Question about Cell Phones
Manual for kitmobile easy talk bluetooth car kit
Connect new phone to device via bluetooth
Posted on Jan 31, 2011
Tip
Jabra Bluetooth Headset Pairing Instructions
<span><span>Connecting a Bluetooth headset or car kit</span> <span> You can listen to music over a Bluetooth stereo headset, or have hands-free conversations using a compatible Bluetooth headset or car kit. It's the same procedure to set up stereo audio and hands-free. <ul> <li>For you to listen to music with your headset or car kit, the headset or car kit must support the A2DP Bluetooth profile. </li> <li>Before you connect your headset, you need to make it discoverable so your phone can find it. You can find out how to do this by referring to your headset manual. </li></ul> <ol> <li> <span>From the Home screen, press <span>MENU</span>, and then tap <span><span>Settings</span> &gt; <span>Wireless & networks</span></span>. </span> </li> <li> <span>Tap <span>Bluetooth settings</span>. </span> </li> <li> <span>If the <span>Bluetooth</span> check box is not selected, select it to turn Bluetooth on. </span> </li> <li> <span>Make sure that the headset is discoverable. </span> </li> <li> <span>Tap <span>Scan for devices</span>. </span> Your phone will start to scan for Bluetooth devices within range. </li> <li> <span>When you see the name of your headset displayed in the <span>Bluetooth devices </span>section, tap the name. </span> Your phone then automatically tries to pair with the headset. </li> <li> <span>If automatic pairing fails, enter the passcode supplied with your headset. </span> </li></ol> The pairing and connection status is displayed below the hands-free headset or car kit name in the <span>Bluetooth devices</span> section. When the Bluetooth headset or car kit is connected to your phone, the Bluetooth connected icon is displayed in the status bar. Depending on the type of headset or car kit you have connected, you can then start using the headset or car kit to listen to music and/or make and receive phone calls. </span></span>
on May 23, 2011 | Cell Phones
Cant get phone to connect to kitmobile
please can you describe more your problem like what is your mobile and cable reference, kit mobile version.
Jun 19, 2012 | Cell Phones
Have lost the manual to bluetrek and have an iphone 3 now and need to get the bluetooth working with this new phone
First, here is the link to the manual:
http://www.bluetrek.com/getfile.php?source=/download/product_download-manual63.pdf&filename=CompactClassic+Manual%2C+English&file_extension=pdf
Here are the instruction: 1. Switch on your Bluetrek and press and hold Talk button and Vol+ button for about five seconds untill indicator light flashes red and blue alternatively and you will hear a sound from speaker.
2. Open bluetooth in Iphone 3 search for bluetooth device. You will see Bluetrek Compact Classic. Click on name to pair and enter "0000" as pin code.
Bluetrek will be connected to iPhone.
Jun 02, 2011 | BlueTrek Compact Classic Ultra Slim...
How do i pair my jabra bt250 to my htc desire hd
Connecting a Bluetooth headset or car kit You can listen to music over a Bluetooth stereo headset, or have hands-free conversations using a compatible Bluetooth headset or car kit. It's the same procedure to set up stereo audio and hands-free.
  • For you to listen to music with your headset or car kit, the headset or car kit must support the A2DP Bluetooth profile.
  • Before you connect your headset, you need to make it discoverable so your phone can find it. You can find out how to do this by referring to your headset manual.
  1. From the Home screen, press MENU, and then tap Settings > Wireless & networks.
  2. Tap Bluetooth settings.
  3. If the Bluetooth check box is not selected, select it to turn Bluetooth on.
  4. Make sure that the headset is discoverable.
  5. Tap Scan for devices. Your phone will start to scan for Bluetooth devices within range.
  6. When you see the name of your headset displayed in the Bluetooth devices section, tap the name. Your phone then automatically tries to pair with the headset.
  7. If automatic pairing fails, enter the passcode supplied with your headset.
The pairing and connection status is displayed below the hands-free headset or car kit name in the Bluetooth devices section. When the Bluetooth headset or car kit is connected to your phone, the Bluetooth connected icon howtoimage.aspx?id=12046 is displayed in the status bar. Depending on the type of headset or car kit you have connected, you can then start using the headset or car kit to listen to music and/or make and receive phone calls.
May 23, 2011 | Jabra BT250 Consumer Headset
I don't have the manual anymore and I forget how to pair the blue trek car kit with my phone. Please help!
Try this:
1. Put them close together
2. Switch on phone and select bluetooth discover mode (make sure it's visible to other devices)
3. Switch your BlueTrek device. Press and hold both Talk and Vol+ button for about 5 seconds until the indicator light flashes red and blue alternatively and sound can be heard from the speaker.
4. The phone should then detect the Bluetrek device. Follow the instructions from the phone to accept the pairing request. If you didn't change it, the PIN code should be 0000 (zeroes).
Hope this helps.
May 04, 2011 | BlueTrek Surface sound Duo Bluetooth Car...
Lost my instruction manual
Hi
Thanks for using FixYa. You can free download the User Manual for your Samsung J700 Cellular Phone from the link---
User Manual Samsung J700 Cellular Phone
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Oct 15, 2009 | Samsung J700 Cellular Phone
Need to delete paired phones from Motorola IHF1000 car kit
Hit the talk button. Say Setup Menu. Then Say Remove Phone (phone # you want to remove). Alternately, say "remove all phones", then re-pair just the ones you want.
Manual : http://www.motorola.com/Hellomoto/Master%20Lists/Product%20Manuals/Static%20Files/US-EN/User_Guide.pdf
Jul 14, 2009 | Motorola Mobility Blnc Bluetooth Car Kit...
Cell Phones Logo
3,251 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
