Question about JVC HD-52G786 52" Rear Projection HDTV
JVC HD-52G786 Service Mode
I was wondering if you could tell me how you had entered the service mode, and if it's possible to do so without the manufacturers remote, such as a universal remote and how you reset the hdmi input. It'd be greatly appreciated.
Thanks
Sure. I'm not sure if you can do it without the original remote, though. On my remote, you need to have the tv turned on, then press the sleep timer, then press the display and video status buttons simultaneously. This enters the service mode. Then, you should see an option for self-check (#2 i think). Enter that, then you should see 2 vertical columns of different inputs. From that screen, power the tv off. This resets all the ports on the tv.
Posted on Jun 20, 2008
Enter service mode
I'm wondering if you realize what little information you have given us to help you with. I have to make major assumptions just to begin... it must be a digital washer to have a service mode... so its a recent model. Generally, service modes are entered by doing things that a consumer would be unlikely to do, like holding several buttons down while turning the unit on. I assume also it has some sort of display to tell you what is going on.
Really, I can't be much help until you give more info - make and model are essential, and perhaps why you want to enter the service mode.
Sep 26, 2014 | Washing Machines
Can't get volume on jvc hd 52g786
This set is prone to the audio board inside failing---all the audio is on one board, last one I replaced was just over 100 dollars.
Oct 30, 2012 | JVC HD-52G786 52" Rear Projection HDTV
Shadow like effect on television screen. What could be the cause? What is the resolution.
http://download.sears.com/own/05754845.pdf
http://www.user-manuals.com/advanced_search_result.php?keywords=HD-52G786+service+manual&forward=plist
http://209.187.238.153/movies/ServiceManual.pdf
Please find above your user, top, parts, below, and be,low that is your service and repair manual. this should allow you to isolate your issue. It may indeed be a problem with your projection unit, but as these problems can have many many causes, use the TS manual to help isolate.
May 21, 2010 | JVC HD-52G786 52" Rear Projection HDTV
JVC HD-52Z575 red screen
The solution is an easy fix. Ignore anyone telling you to take it to a service center or to replace the convergence driver. You need to access the service menu on your television by using your remote control:
DRIVE CONVERGENCE Adjustment (Using remote control)
•Use the inner RGB box pattern.
(1)Set the [SLEEP TIMER] key to 0 min.
(2)Press the [DISPLAY] key and the [VIDEO STATUS]key simultaneously.
(3)Press the [9] key to display the RGB box pattern.
(4)Select the R mode by pressing the [DISPLAY] key.
(5)Adjust the R mode to setting as same as G mode bypressing the [CH ]+ / [CH -] key.
(6)Select the B mode pressing by the [DISPLAY] key.
(7)Adjust the B mode to setting as same as G mode bypressing the [VOL] - / [VOL +] key.
(8)Check to see that the cross pattern is white. If thecross pattern is not white, readjust (5) to (6).
That's it, your color is now corrected. Yes, I know...your welcome.
Feb 20, 2010 | JVC HD-52Z575 52" Rear Projection...
HOW CAN WE PROGRAM OUR TV WITH OUT A REMOTE
even your basic cable should come in.it sounds like you have a weak tuner
Feb 01, 2009 | JVC HD-52G786 52" Rear Projection HDTV
Red Tinting on Screen
30 YR SERVICE TECH.
YOU NEED TO TAKE THE SET INTO AN AUTHORIZED SERVICER. YOU HAVE EITHER AN OPTICAL BLOCK PROBLEM OR AN INTERMITTANT LVDS CABLE.
APGONZO
Jan 12, 2009 | JVC HD-52G786 52" Rear Projection HDTV
Tv picture is jumping
Unfortunately, JVC service manuals are not usually available outside of Authorized service centers. That being said,anyone that services TVs should have seen similar symptoms on other sets and should be able to "fix" this one even without a schematic. Call around. In the meantime, I'll look into this a bit more.
Dan
Nov 27, 2008 | JVC HD-52G786 52" Rear Projection HDTV
HDMI INPUT HAS FAILED
DId the technicians try to reset the HDMI.
The HDMI module will need to be reset after service
. Enter the service
menu and select “2”, the Self Check option. Power off the unit using the
Remote. Allow the unit to complete its Cool Down cycle, then unplug the AC
Power. Reconnect the AC Power and power on unit. Confirm HDMI input
operation
sorry the font change on me. this unit has compatbilty issue with some hdmi sorces. there is also a safety interlock sensor if it see extra light it thinks your trying to do something wrong and locks up hdmi.
WARNING. Service mode can result in further damage to set. Care should be taken not to mess with settings unless you know what they are.
1) Set to "0 minutes" using the [SLEEP TIMER] key.
(2) Press the [VIDEO STATUS] key and [DISPLAY] key
simultaneously, then enter the SERVICE MODE.
(3) When the Main Menu is displayed, press [2] key to enter
the self check mode.
(4) Turn off the power by pressing the [POWER] key on the
remote control
Nov 17, 2008 | JVC HD-52G786 52" Rear Projection HDTV
JVC HD-52G786 52" Rear Projection HDTV Logo
636 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
