Need a wiring diagram for armstrong package unit m# pge10a36d075a-2a
5 Suggested Answers
bobicehouse
  • 1524 Answers
SOURCE: I am looking for the outdoor AC unit wireing
Atta way.
Posted on Apr 27, 2009
  • 116 Answers
SOURCE: Need wiring diagram
check the capicitor if it is domed up on top bad check the wires at the compressor to see if burnt take a insulated object and bump the contactor in to see if comp starts if so then out on low voltage circ check for call from stat on common to yellow then follow the connections may be out on low psi switch located in the suction line
Posted on May 10, 2009
farfield
  • 462 Answers
SOURCE: need wiring diagram for 1980's 3 ton package unit
I assume you know if this is correct voltage and single or 3 phase, and whether it will fit your application or not, how is the duct work going to attach, how many people will be in the conditioned area, what is the building made of, how much insulation is has...
A little more to it than just "turn it on".
If you get the models and serial and can contact the manufacturer or their representative you might get a wire diagram. Most any package unit would do. As long as you keep the original equipment controls. If you "patch" it up it may be hazardous by not having safety's where it was designed for. Or for instance It may have a anti freeze thermostat. By passing this could lead to coil freeze up and compressor damage. Leaving out a pressure switch (if any) may do the same or could become dangerous to people in the event of fan motor failure. A low temperature fan speed switch may not be needed now unless you plan to run the AC in below 55'f.
And a few dozen other factors that might need to be considered.
If you feel confident after this then contact carrier.
Please rate me as high as you can and thanks for using fixya.
Posted on May 19, 2009
shastalaker7
  • 1515 Answers
SOURCE: Armstrong Heat pump Package Unit, Model#1B36DA-9B,
Hi, the outdoor unit will start to freeze when it is cold outside, but also it should go into a defrost mode to melt this ice either by the defrost board or defrost thermostat. You will know as steam will rise like smoke and some folks think it is on fire. If it never goes into defrost, get back to us and we can go through some things to check. Merry Christmas,
Shastalaker7
Posted on Dec 24, 2009
Need a wiring diagram for and armstrong SCU10A30A-3A AC unit specifically from the control board to the out side unit. not 24V to the contactors
Looks like all you have from inside unit to outside unit is the hot and common for the compressor contactor. What seems to be the problem?
Apr 12, 2017 | Heating & Cooling
I WOULD LIKE TO KNOW WHAT TONNAGE IS FOR MY ARMSTRONG AC UNIT. THE MODEL NUMBER IS SCU10A42A-2A
If you look in the manual it will give you the BTU, simply divide that number by 12,000. Example: 24000 BTU = 2 Ton.
Aug 10, 2014 | Heating & Cooling
I have an Armstrong package unit gas heat and air unit and the fan started blowing all the time and it will not shut off
Does your heater work otherwise or is it just the blower going non stop? I have worked on a few armstrong brands but they weren't a big seller in this area. However general electric units had a fuseible link located close to burner compartment. This link looks some what like a resistor without the strips. If you can locate it,bare a small section of wire on either side of it and test for continuity with an ohm meter. If it showes an open circuit,temporairly put jumper wire across it. If this shuts off your blower replace link and look for any other problems you might have. I have replaced several of these that apparently got to hot and opened. This may not be your problem but when I saw your question this was one of the first things that came to mind. I hope this helps you. Thanks
Nov 23, 2010 | Heating & Cooling
Out door unit on a armstrong heat pump will not come on unit # SHP10B30A-2A using the thermostat, unit will come on by pressing in on the contactor.
Hello
Have a look at the low volatage tranformer,should show 115 volts in and 24 volts out,when unit is calling for ac.There may be a small overload button on the side of the transformer,check that its pushed in.
You need low voltage to pull in the contactor.
Jun 06, 2010 | Heating & Cooling
Model MES5770AAB Serial 11517659WK The single element, 700 watts came with a wiring kit for a new connections. My range has "Old connection type 1" . the moddification kit (A-30001, Revision 4) shows...
Ten to one the elements will have to be changed also. Call or email Maytag about your dilema. You can simply reject to pay me also on this one
Jan 21, 2010 | Maytag Kitchen Ranges
Shastalaker7
Dec 24, 2009 | Heating & Cooling
Looking for elec. wiring diagram Armstrong unit pge10a42d100a-3a
Google Lenox and you will get armstrong also. The have tech site for diagrams and instructions.
Nov 28, 2009 | Heating & Cooling
No heat need a wireing diagram 1997 package unit
impossible to get wiring diagram without model or manufacturer
Nov 21, 2009 | Heating & Cooling
We have an armstrong 125GRTC601a-2a package unit. The burners have rusted out. We are trying to find replacement burners. Do you know how or where we can purchase these burners. We have contacted...
did you check the heat exchanger? If the burners rusted out you may have holes in it and could get CO in the building. You might be replacing this unit.
Aug 05, 2009 | Heating & Cooling
Heating & Cooling Logo
133 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
