Question about Ic Verify Computers & Internet
Using PINpad 1000se with IC-Verify and First Data
We are trying to get debit cards working on our system, which uses a vb.net program to extract the data from the pinpad and send this to IC-Verify/First Data. When we run our transactions thru IC-Verify's GUI interface, we get an acceptance. When we run this through our programs, we get a Pin Error message. We are sending them the 16 digit keyed serial number and the 16 digit encrypted pin. IC-Verify states our format looks correct, but they do not know why we are being declined. They suggest it must be in our formatting??
Any help would be appreciated.
    Genius:
  • 1,665 Answers
When I run a debit transaction on my verifone VX 570 it tels me NO MASTER KEY, up until a few days ago I was abel to run all debit transactions just fine, I been using this terminal for about one and a...
Your pinpad has lost its encryption. This usually happens because of a power surge. Or from unplugging the pinpad, and then plugging it back in when the power is still on to the terminal. The pinpad must be encrypted with a code specific to your processor. You will need to contact your debit processor to have the pinpad re-encrypted.
Jul 20, 2011 | VeriFone VX570 Credit Card Terminal (Dual...
Plugged new pinpad 1000se into my verifone vx570 according to instructions. Pinpad shows the moving arrow to indicate it is on. When I run a debit, it does not switch over to accept the customer's pin...
The terminal has a setting to tell it whether to use the external or internal pinpad. Yours is still set for internal. Call your merchant services provider and they will change the pinpad setting so that you can use the external PP100SE.
Apr 29, 2011 | VeriFone PINPad 1000SE Network Terminal
VeriFone Pinpad 1000se - it has "Tampered Device - Press any key" error message. How do I reset this so it will work?
if the intrenal battery is bad you will also get a tamper error, battery needs to be replaced and reload or inject encryption.
Sep 21, 2010 | VeriFone PINPad 1000SE Network Terminal
Where can i get device driver's for NURIT 293
That pinpad does not have drivers associated with the unit. The unit will only work with a credit card terminal IE: Nurit 28xx, 30xx, 80xx and also software developed specifically for the pin pad to work. You can only use that pin pad with a 9Pin serial cable to pc.
May 07, 2009 | VeriFone PINPad 1000SE Network Terminal
Verifone vx510 showing "no master key"
it message show in the pinpad or in the point of sale??? if it is in the pinpad you must re-enteder the master key number into a pinpad.
Mar 15, 2009 | VeriFone Omni 3700
PINpad 1000se not working
When you power on the terminal, is the pin pad also powered on? If it is not powering on the pin pad, you might have an issue with the pin pad. If it is powering on and it's still not detecting it, it might but that you are using the incorrect cords or the programming is blown on the pin pad. You will have to contact your processor to see if they would be able to reprogram your pin pad if that is the case.
Jan 05, 2009 | VeriFone PINPad 1000SE Network Terminal
Pinpad won't work, but has worked before.
The encryption that is loaded on the pin pad is wiped out; this may have happened when powering off the terminal, unplugging the pin pad without unplugging the terminal power source first. What you would have to find out is what platform you are on from your processor, if they are not willing to do it, you can contact companies that will reprogram your pin pad. This will be cheaper than to buy another pin pad.
Dec 12, 2008 | VeriFone PINPad 1000SE Network Terminal
Verifone 1000 se
The Verifone 1000se uses a special serial cable that also has to provide power to the device. It does not use either ethernet nor usb.
Mar 31, 2008 | VeriFone PINPad 1000SE Network Terminal
Microsoft Retail managment system
You need to have the correct keys loaded into the pinpad. If you got the pinpad from some place other than from your processor, you are out of luck. They will only load the keys when the pinpad is physically in their possession.
Feb 29, 2008 | VeriFone PINPad 1000SE Network Terminal
Computers & Internet Logo
181 people viewed this question
Top Ic Verify Computers & Internet Experts
David Payne
David Payne
Are you an Ic Verify Computer and Internet Expert? Answer questions, earn points and help others
