On my laptop it says no audio output device is installed all of the sudden and i dont no how to fix it when i go to device manager to the sound tab it says error code 10 and wont work
    Genius:
  • 1,542 Answers
Hi
You could try to do a system restore back to when it was ok it normally gives you a few dates but also at the bottom it sometimes gives you options of showing more dates to choose from
good luck
Posted on Nov 13, 2010
No audio output device is installed on my acer aspire 5535 laptop
which operating system ?
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrative tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to
reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have selected the correct speaker settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place icon in taskbar for any
further volume control settings you will need to right click on the speaker volume icon system select adjust volume
click start control panel sounds and audio volume advanced speakers select the appropriate speakers
from the drop down list or navigate to the device manager scroll to system devices + to expand system
speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
IE: motherboard name audio driver you might have to try a few times to get it right
for windows 7
click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to update drivers
click start right click on computer select properties then device manager scroll to sound and video if you right click on sound and video then on high definition audio device select update driver software
click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers
right click on the speaker icon in the bottom taskbar you will see an array of options select
playback devices make sure it has a green tick and the correct speakers are selected
be updated if you computer came with a motherboard disk the drivers could be on it although
once speakers are connected widows 7 should automatically update the drivers
click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker
you might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down
list in the advanced tab select dvd quality or another then apply
hope this helps
Sep 24, 2012 | Acer Aspire 5535-5050 Notebook
A cant get my sound to start it says no audio output device installed so a dont know what to do to fix it
may be you need to install audio driver, check it at device manager
follow this step:
go to device manager, look at device manager, is there any yellow mark (?) or (!)?if yes this mean you need to install audio driver, just insert your motherboard cd driver, then click install audio driver, follow instruction at installation until finish, if installation success at device manager the yellow mark will disappear, the try play sound, for example using windows media player, you will get sound at your speaker
i hope this helpful
thank you for using fixya
Feb 04, 2011 | Foxconn (945G7MA-8KS2) Motherboard
My Toshiba Satellite A135-S2386 laptop all of a sudden says "no audio output device is installed" any help on how to fix this would be appreciated! I have gone to device manager, however states there is...
control panel sounds and audio,audio make necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
good luck
Sep 13, 2010 | Toshiba (4CH-VOUT) Sound Card
How to reset settings on realtek hd audio manager
Hello
OK, all you need to do is to open the Manager from the start tray, once the manager is opened, Click on the speaker tab, and then on the Sound effect tab. You should see something like this now.
Now just click on the reset tabs, this should then reset the manager to it's default settings.
Please let me know if this was helpful. Also,, let me know if you need any further assistance.
Kind regards
Andrea
Sep 08, 2010 | Computers & Internet
Audio device its not installed - computer toshiba U300
Check device manager (right click on my computer, select properties, click the hardware tab and then the device manager button). If the sound card is not listed or has a ? or ! on it, go to toshiba's web site and download the drivers to install.
Hope this helps
May 02, 2009 | Computers & Internet
My laptop's sound is suddenly stopped
Right click on the my computer ICON and choose manage, then brose to device manager and see if the Sound device has a yellow ! over it if so right click on the device and choose update driver, and browse to you driver folder usually c:\ manufactors name \ Drivers\ Audio and then choose .inf file if you don't see one then see if it has a setup.exe and run it. Which should reinstall your sound driver.
Mar 09, 2009 | Lenovo ThinkPad R61 Notebook
Speaker showing No Audio Output device is installed
Try to uninstalled the audio driver.then restart the machine and again install the audio driver.hope this will work for you.
Thanks
Feb 28, 2009 | Toshiba Satellite U305-S2804 Laptop
Solve prob PLZ
go into start, control panel, system management, services. There locate "Windows Audio" and select start on the left side
Sep 22, 2007 | HP Pavilion dv2000t Notebook
No sound
You can try bringing the computer to an earlier point by using a restore point. Make sure that you dont have your audio muted. Go into your device manager and go to sounds and audio devices (xp; its different for vista). If everything is 'drayed out'... go into start/run/ [then type] msconfig Under the tab 'services' look for something that says sound or audio on the far left column. On the far right column make sure it says 'running' if it says 'stoped' thats your problem. If you cant find anything, go to hp.com and download updated drivers.
Sep 20, 2007 | HP Pavilion dv2000t Notebook
Computers & Internet Logo
David Payne
David Payne
