Question about Sony ACID Pro 7 for PC
Rendering problems . I recorded a mix in Sony Acid 7 .After rendering it to a MP3 and listen back the delays i used in parts have gone out of time .
3 Suggested Answers
  • 13 Answers
SOURCE: How do i get rid of microphone delay?
You need to adjust the buffer in acids settings. If you set the buffer too low, everything will be in time, but you will get pops and clicks in the audio. Try and find the happy medium for your system. Also be sure there are no other programs such as a virus scanner enabled or running while recording.
Depending on your sound card, there could be another solution if adjusting the buffer does not work for you.
You will then need to find a different ASIO driver that is compatible with your sound card. If you have a soundblaster, there are 3rd party ASIO drivers that you can install, and that should fix the issue.
Good Luck!
Posted on Jul 11, 2010
simcode
SOURCE: I have a Fostex DMT-8vl 8 track digital recorder.
You can copy. You cannot just dump the file data. Unless you have an audio interface with multiple inputs, you can only copy 2 tracks at a time. Also, to sync the timing you'll need a midi port on the computer. Then you make the computer the "master" and the Fostex a "slave" device.
Posted on Jul 22, 2010
Video card or driver doesn't support the required fixed-function texture blend operations. DirectX 7 rendering path will not be available. Video card or driver doesn't support direction lights in...
Hello, the problem seem to be related to the video card you're currently using, See if you have an integrated video card: a hint to find out is to see behind your computer if the monitor connection is on a side of the back panel is probable you have an incompatible integrated video system, you can solve this problem by buying and installing a compatible video card as any Nvidia or ATI card, Call an IT professional and ask for some advice on what card you should buy and install to make these problems disappear, also ask him/her to install it for you.
Have a nice day, and If you have any other questions you can come back and reply.
PD: If you still want to buy and install it yourself ask me again and I'll help you.
Jun 03, 2011 | Microsoft Windows XP Professional
When I try to record an audio CD on the internal CDRW from a mixed down song in the VF160 it records it, but adds a horrible, cyclical "hiss" (very loud) over the recording rendering it useless.
I haven't personally used this equipment, but 9 times out 10, a hiss or noise problem is due to damaged or incorrect cables been used.
Check your cables.
Check your gear. If the inputs are TRS (1/4") the make sure your cables are to. This goes for any connection your recorder: balanced cables.
If the inputs are unbalanced, then you would use TS (1/4")
Apr 01, 2011 | Fostex Mr16hd 16 Track Digital Recorder
There is a 2 second delay with my snowball. I am trying to record and a vocalist needs to listen to their voice quality when doing so, however it is very difficult to actually record with headphones on...
The delay isn't the mic, it's the mixer or how you're routing signal that's causing delay. If you're using a stander mixer use 2 separate "aux.'s" one for your vocalist and 1 for yourself. OR i aux for your vocalist and you listen to final output (stereo mix)
Mar 02, 2011 | Blue Microphones Snowball Professional...
When trying to render my DVD Architect Studio 5.0 project to burn to DVD it just starts rendering and the percentage stays at 0% and just keeps going for hours. This is only the second project I've done...
Sony DVD Architect Version 5 - large rendering time, not burning disk, stuck at rendering stage, stuck at 0%
I don't often write on forums, so I hope the information I give helps and maybe saves someone some time.
I recently got the trial version of Sony DVD Architect. I made a DVD, including a menu, I was really happy with it.
When I tried to burn the disk, it said it required more than 24 hours and counting, to burn a single disk. I waited for hours, and it was still stuck in the "rendering" stage, not getting past 1%.
I tried many, many, different variations of my dvd to get it to work. After many hours of altering things to find where the problem might be, I finally isolated it. After turning off "animated thumbnails" the DVD burnt normally.
I emailed Sony's technical support during my problems asking for help, and got no response back. I will send this letter to them too.
Despite wasting a lot of my time and getting no useful help from the company, as of now, I am happy with this product.
Hope this information helps ~ John
Dec 23, 2010 | Sony DVD Architect Studio 4.5 for PC...
Good Luck!
Jun 20, 2010 | Sony ACID Pro 7 for PC
Timing problem!! help needed badly!
Your solution is to delay or speed up the sound that your running thru to your computer. The reason why they put user recording latency under the options then preferences then audio settings is not because this never happens or isn't know about. If your sound is too late in the track you have to re-record the track with a higher number try about 125-160. A hint is to play some notes to the beat, check to see that you are in time, then record what you are planning to record.
Jan 11, 2009 | Sony ACID Pro 5 for PC
I am not able to record the tracks in acid pro 7.
man oh man.. have i been fighting with this problem !!!!!!!!
but guess what---- i have the answer!
so heres what the problem is believe it or not.. your antivirus program.. especially kaspersky!!
what is happening is either the program is trying to scan as you record.. or just simply is deleting the file... either way you end up with a blank record box.. and get errors when you try to open the audio files you just recorded..
so the fix is very simple!!!
tell you anitivirus program to give full permisions to acid and not to monitor acids activity
there you have it..
www.myspace.com/jphat now visit my myspace.. lol
Dec 29, 2008 | Sony ACID Loops - Ugly Remnants: Volume...
Problems recording with Sony Acid mucic studio 7!
This probably has to do with the levels you have set for the sound card - take a look at your mix levels AND the volume input level 0 this is not the same control as output
Sep 30, 2008 | Sony ACID Loops - Ugly Remnants: Volume...
Sony ACID Pro 7 for PC Logo
242 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
