Question about Toshiba Televison & Video
WHEN THE TELEVISION IS ON THERE IS SOUND BUT NO PICTURE OR THE PICTURE COMES ON AND QUICKLY GOES OFF LEAVING NOTHING BUTSOUND
    Top Expert:
  • Toshiba Master
  • 75,404 Answers
Hello
What is the model number of your Toshiba TV? you haven't mentioned about that.
Posted on Nov 14, 2010
TV picture goes out after 10 minutes of viewing with popping sound
It can be a couple things. Something bad on the power board. Or the vertical output circuit. How long ago did you purchase the television. Your best course of action is to have it serviced.
If you need any information or other assistance let me know.
Thanks,
Lee
Jun 24, 2008 | Pioneer SD-582HD5 58" Rear Projection...
Lcd32880hdf 10 months old. When switched on the picture disappears after 2/3 seconds and will not come back on. Sound still remains un-effected.??
If you can quickly get to menu before picture goes blank, then go picture / backlight / set backlight to minimum and it will work fine.
Jul 04, 2010 | Albatron LNX-21TIS-3 Television
Tv goes black
sounds like the flyback needs to be resoldered
Apr 13, 2010 | RCA HD52W59 HDTV Projection Television
Set will not turn on. After you press on/off button red led light comes on briefly and quickly goes off. No sound or picture comes on.
the convergance amp ic;s have failed and need to be replaced along with the 2 burnt resistors not a bad job about 250 cost
Dec 01, 2009 | Hitachi 57TWX20B 57" Rear Projection...
Sony kv35s66: No picture, just sound and red blinking
This should be a quick fix. Try resoldering the vertical IC. This is a small flat IC attached to a heat sink with about 11 pins. It should be marked LA7837 or something similar. That should resolve the problem.
Keep us posted.
Dan
Sep 08, 2008 | Televison & Video
Picture/sound goes out after 10 minutes of TV use
Rear projection hdtv, most likely damaged tubes. Don't repair this by your self get a tv repair man to do it before you injure your self.
The most common problem (I have fixed lots) is the Vertical amplifier has developed a loose connection. It probably just needs resoldering. As things expand it makes and looses connection you picture goes in and out. The vertical chip is a large black chip that gets hot, over time it degrades the solder until a connection is damaged. Most newer sets have a protection circuit that senses the lack of height, and shuts down the picture tube to save it. When the picture dropped to a line on older TVs and left that way too long it would burn a line into the face of the picture tube. You then had to have the picture tube replaced along with the vertical amp. it's kinda like a screensaver for your TV.
Nov 21, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No picture just comes sound
sounds like the Backlight has failed, if you look closely at the screen you should be able to see the image changing, but as there is no back light there is no luminescense so it will appear black or grey, It is probably the backlight inverter or element that has failed, if this is within warrany organise with them to fix it for free,
Dec 22, 2006 | Philips 42PF7320 42 in. EDTV-Ready Plasma...
Open Questions:
I was given a 2007 Toshiba Regza LED television ( I believe it to be LED just because of the Year 2007.) I have the television plugged into the wall standing alone with nothing connected to it no wires no cable boxes nothing. When I push the power button on the side it goes on because the green light is on the bottom it's not flashing but it is on okay. Now what's happening is I'm not getting any picture and I went on to shop Jimmy's and they recommended that I contact you. The back lights are on as I can see through the slots on the back of the television that there is light coming from there. The thing I'm trying to find out if I did the flashlight cuz I couldn't see any picture whatsoever and I don't know I turn the volume up as much as I possibly could through the side and also with the remote. I change the batteries in the remote of course to see make sure that they were working and I shine a flashlight on the screen I could see no picture whatsoever no menu picture no nothing and no sound. So my question is to you, after following shop Jimmy's recommendations it said that if you have your back lights working but you still have no sound or picture then you would need to replace one of two parts or both. I'm not sure what those parts are called I forget but my main question is how much is it to even get those parts and can I still get them. Like is it really worth doing that or should I just go and buy another television. Mind you to see me was given to me at no cost so that is basically the question would it be worth buying those two parts that they recommended and putting them in one at a time or should I just go get a whole new television remember I'm not which call Rich either so... If you could contact me with an answer that would be great please be specific as I am not what you call text Abby okay? I thank you in advance for your time patience and cooperation and helping me to answer this questions. I look forward to hearing from you! Respectfully, Stephanie Whitman PS can this television only be controlled by the remote. There are buttons on the side but to truly get the best quality of the television I would need to use the remote correct?
Jun 14, 2018 | Toshiba Televison & Video
Televison & Video Logo
26 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
