Question about Stoves 720EF Electric Double Oven
My stoves double oven 720EF has stopped working the grill works and the fan turns on when the oven is switched on but there is no heat on either top or bottom oven. Also the clock has stopped working aswell with no digital display. Any advice as to diagnose this problem would be great, i have contacted three repairer's but none have turned up. I have thre hungry children and an angry wife!!!!!!!!!!!!!!!! Help....
Just moved, can not get stoves double oven to work light and fan comes on both ovens but no heat
On the main oven, does the circulating fan at the back of the oven start to rotate when you switch it on and does the fan oven neon illuminate as well.
For the top oven, the heating element is not very big so the oven takes a long time to warm up. Does the top oven neon illuminate when you switch this on as well?
Aug 02, 2011 | Stoves 720EF Electric Double Oven
Model 720EF. Model No 059040415. The grill will not work. The top oven is still working but the grill light or fan will not come on at all. Stoves have told me over the phone that it could be the...
First things first. The top oven lights ONLY come on when the top oven is switched on. Operating the grill DOES NOT turn the lights on. If you wish to see what you are grilling, you have to turn the top oven control knob on to its first position as well as turning the grill on.
Secondly, the grill only works when the door is open. The grill does not work when you shut the door. When you open and shut the door, you should be able to hear the microswitch operating. It is located in the right hand side of the cooker, between the inner and outer panels - you cannot see it. I haven't seen the switch first hand but they normally come with an arm that contacts the door mechanism and the door mechanism operating, causes the arm to move, which causes a button on the switch to move and make the circuit. It has been known for the arm on the microswitch to bend with use so it no longer works correctly.
If you have checked all above and you hear the switch operating, then it could have failed. They are quite common, so if you can't get one from STOVES, try espares or someone like Maplin or RadioSpares.
The get to the microswitch you have to take the oven out of the housing and then take the right hand panel off. You should then be able to see it and check its operation.
All the best
Jul 26, 2011 | Stoves 720EF Electric Double Oven
Hi Guys I have a Stoves 720EF Double Oven and Grill. Whilst halfway through cooking some sausages on the grill this evening, the grill suddenly stopped working (plus the LED for the grill knob showing...
If the element and the indicator light both stopped working this suggests a problem with the power supply for the grill control. Either the grill control has no power going to it or it is faulty and requires replacement. If you are not sure what you are doing you'd better get a tech. to look at it, it can be fairly complicated for the untrained person.
Feb 24, 2011 | Stoves 720EF Electric Double Oven
Stoves 720 EF Electric Double Oven Model No 059040415 -when you turn the grill knob there is no light and it doesn't do anything at all - the grill is not working. However, the element must be working as...
First things first. The oven element is totally separate to the grill element. The clock has to have a time set for either the top or bottom oven to work, whereas the grill will work without the clock being set.
The control knob for the top oven is the ONLY control that will turn the top oven lights on, the grill does not turn the lights on. ( If you want to watch your toast, you have to turn the top oven switch on to the first setting as well as operating the grill control).
To prevent the grill being operated with the door shut, there is a micro-switch on the door hinge that allows the grill to operate ONLY when the door is down. The grill control also does not illuminate unless the door is down. There are two options on the grill control - right or left. One way is the inner element only and the other is both inner and outer ones.
So if you have done all that and it still doesn't work, then the micro-switch could be faulty.
Best of luck
Nov 23, 2010 | Stoves 720EF Electric Double Oven
My stoves 720ef oven keeps cutting out after 20 minutes and will not turn back on, the grill continues to work ok. I know the timer is set to manual so I guess it must be a thermal trip. As I do not have a...
There are seperate thermal (overheat) cutout devices for both the top and bottom ovens. First check to see if the lower oven fan is running ok and is not restricted by grease or fat (there are 4 self tapping screws that hold the fan cover on) and the thermostat is switching off and on as it should. You should also check that the main background cooling fan is running and switches off a few mins after the ovens have turned off. If these check out ok, then it is possibly the lower oven thermal cutout.
Aug 04, 2010 | Stoves 720EF Electric Double Oven
Stoves 720EF - main fan not working
When you say the main fan, do you mean the background cooling fan or do you mean the circulating fan in the bottom oven?
Do you have the handbook for this oven as the wiring diagrams are included in it. If you haven't, you can take a copy from my BT Digital Vault - all I need is an email address to register you.
Looking at the diagram, the power for the cooling fan comes via the timer board. If, as you say, the fan doesn't work at all, the timer board could have gone faulty.
Nov 15, 2009 | Stoves 720EF Electric Double Oven
Oven stopped working halfway through cooking. grill still works but top oven also stopped working
Sounds like to overheat device(s) kicked in. Is the background cooling fan still operating? i.e. that is the fan that continues to run for about 10 mins once everything on the device is switched off.
As well as hearing it, you should be able to feel a gentle draft of air coming out of the gap between the top and bottom doors.
Oct 04, 2009 | Stoves 720EF Electric Double Oven
My stoves 720ef oven goes off if it turned up over 140 deg c also the grill in the top oven does not get red hot
Is the cooling fan running in the oven? Does it also continue to run when the oven controls are turned off to let the oven cool down?
There are ventilation grills below each door on the oven. You can see these when the doors are fully open, just look under each door to see if they are clear and not blocked up.
Jul 21, 2009 | Stoves 720EF Electric Double Oven
I have a stoves 720EF Heritage - electric - the top grill is not working - does it have a reset button?
No, there is no reset button. However, the grill will only work when the front is down as there is a microswitch which operates to provide connectivity when it is in this position. This is to stop the grill overheating. The switch could have gone faulty.
Does the top oven work ok?
When you operate the grill there are two options, part or full. Are they both failing? Does the cooling fan switch on when either grill is operated?
May 05, 2009 | Stoves 720EF Electric Double Oven
Stoves 720ef grill not working
The grills appear to be independant of each other. Does the oven still work and the oven light come on?
Depending on your answer it could be that the Top Oven Switch has gone faulty. The Grill Regulator and the Switch work together on the top oven. To get at both you will need to take the top of the oven off.
Oct 04, 2008 | Stoves 720EF Electric Double Oven
Stoves 720EF Electric Double Oven Logo
717 people viewed this question
Top Stoves Ovens Experts
ashburton
Dan Webster
Dan Webster
Are you a Stoves Oven Expert? Answer questions, earn points and help others
