Hi, My Xerox Phaser 8560 is showing the fault code: 07,009.42:47536. What does this mean and what's the remedy? Thanks!
  • waverley220 Nov 13, 2010
    Thanks for the suggestion. Unfortunately that didn't work. The same error code is on the screen and the light on the front is blinking red, yellow and green.
    Jan
    The power off solution didn't work. What's the next solution?
    Thanks!
Check your wiper belt system and clutch. Replace the bad process motor and change both camshafts
Posted on Nov 14, 2010
  • 340 Answers
Turn the printer off. Wait until there are no more noises coming from the printer; in some cases this may take several minutes. Remove the power cord for at least 30 seconds. Plug the power cord back in and then turn the printer on.
This will reset/power cycle the printer and should take care of the error code for you. If you do the listed steps and are still receiving an error message please comment back and we will go to the next step
Posted on Nov 13, 2010
Error message on xerox 8560 09,038.46:13269
Go to the Xerox.com website and follow the troubleshooting aid to these types of faults.
Good luck.
Feb 26, 2015 | Xerox Phaser 8560/YN Printer
Xerox Phaser 8560
Please take a look at this solution for the Fault code 09,035.43 and see if any of the solutions will help you. If this does not help, please consider contacting your support centre for further assistance.
For more help visit cbrtechsolutions
May 07, 2014 | Xerox Office Equipment & Supplies
On the 8560, what does the error code 07,010.43:14070 mean??
In the Xerox support website that error indicates that the printer needs to be turned off and call for xerox assistance. Does not specify the problem.
Although, this website refers to this problem.
http://www.fortwayneprinterrepair.com/wordpress/2011/09/25/xerox-phaser-8400-8500-8550-8560-07010-43-error-message/
If the printer has only one year old, the best solution will be to call for xerox assistance because it is under warranty.... I think...
Aug 08, 2012 | Xerox Phaser 8560MFP Laser Printer
Xerox error code 09,038.46:350??
Hi. The error code you are referencing is referring to Black Ink Stick Count Failure.
  1. Make sure you are using Phaser 8500 ink sticks
  2. Make sure the ink sticks slide properly
  3. Remove any broken or partial ink sticks from the ink-loading bin
If the fault code is still displayed you will need to contact support to schedule a service call.
Please check out the online support at www.xerox.com\support
Oct 24, 2009 | Xerox Phaser 8500/DN Printer
Phaser 8560 error code
Most likely you are using generic ink or ink not made for that specific machine. The black ink is the one causing the problem. the printer will then need to be reset.
Apr 15, 2009 | Xerox Phaser 8500/DN Printer
Xerox 8560 37X Fault code
either the paper pulling gears are not spinning properly or they are craked or getting blocked by any dust particles.
or the fuser unit in the copier is not getting properly heated up.fuser unit has to be checked first before replacing and the printer /copier needs to be opened to check the fuser unit.
Feb 26, 2009 | Xerox Phaser 850DP Thermal Printer
Install wiper on xerox 8560 dn
The user guide is available here http://www.support.xerox.com/go/results.asp?Xtype=docs&prodID=8560&Xlang=en_US&Xcntry=USA&prodName=Phaser%208560
Also, I think there are two wiper blades on the 8560, one is on the maintance kit and the other is supposed to be removed, that was the old 860 that could remove theirs. Perhaps cleaning it will be fine. just open the top of the machine and its right there, give it a wipe and it should be fine. The other wiper blade on the maintanance kit and here is a link below to show you how to clean it!
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=355,E=0000000001343253407,K=1300,Sxi=12,Case=obj(902)
You can use this site to troubleshoot any problems with Xerox printers.
Niallbt
Feb 17, 2009 | Xerox Phaser 8500/DN Printer
k24674
jasbo
jasbo
