Question about Linksys Wireless-N WRT150N Router
I cannot access all websites with my wireless-n home router. what should i do orwhat could be the problem?
  • Linksys Master
  • 7,733 Answers
Make sure the physical connection is good between the computer in question and the D-Link gateway. If you do not have a solid link light, try swapping cables. Make sure the ethernet adapter is installed and functioning properly.
If you are running any firewall software on the computer that cannot connect, disable it. Make sure the TCP/IP settings are set to obtain an IP address automatically. Try releasing and renewing the IP address for your ethernet adapter. It should pull a 192.168.0.x address with a subnet mask of 255.255.255.0 and a default gateway of 192.168.0.1. If it does not get an IP address in this range, specify the address to be 192.168.0.10, subnet mask 255.255.255.0, and add the default gateway and primary DNS 192.168.0.1. Try and go online.
If it still cannot get online, go to the Control Panel and open Internet Options. Restore the default settings on the Security and Advanced tabs. On the Configuration tab, make sure the Dial Up setting is set to never dial a connection. Click the LAN settings button. All you want selected here is automatically detect settings, uncheck the other two boxes. Try and go online.
Posted on Nov 13, 2010
Associate wireless router to my home hub
If your Home Hub is a BT type internet hub, then you can connect the WAN port to the Ethernet port on the Hub.
This means it will go through two routers. One in the Hub and another in the Edimax. The Edimax needs to be configured as a bridge, because you need to keep within the same address range as the BT router. The Edimax DHCP allocation of IP addresses need to be disabled. This is not on the web site.
EDIMAX Technology Official Website Wireless Routers 300Mbps Wireless...
Mar 02, 2015 | Edimax Network Br-6428ns Wireless N 300m...
I bought a new router for my home pc and I am trying to enter the new security key into my wireless repeater but keep getting and error message saying page can't be displayed, how do I get into it?
You can disable the wireless security on the router to allow you access to the repeater. Once the repeater has the proper key you can enable the the wireless router security.
Aug 14, 2014 | Computers & Internet
Tablet connected to Wifi but does access websites
It looks like the wireless part of your wireless router is damaged.
If your friend's wireless computer/laptop cannot detect a wireless signal from your wireless router then this confirms the wireless fault.
Dec 04, 2012 | Computers & Internet
Delete home network defender
Reinstall the software and uncheck Home Network Defender during install.
Oct 06, 2012 | Linksys WRT160N Wireless Router
Why will my pavilion dv9000 only connect to public access networks, and not wirelessly to any home networks?
sounds like
a. wpa or wps needs to be reconfigured at router
b. firmware for router needs attention
c. router is truly unhappy about wireless settings
check router website for management access and adjustment procedures
not an hp issue
May 30, 2012 | HP Computers & Internet
Hello I have a type of router 802.11g 2.4ghz Dlink I want to learn how to work PASSWORD of the Internet in the home, so do I prevent neighbors from accessing the website of our own
In your router configuration, activate WPA2 encryption with a 64 bit key. Get a random key here:
http://www.grc.com/passwords.htm
Use this key to use the router connection with other computers in your home.
Sep 12, 2011 | D-Link 802.11g Wireless Router WBR-1310...
I NEED THE Home Wireless AR SECURITY CODE TO HAVE INTERNET IN MY WII
You will need to login to your wireless router to get the wireless password. You will need to know the username and password to the router in order to access this information. You will need to talk to the person who setup the router for the information. The router website will vary depending on the brand of the router. If you do not know the router username and password. You will want to contact the router manufacture for assistance acquiring that information.
May 31, 2011 | Nintendo Wii Console
How to set up password on my wireless router ?
The answer to this depends on WHICH password...... Router access, or wireless access. Run the install wizard from Edimax....but here are the highlights of what should be set:
Wireless Router
It is usually easiest to run the install wizard from the manufacturers' website, usually for free, but be sure to be ready to set the items listed below.
To get access, start your browser, and put 192.168.1.1 or 192.168.0.1, or other address for your unit, into the ADDRESS bar (not search box) of your internet browser. Every unit has unique access login and passwords, some are admin with no password, some are admin and admin...seek access information from the website of the manufacturer of your unit.
Things to set:
Note: Routers are intended to be set by geeks. You have to SAVE EVERY page before you leave it, or the changes will be lost. A geek knows this (apparently). The router gives no protest...just dumps your changes.
1. Login password (RECORD THIS!!). Consider taping to bottom of the router. Physical access is not the security issue.
2. Set a recognizable system ID.
3. Invoke wireless security of at least WEP.
a. Assign your own access code, 10 digit home or cell #. Consider taping this information to bottom of the router. (Physical access is usually not the security issue.)
4. Check that your router is set to broadcast its' presence.
5. Change the channel of the wireless to 11, and avoid conflict with landline cordless phones. (Big issue, even the neighbors can interrupt).
There are more secure settings available, all the way down to only allowing certain MAC addresses to have access. A MAC address is a digit unique to each and every network card. Like a fingerprint. Most users do not set mac address limits
Apr 24, 2011 | Edimax BR-6226n nLite Wireless Broadband...
I set up wireless network for my boss, using Belkin wireless n router, so the 3 computers can connect to the same wireless printer, and she can access this network with her home laptop. All is well except...
If possible, to rule out the modem as the cause, connect a computer directly to the internet(bypassing the router entirely). If it is the router, you could try flashing it back to factory defaults and reconfigure. Log into the router's firewall feature and see if port 443 is blocked to the outside--this could cause https connections to fail.
Mar 04, 2011 | Belkin F5D8236-4 Router
Help me access linksys router website. if i type 192.168.1.1 an error appears.
Typing the IP address will not get you to the Linksys WEB site.
The Linksys/Cisco WEB site is -
http://home.cisco.com/en-us/wireless/
The configuration URL for for configuring the Linksys wireless settings is -
http://192.168.1.1
The default login = admin
The default password = admin
Sep 11, 2010 | Linksys WRT160N Wireless Router
Linksys Wireless-N WRT150N Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
