Question about Minolta EP4000/5000 CS/PRO Copier
I need help for Minolta CS/PRO 2080 Error code C0500
  • Anonymous May 20, 2009
    the box dosent seem to be located on left side of machine. Any other ideas on how to reset it?
  • 2,923 Answers
This is a lamp error, check that is not burned, or the thermal fuse.
1. Press the soft initialization on the right side of the control panel.
2. When the dot appears on the LCD after reboot, press the number 3 key.
3. The mode will change to the initialization screen.
4. Choose the selection for trouble reset.
5. After reboot the code will be cleared.
Warning: Be advised that with fuser codes, some RISKS are involved, PLEASE SEEK PROFESSIONAL HELP to reduce these risks.
Thank you and good luck!
Posted on May 02, 2010
  • 145 Answers
Open front door close and locate a samll cover on the lft side below screw open it and you will c 2 botton on a small board one should say trouble reset depress once
good luck
Posted on Sep 29, 2008
Model 7113 Konica has got a problem of error C0500
Posted on Aug 11, 2009
My copier give code c0500
Warm-up failure
- The surface temperature of the Fusing Roller does not reach a given level even after the lapse of a given period of time during a warm-up cycle. Please change upper roller
Feb 15, 2014 | Minolta EP4000/5000 CS/PRO Copier
Code error c0500
Open the front door, to the upper left there is a small access remove the plate press the button with the machine on that will reset the c0500 code if it comes back do NOT reset the machine it is telling you that it need fixing continue to do that can destroy boards worse case start a fire. YOU are resetting the code for the Fusing Unit which fuse the toner to the paper. GETS very hot normally.
Feb 07, 2014 | Minolta EP4000/5000 CS/PRO Copier
Code c0500
C0500 is a problem with the fixing unit. Check the fixing lamp & thermal fuse and thirmistor.
Oct 03, 2013 | Minolta EP4000/5000 CS/PRO Copier
Error Codes
Well the C0500 code is the code that is given when the fusing unit is bad (THE HOT PART) to reset that code need to go to the rear remove top rear cover and press the small black button on the control board lower left. The C0400 is Exposure Lamp the bright lite under the big glass. Might need to get a new one try web site below as for the C0500 if it comes back do not reset get Konica Minolta rep to look at the fuser unit. IT can catch on fire and that would ruin a perfectly good day. If parts required see the web site below for a start Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Feb 16, 2012 | Minolta EP1083 CS/PRO Copier
Minolta EP2080 malfunction detected ... code C0500 .... this is an old machine ... anything we can do here ourselves to clear the error code?
the laser unit of the machine is faulty.either the polygon motor in the laser unit is not working or the laser diode is not working.anyways u have to replace the laser unit to make it work and it is costly so better buy a new machine
Aug 15, 2011 | Minolta EP4000/5000 CS/PRO Copier
Minolta CSPro 3000 Copier/how to enter service mode
Press Stop - 0 - 0 - 1 or it maybe User Funciation then meter count - Stop - 0 - 0 -1 , it's been years since I worked on them
Feb 06, 2009 | Minolta Di3010 Copier
Problem in minolta cspro 2050
What code are you looking for??? I'll tell you what it means for FREE.....
Aug 19, 2008 | Minolta EP4000/5000 CS/PRO Copier
Ep2080 minolta cspro
Ep2080 minolta cspro error code comes up with c0500
Dec 06, 2007 | Minolta EP4000/5000 CS/PRO Copier
C0071 error code minolta cs pro 2080 copier
this code is for toner motor rotation abnormal timing. check for any loose toner inside the toner hopper rotational path, clean the sensor for toner motor. check the toner bottle inserted is for the same model
Nov 21, 2007 | Office Equipment & Supplies
549 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
