Question about Jenn-Air JED8230 Electric Cooktop
Cooktop problem I received your solution but I am not at home to work on it. Could you tell me what parts I need to purchase to complete my repair? BC
    Guru:
  • 1,894 Answers
I have replied in the premium service sir..
dont forget to accept the solution if u go by it.
Posted on Jun 18, 2008
Burner won't turn off. stays in simmer mode
Good Afternoon Judy, thanks for your post!
From what you have described the burner on your Frigidaire cooktop will not shut down and continues to run in simmer mode. I would suggest performing a reset on your cooktop and you can do that by disconnecting power from your cooktop for at least ten minutes. If that does not help alleviate your situation you may need to have a burner switch or control panel replaced and that is not a simple DIY job. If any electrical components need to be replaced I would recommend contacting a professional technician for proper repairs to be completed. This will help you avoid any unnecessary part purchases. I hope this information is helpful. -OOS
Apr 04, 2015 | Frigidaire Cooktops
I own a Maytag Glass top electric range stove. Model # PER5710BAC. The glass stove top cracked straight down the middle, and one of the bigger burners doesn't heat up anymore. Is there any way to repair...
You could try purchasing replacement parts from a local appliance parts supplier and you might be able to get advice on making the repair. The supplier can advise you of the cost, allowing you to decide whether it is economically worthwhile to repair the range. You also have to consider your degree of confidence in your ability to do the necessary work
Sep 29, 2013 | Magic Chef 30 in. 8241RT Gas Cooktop
I have a Jenn Air radiant glass cooktop, model CCE3401B. The left rear burner will not heat. Howver the indicator light under the control knob stays on continuously, regardless of the position of the...
If the light circle around the knob stayed on, then you have the same problem I just had. I purchased a OEM replacement switch via ebay for $38. Very simple replacement, but take your time so you understand how it works. It took an hour to install and works fine now. Here is the link to the parts list:
shared.whirlpoolcorp.com/assets/pdfs/literature/Repair Part List - CCE3401B.pdf
If you can, take pictures with your phone of how everything is assembled before you take it apart. It will save you hours of aggravation.
I must say, Jenn-Aire (Whirlpool Corp) was less than helpful. I asked for some advice prior to purchasing the replacement part and all they would tell me is they were willing to schedule an authorized repair shop to come over. The closest was a 2.5 hour drive each way, and the travel time cost was $85/hour. Plus the part at list price ($90 something) and installation was going to cost $600. Give me a break.
Dec 31, 2010 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Missing manual and gas diffuser
May I get the make and model # to help you get the manual.
Also from the gas supply from house to cooktop it should go like this.
gas valve
gas line
regulator
then cooktop
May 31, 2010 | Maytag MGC5430BDS Gas Cooktop
JED9800CAS - BROKEN COOKTOP GLASS NEAR THE DOWNDRAFT..... CAN I FIX MYSELF AND WHERE SHOULD I GET THE PART IF SO? OR SHOULD I PURCHASE THE NEW TOP AND HAVE A TECHNICIAN COME OUT AND INSTALL IT? WILL THAT...
You might be able to do the job yourself, but it can be quite challenging. You should definitely consider getting a tech to do it. Whether you'll save any by getting the part yourself depends on the repair outfit. However, if they order the part and it's wrong or something doesn't work out, they are responsible- not you. Some places might charge you for the extra callout if they have to make an xtra trip for wrong part.
Nov 16, 2009 | Jenn-Air JED8430 Electric Cooktop
Need part for an old whirlpool cooktop model number SC8900EXB1
SC8900EXB1 Whirlpool purchased 1999 when house was built. Electric wires to start the burners, started smoking, burnt? Shoud I replace the entire cooktop, if so need comparable system purchase and installed ASAP.
Nov 07, 2009 | Cooktops
MODEL JEC9530 CUSTOM CONTROL ELEMENT TURNS OFF BETWEEN THE 4 AND 6 SETTING. WHICH PART (NUMBER) IS REQUIRED FOR REPAIR?
i would start with the infinite switch itself
you can find this part at appliance parts pro one word dot come
type in your model number
your looking for part number
AP400965 they are currently in stock
unfortunatley it is expensive around 150.00
tell them your a servicer
working for myyellowdog
it may get you a discount
have a great day
Oct 08, 2009 | Jenn-Air JEC9530ADS Electric Cooktop
We ordered a GE gas cooktop 2 burner module to replace the grill on the lefthand side of a cooktop we inherited (model JGP389WEVWW). The gas cooktop only had 2 burners with a grill, and since we want 4...
THE BEST ADVICE I CAN GIVE YOU IS GO ON LINE TO
REPAIRCLINIC.COM AND THEY WILL ANSWER ANY QUESTIONS YOU HAVE AND CAN GET YOU GOING IN THE RIGHT DIRECTION
Sep 26, 2009 | GE Cooktops
Jenn Air gas cooktop
pop me an email at b4829@yahoo.com and reference your cook top you can rate me later
Mar 29, 2008 | Cooktops
Jenn-Air JED8230 Electric Cooktop Logo
49 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
