Question about SanDisk Sansa Fuze MP3 Player
DOES NOT PLAY. IS THERE ANY BATTERIES TO REPLACE?
  • mjatwood Nov 13, 2010
    it is compleely dead. it has been dead for more than a month. i am trying to fix it or determine if i should junk it
    it is completely dead. it has been dead for over a month. I am trying to fix it or junk it
  • 10,515 Answers
Is it completely dead or it's freezing ?
Kindly explain the problem in detail. What happened and what were the procedures you took to fix this....
Thanks!!
Posted on Nov 13, 2010
  • taran_2005
    taran_2005 Nov 13, 2010
    Thanks for your response!!
    If it is dead, try one trick - Press the Menu/Power button for 30 seconds and see, if that helps.
    Let me know,so that we could proceed.
    Hope i helped you.
    Thanks for using ' Fixya ' and have a nice day!!
HAVE LOADED CD, PRESS PLAY BUT GET ONLY A WHIRRING NOISE THEN Er WITH BATTERY ICON ON DISPLAY BUTTON - HOW DO I GET THE CD TO PLAY?
Normally a battery icon on a display indicates that the battery power is too low to operate the device. If the device uses disposable batteries, it's time to replace them with fresh ones. If it uses rechargeable batteries, recharge them. If recharging the batteries fails to work, they may have reached their useful lifetime and need to be replaced as well. If the unit has a internal battery that is chargeable, and charging fails to work, you may need to have the unit serviced to replace the internal battery(ies) or just get a new unit, depending on the cost-effectiveness of repairs.
May 25, 2016 | GPX PC101B Portable Compact CD Player
How do i use the memory function on my ibm wheelwriter 6?
Before we start turn it on after it completes is power on just the #1 light should be lit this says the batteries are OK. If they flash replace the batteries and clean the holder.
To store hold the store key while entering an address 1 - 99, type info then press store again.
To play press play with the address.
DickyO
Oct 07, 2014 | IBM Wheelwriter 6 Typewriter
I have a problem with the hands on Buzz. The hands were moving fast, but all of a sudden it moved slow. How can I make the hands move fast?
To make the arms move faster, remove all the batteries and the batteries on the remote control.
Buy brand new batteries and insert them in. Turn buzz to TRY ME on his back. Stand him up and turn him OFF for 5 seconds. Then turn him to PLAY and the arm will move faster.
/uploads/images/8_4_2014_7_01_51_pm.jpg
Jul 05, 2014 | Disney Pre-Order Ultimate Programmable...
My Wii says it s batery is low. How do i charge it?
If you have the type of controller that has rechargable batteries, then just recharge them. If not, then just replace the batteries. You will have to take the rubber sleave off if you have one, to access the battery compartment. Then just replace the "AA" batteries in it. ^^ Good luck.
Apr 05, 2013 | Nintendo Wii Console
Remote for philips model dvp 3050v/37 won't work
Remove old batteries and clean battery terminals with rubbing alcohol, allow seveal minutes to dry and replace the batteries with new ones.
Mar 07, 2012 | Televison & Video
How do you re-print on an IBM Wheelwriter 6?
First be sure the batteries are good, when you power up it does the routine the only light lit should be "1". if not replace the batteries and clean the contacts in the holder.
There are 3 keys on the L. dide of the keyboard store, play and del.
To store hold the store while selecting an address 01 - 99, release the store key, type info, press store again. To play press play and the address, del works the same way.
If the batteries are bad info will be lost when turned off.
DickyO
Feb 03, 2010 | Lexmark Wheelwriter 10 Series II...
Will only take pictures....won't let me use video, picture editor, games or access memory.
HI,
Here are some steps to solve your issue:
1. Press the Reset Button with a paper clip. This should reset your camera and should wok fine..
If this does not solve the problem, please continue the following steps:
1. Please make sure the camera is OFF.
2. Interrupt the power supply by removing the batteries.
3. Let the camera sit for a few minutes without batteries, then replace the batteries and press the Reset Button again.
4. Turn the unit ON. The unit should now be ready to play again.
5. If the unit still does not work, replace the batteries with an entire set of new batteries.
Please leave me comment, if you need further assistance
RNJ VINODKUMAR
Oct 06, 2009 | Vtech Kidizoom Digital Camera
Acts weird when turn on and it won't take pictures just will let me play back
yep ...most of them do that when the batteries are almost empty ...and have anough power just to turn on the play-back ...but not the actual function of the camera ...try to recharge well the batteries..or replace them with normal alkaline ones...
Jul 18, 2009 | Olympus FE-340 Digital Camera
Where does battery go
the batteries go under the orange play tray, it just lifts out n u will c battery compartment.
Apr 06, 2009 | Chicco 4 In 1 Ride On Car By
SanDisk Sansa Fuze MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
