Question about Hotpoint 24 in. FDW60 Free-standing Dishwasher
Hotpoint DW62 dishwasher
I have two small white plastic clips from the fron door cover and I don't know where to put them back. Any ideas?
I didn't bother putting them back. They are just there to stop the front door vibrating. They made no difference if there or not.
Posted on Jun 19, 2008
Hello there, I have a Bosch Logixx dishwasher which I purchased just over 2 years ago. My upper dishwasher tray is not fitting properly into the hose pipe holes on the inside of the back wall of the...
Hello Deepak,
You can definitely fix this yourself, but I'm not entirely sure from your description which part is "dropping off". It may be a simple fix where something needs to be clipped back into place or you may need to replace something. Please can you take a look at the images below and identify which part you are having trouble with.
Below is the back of the upper spray arm which clips on to the upper rack. It has a grey plastic cover behind which is a large white plastic washer / gasket. The washer simply slots in to the back of the spray arm and the grey cover clips in over the top.
Your description suggests the grey plastic cover and/or the white washer are dropping off. If the grey plastic cover is missing, it may have fallen into the bottom of the washer under the lower rack, in which case you should be able to find it and clip it back on. If it's missing or wont clip back on, you will need to replace the upper spray arm as the cover and washer are not available separately.
This is the water delivery tube which clips to the back wall of the washing compartment. There is a metal clip which secures the tube to the wall. The open hole and one of the spigots slot in to the two holes in the back of the upper spray arm above. The spigot used depends on which height setting the upper rack is on.
Basically, everything simply clips together. If nothing is broken, you should be able to fix this at no cost by simply clipping the offending part back into place.
Hope this helps. If you need further assistance or help locating replacement parts, please let me know what needs to be replaced. Nearly all Bosch parts are available and in stock direct from Bosch.
Regards,
BElectric
Apr 13, 2011 | Bosch 24 in. SGS69L02 Logixx Built-in...
Dishwasher is beeping every 20 seconds, but not turning on.
There is most likely a problem with one of the door switches. Right where the door latches to the tub there is a small white plunger in the opening of the door which gets pushed down to trip two switches within the door. Disconnect power to the dishwasher and take out the phillips head screws holding the inner and outer door panels together. Check out the plastic cover over the door switches to make sure it has not warped due to heat. The cover is held on by four plastic tabs. The white plunger has a spring on the bottom of it, so watch out for it so you won't lose it. The flat side of the white plunger faces the dishwasher's tub.
Feb 05, 2011 | GE 24 in. Profile PDW7880G Built-in...
I have a frigidaire dishwasher 4000 series aqua surge with speed clean. The small spray arm on the ceiling of the washer came off. I found it sitting on top of some cups in the top basket. There is a...
The top arm snaps into place. Simply unscrew the retaining clip from the ceiling of the washer. Inside of there, you will find a small white plastic clip. Make sure the two prongs are pointed down and poking out through the hole in the bottom of the larger grey clip that you just unscrewed. Then press the prongs on the white clip into the hole on the arm and snap it back together. Then you can screw the assembly back into the ceiling of the washer.
If this problem persists, you will likely need to replace the white plastic clip. (which is where I am at right now with my washer).
Dec 01, 2010 | Frigidaire PLD4555RFC Dishwasher
How do I clean the filter on my Hotpoint First Edition FEW12? Do I have to take off the whole big black pipe at the back, under the drum? There is no filter at the fron
Yes, remove lower rear cover.
Remove large black hose from bottom of drum.
Clean the filter inside the hose.
Please rate my solution.
Thanks.
Nov 14, 2009 | Hotpoint First Edition FEW12 Front Load...
Dishwasher will not drain all the water out
If this is a GE or Hotpoint dishwasher the solution is fairly easy, but a pain. GE (Hotpoint is the same company) has been using a small plastic ball that prevents backflow of the water. A lot of times that ball migrates and doesn't allow the dishwasher to drain. To get to this, you need to remove the two 1/4 inch hex head screws in the food trap basket, the 1/4 inch hex head screw from the spray arm, and use a small screwdriver to pry a clip at the back of the spray arm up to remove the spray arm assembly. Siphon as much water from the dishwasher as possible because you'll be opening up the plumbing below. Turn off your electricity to the dishwasher and pull it out of the cavity. Directly behind the motor is a large manilla-colored "tank" with a large hoseclamp holding a white union with two smaller hoses coming off it. Loosen and remove the white union from the large tank and the ball should fall out. Replace the white union, tightening the hose clamp and drop the ball back into the tube on the left side of the food trap basket. Put it back together and test run.
Sep 10, 2009 | Dishwashers
Hotpoint washer not rinsing
If it is at the rinse or spin cycle it could be something trapped in the pump, for the water can't drain quickly enough when the machine starts to spin & the water gets forced back up through the soap dispenser as there is nowhere else for it to go. Check your filter too.
The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. In side is a white molded cone and a big white ball which floats in side. You will find a lot of junk here, clean out. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the gator to the pump unit and tighten the plastic clip.
Apr 01, 2009 | Hotpoint Aquarius WF000 Front Load Washer
On my Hotpoint Aquarius WF000 1000 spin there are two lights flashing, one of them is the Time Delay ligh and the other is the Crease Reduction light, does anyone know why this might be occuring?
Try this out, it's for another hotpoint model:
The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. In side is a white molded cone and a big white ball which floats in side. You will find a lot of junk here, clean out. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the gator to the pump unit and tighten the plastic clip. Would be good to check out the pump too
Mar 28, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Dishwasher not filling
there is a small float and micro switch behind the LHS cover which if activated will stop the water flow. you will need to remove the top cover(dont forget to unplug from the mains first !). then remove the side cover, you should find a clear plastic unit with a red float in side this maybe gumed up with scale. if so you should clean to allow the float to be free. this float activates a micro switch via a red arm. if this switch is stuck in this will stop the water flow. or the switch maybe faulty.
May 31, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint wd63
take door off. outer porthole is just clipped into frame. gently prize out with a small screwdriver
Mar 04, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint 24 in. FDW60 Free-standing Dishwasher Logo
76 people viewed this question
Top Hotpoint Dishwashers Experts
Mike Cairns
Mike Cairns
bosch5
AcmeUK
Level 1 Expert
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
