Question about Haier Dryers
Haier dryer model#rde350aw. motor binding drum in a binde
4 Suggested Answers
Jimster
  • 240 Answers
SOURCE: Kenmore series 90 dryer
I hae to say it, but it sounds like the motor has already gone out. That loud humming noise is usually the start windings going out. There is no other way easily to tell if the motor is out, but taking the belt off and saying it doesnt look broke what work in this situation. I would imagine that you have a DOTT (Dryer Of Tommorrow, Today) dryer, because you said it had the front panel. The motor part number is 279787 if this the case. Good Luck, and let me know if you find out any new information or need further help.
Posted on Feb 13, 2008
SOURCE: Hoover Tumble Dryer 5030D
I picked up a second hand unit which had the same problem.
I removed the back (philips head srewdriver and 1/4 in socket) and vacuumed all the lint from around the motor, and the vent at the back.
The motor drops our easily for cleaning (1 screw). Make sure the belt tensioner goes back in the same slot.
Mine now works as normal.
Posted on Jul 21, 2008
SOURCE: Maytag MDE6000AYQ Dryer
Sounds like the belt that rotates the drum may be slipping. Does your drum turn ok when no clothes are in it? If you have to start it by hand and then it rotates ok chances are you need more belt tension.
Posted on Sep 04, 2009
My Haier Dryer Model RDE350AW only clicks when I press start button, any suggestions?
Since the start relay is clicking it is likely closing the circuit and sending voltage to the dryer motor. You may have a defective thermal limiter fuse blown, it is near the dryer motor so you must remove the back or front of the dryer to access it for testing. Always unplug the dryer before any work is done. You will need a DVOM meter (about $10.00) to check the fuse for continuity.
Dec 28, 2016 | Haier Dryers
Rotated drum by hand heard loud bang
take off top see if counter weight came loose
Mar 01, 2014 | Haier RDE350AW Dryer
Maytag ensignia
follow this steps and fix it. God bless you
Drive Motor
The dryer drive motor turns the drum and the blower wheel to exhaust the air. If the dryer stops the motor might be defective. If the dryer stops and the dryer motor makes a humming noise there might be something caught in the blower wheel, or the drum might be binding. Try removing the belt from the motor and checking the blower wheel for obstructions. Also try rotating the drum by hand with the belt off, it should rotate freely. If the drum doesn't turn freely, determine what is causing it to bind. The dryer motor can't be tested easily. If the drum turns freely and the blower wheel is clear, and yet the dryer still keeps stopping mid-cycle the motor may be defective. it will need to be replaced. It is not serviceable.
Enter your model number to see parts for your dryer.
Help me find my model number
Drum Roller Axle
This dryer has drum support rollers. There will always be two supporting the rear of the drum, and on some models there may be two supporting the front of the drum. The rollers must spin freely to work properly. If the roller axles are worn out the rollers may not spin freely which can overload the motor and the dryer stops. If the dryer stops mid-cycle, remove the belt and spin the drum, it should spin freely. If not, check the rollers and roller shafts.
Drum Roller
This dryer has drum support rollers. There will always be two supporting the rear of the drum, and on some models there may be two supporting the front of the drum. The rollers must spin freely to work properly. If they are worn out or start binding the motor can get overloaded and the dryer stops. If the dryer stops mid-cycle, check to be sure the drum turns freely with the belt removed. If not, check the rollers. Do not lubricate the rollers or roller shaft, lubrication will attract lint and cause the roller bearings to wear out faster. If the rollers don't turn freely, replace them. The roller shaft can often be reused, unless it has worn down. Clean the shaft thoroughly before installing the new rollers.
Drum Support Roller & Axle
This dryer has drum support rollers.There will always be two supporting the rear of the drum and on some models there may be two supporting the front of the drum. The rollers must spin freely to work properly. If the roller axles are worn out the rollers may not spin freely. If not, check the rollers and rollers shafts. If they are worn or do not turn freely they will need to be replaced.
