Question about AO Smith 1.5 hp Swimming Pool - Jet / Well Pump Motor - / Century B123
I am installing a new pump and motor. the motor is 110/220 optional. I am 220. The connectors are A, B, L1 and L2. What goes where for 220. Thanks
  • 310 Answers
There is always a wiring diagram on the side of the motor. If you want help with this one still, you would have to list here the exact model of pump, and the model of the motor connected to it.
Most common connections are to run one hot line to L1 and one hot line to L2.
You would want to confirm this on the motor housing though as some motors are different than others.
Posted on Nov 15, 2010
A.O. Smith 1/4 hp 115v red black blue and white
Not sure what wires you are talking about. Normally on a 115volt motor you will have L1 and L2 and a green ground screw. Black or red goes to L1 and L2 (either one). White goes to either L1 or L2 (either one) and the green ground to the green ground screw. These would be the incoming voltage wires.
Sep 13, 2014 | Pool & Spa
How to wire this PS4060 correctly ?
You should have 4 terminals and 2 green grounding screws. 2 terminals are marked Line or L1 and L2 etc, the black from the power supply goes to L1 and the white to L2. Other 2 terminals are marked Motor or M1 and M2 etc. Balck from motor goes on M1 and White on M2, The ground wires from both cables go one to each green screw.
Jul 20, 2014 | Water Source 40/60 Pressure Switch PS4060
Does the Red wire connect to the L1 or L2 Screw
when hooking up a pump on 220v, there are two hot wires. it doesnt matter which hot wire goes where. both L1 and L2 are power terminals
Apr 28, 2014 | Zodiac Jandy 2Hp Flopro Pool Pump For...
Proper wire hook up
black goes to L1 white goes to L2 make sure to look on side of motor to change from 220 volt to 110 volt either a knob or changing wires brown and white to different locations hope you didnt fry motor
Jul 26, 2013 | AO Smith 1.5 hp 3450rpm 48Y Frame 115/230...
I am trying to wire a dayton booster pump. it shows a L1 and L2 connection on the 115v connection. L1 goes to P1 L2 goes to T4. on the 220v connection it shows L1 and L2. L1 goes to wire P1 and L2 goes...
The power cord has a green ground wire; two hot wires, which are black and red; and a white neutral wire. Attach the neutral to the middle connector and the two hot wires to either end of the terminal.
In order to safely ground the machine the green ground wire must be securely connected to the dryer frame. There may be a screw on the frame where you can attach the ground
Jul 17, 2011 | Kitchen Ranges
Wiring new motor
The L1 and L2 are the load terminals. Connect the black wires to the L1 and L2 and the green one to the green colored screw.
May 14, 2010 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
I installed a new pump, motor and timer, but the
Be sure you are actually one the L1 and L2 posts and/or screws. On some of the motors there is a third quick connect tab that is not used when set for 230V lines but if you connect one of your incoming line leads to it the motor wont work. If that is not the case, be sure you have a resistance reading somewhere close to 1 ohm across the L1 & L2 terminals. If you get infinite, there is a problem with the motor. I assume the motor is completely silent when you turn on the switch? If not and it is humming but not starting, have the capacitor checked and if necessary, the motor start switch and winding.
Oct 30, 2009 | Hayward 2HP Pool Pump Motor A O Smith...
AO Smith 1.5 hp Swimming Pool - Jet / Well Pump Motor -  / Century B123 Logo
309 people viewed this question
Top AO Smith Pool & Spa Experts
Jay Finke
Jay Finke
Steve
Colin Stickland
Colin Stickland
Are you an AO Smith Pool and Spa Expert? Answer questions, earn points and help others
