Question about GE Profile JTP18 Electric Single Oven
My bake element needs to be changed which one do I need to buy. I have a GE stove model GRSR3620SM-2, thanks,
5 Suggested Answers
ranger25
  • 72 Answers
SOURCE: GE Oven bake element not work
It sounds like a problem with the selector switch. You have to remove the back panel to get to the back of the switch in the head unit, and find what wire goes from there to the bake element. With a meter set on 240ACV, or whichever setting is on yours that's HIGHER than that i.e. 400ACV, with the red probe on the terminal and the black one going to ground, see if you are getting 210-240 through it. If so, then it's either a faulty neutral wire connection (the other wire coming out of the element) or the selector switch. Hope this helps.
Posted on Jan 29, 2008
SOURCE: mabe oven
Hi, well i have researched the mabe oven problem and it turns out that mabe used to make a 110V oven bake element for the ovens made in Mexico. However it appears that they no longer make that model oven and it's parts. Isn't that just golly gee terriffic!I am still searching for an element for it as GE who is also a share holder about 42% worth also has parts that sometimes will fit the Mabe made in Mexico, and not to be left out of the programe Camco is also part of the GE Mabe family so they are also a source to check with, and yes even whirlpool who is nothing to do with any of those other than a competitor sometimes has parts that will fit the Mabe made in Mexico. I'm not saying it will be a perfect fit but if it works, it works, but i'm not recomending you do it to a customers appliance at least not without asking if it's ok.
Posted on Feb 20, 2008
SOURCE: my ge spectra stove bake element is not heating
I have a GE Spectra stove. The top element over heated and broke in half.
Posted on Sep 08, 2008
dgjtex
  • 405 Answers
SOURCE: Install bake unit in GE wall oven model JKP07J
I honestly believe you are right. you should be able to wiggle it back and forth and pull it out.
Posted on Dec 27, 2008
GE stove model GRSR3620SM-2 Self Cleaning Cycle Not Working.
my first thought would be a loose connection at the element or main power terminal. it could be a relay board issue also
Jan 08, 2012 | GE Profile JTP18 Electric Single Oven
How to change the bake element in a GE stove
Unplug or turn off all power to the oven. With most ovens you can then unscrew the element from inside the cabinet with either a screwdriver or a 1/4 nut driver. carefully pull the element out with the wires attached and dont let the wires go back through the holes. Unplug or unscrew the wires from the old element and plug into or screw onto the new depending on the type of terminal. If it is a push on type terminal make sure the connection is tight, if they are not tight pull the terminal back off and tighten the gap with pliers and recconect. put it back together and you are done. If by chance the wires are not long enough you will need to pull the stove out, remove the back panel and make the connections from the back. Good luck, it is not hard.
Dec 13, 2009 | GE Ovens
GE Evolution stove/oven. My oven is not working,
remove heating element an check with ohm meter. pretty simple really.
Jun 12, 2009 | GE Ovens
Bottom oven element not working
Only 2 things left. A bad wire or bad control board.
Remove the rear panel. Set the range to bake,check power at the element terminals with a voltmeter. Ifyou do not have 220 volts at the element replace the ERC.(clock).
May 23, 2009 | GE Ovens
Can I use a similar bake element if I can't find the exact match
Yes, I would say you could use a different shaped element.
Apr 28, 2009 | GE Ovens
Heating element in GE Range Oven
get the model number and order the exact repacement bake element
Mar 10, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Mabe oven
Feb 18, 2008 | Ovens
My ge spectra stove bake element is not heating
Dec 18, 2007 | GE JKP20 Electric Single Oven
GE Profile JTP18 Electric Single Oven Logo
124 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
