Reset the BIOS on a Compaq server 740 jumpers settings
  • 7,733 Answers
Don,t do that insatead:
Entering the BIOS Setup menu Entering the BIOS Setup menu requires pressing a specific key at a specific time. If you fail to enter the Setup menu on your first try, repeat the following steps until you are successful:
  1. Close all applications that are currently running and restart the computer by clicking Start , Shut Down , Restart the Computer , and then OK .
  2. When the red Compaq logo or blue HP logo screen appears, press the F10 key on the keyboard to enter the Setup menu.
NOTE: An alternate to the above steps, especially if the logo screen disappears too quickly to enter BIOS, is to shut down (turn off) the computer. Wait 30 seconds, turn the power on and press F10 or F1 at the logo screen. Reloading the default settings Complete the following steps to reload the factory installed BIOS Setup settings:
  1. In the BIOS Setup utility, select the Exit tab.
  2. Select Load Setup Defaults .
  3. Select Save Changes and Exit (pressing F5 and the Enter key will also load the Setup Defaults).
  4. Press Esc and then Enter to exit Setup.
Posted on Nov 13, 2010
IBM x3550 Server
You will need to remove the cover and locate the jumper that controls your BIOS setting. (Sometimes located near the back of the server board by the power supply. Check your owners manual for exact location.)
Move the jumper the BIOS reset, power on your server and follow the onscreen instructions. When complete, move the BIOS jumper back to regular position (1 and 2) and reboot.
Good Luck
C2Solutions
Feb 15, 2012 | IBM x3550 Server
F10 function key has password i didn't set ?
Since this came to me as a desktop question I will give you that set of instructions. you will need to power off the machine and unplug it. Remove the side panel of the computer (or top panel depending on the model). When you look at the motherboard you will see a CR2032 battery that powers the BIOS chip to allow it to retain it's settings such as password, date, and time. There may also be a jumper on the board (a little plastic square with copper in it) to reset the BIOS. You will be looking in the same general area of the battery for this jumper and it should be labeled CMOS or Reset.
If the jumper is present you will need to use it to reset the BIOS. If using the jumper doesn't reset the password then you will need to remove the Battery I previously mentioned and let the computer sit without power or battery for several minutes.
If this still does not remove your password (or if you would like to try this first) you can try to use a manufacturer override password. On a Compaq system the override should be Compaq. That does have a capitals C and the password is case sensitive.
Best of luck!
Nov 13, 2011 | Compaq Computers & Internet
Power-On Password on Compaq Presario C300
YOu can reset bios password with 2 method.
(1) open back cover of laptop then find motherbord .Pull cmos cell from motherbord for 15 minutes then again put it in it's position .then it not ask for password.
(2)You can clear password with jumper settings find jumper on motherbord named clear cmos it has 3 pin .1-2-3
Put jumper in 2-3 position then again put it in 1-2 position then check .
Let me know if you need more assistance.
Thanks.
Nov 09, 2009 | Compaq Presario Notebook
RESET BIOS PASSWORD ON COMPAQ 6400 LAPTOP
Thanks.
Nov 16, 2009 | HP Compaq NC6400 Business Notebook
Need help forgot password for HP Compaq NX7330
here are 2 password type first 1 is bios password if tell me about your bios password it prompt when u powerup follow procedure below
For that you need to reset factory defaults settings for bios.
For reset bios u have to open back side of your laptop then u find motherbord circuit there.
pull cmos cell on motherbord for 15 minute then it reset to defaults.
Also u can reset with jumper settigns read carefully on mother bord there is 1 jumper near cmos cell u read there " bios reset or clear"
It is on 1-2 position right now set it in 2-3 position then power up then all bios settings are reset.
then again set it in 1-2 its original position.
Then it not want password.
And if u tell about windows password
Then when you power up the computer press F8 key then enter in safe mode then wait until it prompt for user passsword
then enter in administrator then if u able to enter then reset your password.
But if u set and forgot default administrator password then u should need winxp recovery disk.
Please rate me .
Thanks .
Jul 29, 2009 | HP Compaq nc6320 Notebook
I have forgotten the power on password of my compaq nx6310 laptop
Jul 16, 2009 | Compaq Evo N610C Notebook
Reset Bios Password on a Dell Poweredge 2850
The following information was found here http://www.darklab.rutgers.edu/MERCURY/t15/pe2850dell.html
This should take care of your issue.
Password Jumper Place the jumper on both pins to enable the password. To disable the password, remove the password jumper.
Apr 06, 2009 | Computers & Internet
Reset bios password
You need to locate the Cmos battery, not the jumpers, this is not a desktop.
Locate the Cmos battery, disconnect the battery for ten seconds, and Bios will reset to factory default.
Jan 03, 2009 | HP Compaq nx6110 PC Laptop
Power on password
did you set the password from the bios settings? if so, reset your bios by opening your pc casing (be sure that its unplugged) locate the bios reset jumper (mostly found near the battery cell in the motherboard) take out the plastic jumper from pins 1 and 2 and set it to pins 2 and 3 and wait for about 10 seconds then put it back to its original settings ( 1 and 2 ). close your casing and start your pc
Oct 17, 2008 | HP Compaq dc5100 PC Desktop
How to resets bios for compaq 2514 at
Why? What happend? Is it asking for a BIOS password?
If it is asking you have to short two jumpers on the systemboard to have it reset.
If not, just go in to BIOS by pressing F2 then restore or optimize default settings on BIOS.
Hope this helps...
Jul 24, 2008 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
2,886 people viewed this question
David Payne
David Payne
