Question about Sony Playstation 3 (PS3) Console
My ps3 60gb hs yellow light for a few secs then flashes re constantly. please help
  • 40 Answers
Send t to sony
Posted on Nov 13, 2010
Yellow light constantly flashes on all handsets
Yellow light constantly blinks on top of all the cordless phones
www.faqqq.com/.../yellow-light-constantly-blinks-on-top-of-all-the-cord...
Question Product: Panasonic KX-TG5432 Digital Dual Cordless Telephone Question Details: Yellow light constantly blinks on top of all the cordless phones The.
Panasonic KX-TGP550 Normal Status Lights
www.statuslights.com/panasonic/panasonic-kx-tgp550.html
Red (Rapidly Flashing), The Base Unit is paging handsets. (KX-TGP-500 only). Amber(Solid), The Base Unit's IP address may conflict with the IP addresses of ..
Jan 16, 2016 | Panasonic KX-TG7641M KX TG7641M KXTG7641M...
We've got a 60G PS3, today whilst my son was playing on it, it hs shut off completely. Cannot be turned back on, displaying a flashing red light. I thought it may have overheated; so we left it for an...
Sorry, but you have the yellow light of death. This is not fixable using ordinary household equipment. Call sony, yellow light normally means catastrophic hardware failure.
Feb 25, 2011 | Sony Playstation 3 (PS3) Console
My handset is displaying register HS. kindly provide me the required support to reslove the problem.
Please follow this procedure to register your handset
1. On the base station: press and hold the registration/paging key for min. 3 sec.
2. On the handset: within 60 sec. of pressing the registration/paging key;
Select MENU then Settings then OK then Handset then OK - Register HS then OK -
Enter the system PIN of the base station (the default PIN is 0000). Then press OK.
Registering now flashes in the display.
Registration takes approx. 1 minute to complete.
Thanks for using FixYa. Please do leave a vote for the help.
Nov 25, 2010 | Siemens Gigaset A490 Twin Cordless Phone
As the battery properly charged hs 2800, two LEDs flash yellow when I turn it on.
You can visit this website to find answers on what the flashing trouble indicator lights mean: http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Locate the page that has the controller used on your power chair/scooter and count how many lights are flashing to diagnose the trouble. If your insurance purchased the power chair for you, they may also cover the repairs; contact them for information.
Oct 12, 2010 | Ctm HS-2800 Power Wheelchair
Tv will not power up
yellow flashing power light codes: flashes 1 every 5 secs = one of 3 fans not spinning. 2 every 5 secs.= lamp cover open.
5,6,7,8,9,or10 x per 5 secs. are power supply voltage errors.
Apr 10, 2010 | Panasonic PT-50LC13 50" Rear Projection...
The red standby light flashes constantly, we are unable to use set. We have been told to unplug all connection to the set, leave for one hour then restart, we have done this, ITS JUST THE...
You have tried the first thing I would suggest. Next count the number of times the light flashes. It should flash in a pattern approximately one sec apart, then pause 3 seconds and start the same sequence over. The number of blinks will help narrow down the area of the problem. I suspect it is either in the HV section or the power supply. Have you had a power bump recently? Lightning strike? Anyone else in the neighborhood have trouble? Find out the additional information and get back to me and I will try to help you out.
hardrocko
Feb 01, 2010 | Philips 32PFL5403D/27 32 in. LCD TV
Hello have a HS2800 the two yellow lights are flashing....and I found a wire with a fuse in it and can find where it plugs into...can anyone help
The wire inside the cowl is an auxillary power supply connection for attaching a lighting system to the powerchair. It has 24VDC available, and it does not connect to anything for normal operation of the chair.
The lights flashing constantly indicate that the joystick is out of position, or you are in neutral, or the chair is plugged into the charger, if it is a constant flash. Take it off the charger, place it in drive and keep hands off the joystick and restart. If it is still flashing, try a restart, then immediately press the "horn" button twice. If still no-go, you'll need a tech to look at it as the controller may be bad, or the joystick.
If it is a patterned flash, like 4 times flash, pause, repeat, then the onboard computer has found a fault. The number of flashes specify the fault, (right motor, left brake, etc.) go to the CTM website here to download the owners manual which show the flash codes. http://www.ctmhomecare.com/About_Us/index.asp?tStyle=01
Sep 17, 2009 | Ctm HS-2800 Power Wheelchair
CTM HS 2800 2 yellow lights flashing after new batteries install
As her to explan to you how she recharges the batteries and how often she recharges the batteris, make sure she is following the owners manual. http://www.ctmhomecare.com/PDF/Owner_Manual/User%20Manual-2800%202800.pdf Explan to her the batteries can NOT Overcharge, Also trace the wiring for breaks or disconnections.
Sep 04, 2009 | Ctm HS-2800 Power Wheelchair
Samsung aircon turns in 5 sec. lights green/yellow flashing
check capacitor on outside unit,or gas is leaking.
try to reset(small black button in inside unit under the cover)
Feb 11, 2009 | Samsung Heating & Cooling
Sony Playstation 3 (PS3) Console Logo
64 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