Drum Slide, Glide, or Pad
The front of the dryer drum is supported by small pieces of plastic-like material. As the drum rotates, it slides on these plastic pieces. If the dryer stops mid-cycle, it may be that one or more of these plastic slides or glides has worn out. When they wear out the drum can start binding and put strain on the motor. The motor then shuts down and the dryer stops. Check the glides for wear and replace as needed.
Drum Bearing
The drum bearing supports the rear of the dryer drum. Over time this bearing will wear out and may cause several different problems. If the dryer stops during the cycle it may be that this drum bearing has worn out and is putting too much strain on the motor. If the belt is removed and the drum spins freely, the drum bearing is probably not worn out. If the drum bearing is worn out, there may be some grinding or squealing, and the drum will be hard to turn.
Drum Support Bearing
Dryness Control Board
The dryness control board shuts off the dryer when the clothes have reached the level of dryness selected by the user. If the dryer stops too early, the dryness control board might be defective. This is not very common and other possibilities should be checked first.
Jul 21, 2013 | Maytag Dryers
Drum does not turn
did you check the belt? It may be stretched or broken . Its on the bottom of the drum , on the bottom of the dryer
Apr 21, 2012 | Haier RDE350AW Dryer
MODEL # RDE350AW HAIER HAS POWER BUT WONT START MAKES CLICKING SOUND
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 17, 2011 | Haier RDE350AW Dryer
Dryer won't start.. has power sounds like something binding. long buzzing sound when starter depressed. try once or twice and then nothing for a while. come back try again ..long buzzing sound again
Hi and welcome to FixYa, I am Kelly.
You did not include a make and model number for your dryer so... this is a GENERIC response. With a make and model number we can better help you.
The long buzzing your hearing is the motor winding trying to start the motor. After 30 - 45 seconds if the motor does not start the thermal overload will cycle and prevent further attempts for around 5 - 6 minutes until the motor winding cools down.
Causes of a dryer motor not starting:
1. Binding.
a. Broken dryer fan blade lodged inside the blower housing
b. Motor start switch failure
c. Motor bearing failure
2. Dryer drum bearing / roller problems
a. The drum can be bound up and dragging on internal components of the dryer
b. The Idler pulley bearing may have failed and it is now a brake.
c. Front or rear drum seals failed / pinched against rear or front of the chassis
d. Drum roller bearing failure and is now a brake.
Reach inside the drum and see if you can turn the drum. If you can not turn it with a little effort, you need to find out where the binding is inside your dryer.
This is the best I can do for the moment without a model number. With a Make and Model number I can provide parts listings and item numbers of where to check.
Thanks for choosing FixYa.
Kelly
Feb 06, 2011 | Dryers
When I go to turn the dry on, u can hear the motor kick in, so it is gettin voltage, but nothing happens.... the drum or barrel of the dry turns freely.... I figure that it is the belt.... but when the...
are you saying when you press the button you hear like a buzzing sound but the motor doesn't start and the drum spins freely by hand,most likely you have a bad motor or the belt broke and is stuck in the motor binding it up,the only way to tell is get in there and check it.what brand name dryer and send the model number?
Aug 20, 2010 | Dryers
Hey when we turn on our dryer we get a burning smell and the drum doesnt turn, any ideas? we think the engine might have burnt out?
Either something is binding the drum, or the motor has failed. Can you turn the drum by hand? If you can, then most likely the motor has failed, if you can't turn it by hand, then the drum is stuck and the motor just isn't able to turn it until you find whatever is binding the drum. You might have to remove the back panel to get in to see what might be causing the problem if it is binding.
Let me know what you find with this.
Benjamin
Feb 06, 2010 | Kenmore 62602 Electric Dryer
Dryers Logo
82 people viewed this question
Top Haier Dryers Experts
Tim Whalen
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Haier Dryer Expert? Answer questions, earn points and help others
