Monitor lines So what should I do then? How do I fix it?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 69 Answers
Next time after doing your work you have to shut down your computer. Or you can setting like this "Display properties">Screen saver> Power>Hibernate>
remove tick mark from "Enable hibernation"
and form Advance tab>power buttons>when i press the power button on my computer> select "Shutdown "
and when i press the sleep button on my computer> select "Stand by"
Posted on Jun 19, 2008
Vertical line in monitor
theres no way to fix vertical line on lcd the only way is to replaced lcd panel with same panel type
Feb 28, 2014 | Philips 17" LCD Monitor
Thin black horizontal lines across bottom of screen
Hi there.
I suggest you see my tip on how to fix the lines on your monitor. The fix for horizontal lines is the same for vertical lines. You can read my tip here: http://www.fixya.com/support/r9352105-fix_colored_vertical_lines_lcd_display
Slasher_X
Jul 20, 2011 | HP w17e Monitor
Ocasionally diagonal lines appear on the monitor or the whole pcu turn off by its self. When thie lines appear the only way to get going again is to manually hit the power button on the tower unit
Hello. Have you tried using this monitor on a different computer? This would help us understand if this is being caused by your computer/video card or the monitor itself is dying and needs to be replaced/fixed.
Jul 18, 2011 | Gateway FPD1760 17" LCD Monitor
Montor has colored lines on left side
Are we talking thin vertical lines that run all the way from the top of the screen to the bottom? If so, this usually indicates a failure of the chip controlling that line of pixels.Unfortunately, there is no easy repair for this and the screen will need to be replaced.
Mar 02, 2011 | Acer FP563 (White) 15" LCD Monitor
Vertical lines on screen , is there a processor driver download to fix this problem
Vertical lines on a screen is not a processor problem, vertical lines is going to be a problem with the monitor or the video card. Try a different known working monitor on your computer and if the lines go away then you know that the original monitor is bad.
If the lines don't go away then try replacing the video card. If you have integrated video then the motherboard would need to be replaced. A processor driver download is not going to fix a vertical line problem.
Aug 08, 2009 | Dell Computers & Internet
Vertical white line near the left end of the screen.
Usually when there are colored lines on the LCD its because the screen is going bad. Quick way to verify this, try a different monitor on your computer and if the line goes away then you know for sure the monitor is bad.
If you try a different monitor and the line remains then you know that the video card is bad.
Jun 03, 2009 | Mitsubishi Power Adapter for DiamondPoint...
On the monitor, only one straight horizontal line display on screen. How to fix it?
Sounds like it's not scanning vertically, probably not worth the money to have a monitor fixed. Time to get an LCD. :-)
Jan 11, 2008 | HP D2835 17 in. CRT Monitor
Monitor problem
It sounds to me like your monitor is going......if the computer itself is functioning fine, and you have even reset the monitor to the default, and still having problems, I would say it's time for a new monitor. You can find reasonable ones on ebay. I got two 19" monitors off of there and I am thrilled with them. Just be sure to check the ratings of the seller before bidding or buying.
Good luck.
Dec 01, 2007 | E-Machines 6809 Notebook
White intermittant horizontal lines
Sure it can be fixed, I think some components on the main board needs resolder on their soldered joints. Try this first before thinkig of getting a new one.
Nov 30, 2007 | Videoseven W17PS 17" LCD Monitor
Computers & Internet Logo
508 people viewed this question
David Payne
David Payne
