Question about Frigidaire Cooktops
I have a cooktop Frigidaire model GLEC36s8eba and two burners dont work. I had sparks come from th control knob now the burner doest work. please adivse of the parts to order
fridgetech
  • 473 Answers
SOURCE: knob not working and some burners not heating
The switch under that knob is bad.  It's called an infinite switch.  As far as the elements go, first thing to check is for proper voltage (220) to the cooktop.  Let me know what you find.
Posted on Oct 19, 2007
  • 619 Answers
SOURCE: Frigidaire Ceramic Cooktop PLEC36S9eca - Turns on but burners won't heat up
Check the power plug is their any separate plug on it / if none check the control panel some switch to power on .
Posted on Jan 05, 2008
SOURCE: six burner gas cooktop
My husband figured it out.....when we took the knobs off, I, of course, washed the area they had been sitting on, thereby spilling some water into the open part which contained the wires leading to the igniters.  A short time with a hair dryer sorting things out.
Posted on May 07, 2008
  • 110 Answers
SOURCE: Dacor SGG365 one burner control won't cause spark
your problem is most likely the spark switch, but it could be you spark module but that is highly unlikely
Posted on Oct 23, 2008
  • 1462 Answers
SOURCE: Element on ceramic Frigidaire Gallery cooktop won't go off.
take knob off and check the middle is not split and hence not turning the shaft
Posted on Nov 20, 2008
Cooktop burner do not ihnite
Hi hgodoy2 - Is the electronic igniter aligned properly? Ensure that tip of spark igniter is aligned with metal point or "nib" located on underside of burner cap after the burner mounting screws have been tightened. (Not all burners having mounting screws). When the burner control knob is set to the "LITE" position do the igniters spark? Can gas be heard or smelled coming from the burners when the control number is turned on? However, if you smell gas, I highly recommend turning the unit and the gas off if you can reach it and contact your gas provider. The range itself does not have a switch or regulator to relight it. Keep in mind that it may be experiencing an issue with the spark module, electrodes, wiring or EOC.
Nov 24, 2012 | Frigidaire 36 in.GLGC36S9E Gas Cooktop
R rear burner not sparking
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
May 02, 2010 | Dacor Preference SGM365SS Gas Cooktop
Igniter doesn't spark on only one burner
There are three parts to the ignition system typically.
The ignitor that is either in the burner or outside the burner.
The spark ignitor switch that is located on the burner control. (( one for each control ))
The spark modual. the modual creates the hi-voltage spark.
If the burner that does not ignight with its control does not spark but does spark with one of the other controls then the spark ignitor control switch is bad.
You can test it with one of the other burner control knobs. (( just try a working burnder and when it clicks look at the bad burners ignitor and look for the spark.))
If the bad burner that wont ignight does not spark then either your modual is bas or the ignitor is shorting out.
If you see any little spark but it does not spark from point A to Point B like the other burners then your ignitor is shorting and should be replaced.
If your ignitor is ceramic and it is cracked, then it should be replaced.
Jan 13, 2010 | Miele KM360GSS 23 in. Portable Gas Cooktop
The igniter on the right front burner of my GE Gas cooktop does not work....I must use a lighter or match to ignite....What can I do? There is no clicking sound when I turn on the burner?
all burner igniters work at the same time - you may have a faulty electronic spark unit. change the spark unit. go to repair clinic dot come for the unit. also would be wise to check the ingniter start switch on the gas burner control knob
Oct 17, 2009 | GE 36 in. JGP628 Gas Cooktop
Short in knob
Replace the spark switch module on the bad burner.
Sep 29, 2009 | Amana AKS3040 Gas Cooktop
Have Jenn-Air 36" gas cooktop w. 5 burners, black. Mdl JGC8536ADB. Plastic knobs keep splitting, even if we remember to push down before turning. Have replaced two sets and now we're down to two working...
Hi
Thanks for using FixYa. There are a few things to check for. Make sure the electrode (the small metal piece that the spark comes off from) is clean and the holes in the burner are clean, use a pin or paper clip to clean out the burner holes and not a tooth pick as these can break off and make things worse. Example of a burner. The next thing to check for are the ignition switches under the surface control knobs, the switches can twist and break and keep the spark module on and the spark keeps "clicking" even when the burner is light. If every thing looks good, you may have a bad spark module, replace it.
The switches or the range control knobs may have got wet and are completing the circuit to the spark module thus causing it to continuously click or fire off sparks continuously. Use your hair/blow dryer and blow some hot air around the spark module area.
This is a typical spark module wire diagram--
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jul 31, 2009 | Jenn-Air 30 in. CCG2423 Gas Cooktop
Oct 22, 2008 | Cooktops
Cooktops Logo
Top Frigidaire Cooktops Experts
Dan Webster
Dan Webster
Are you a Frigidaire Cooktop Expert? Answer questions, earn points and help others
