Question about Sony VAIO VGC-RB40 PC Desktop
Hard drive makes clicking sound and than memory dump begins Help
    Guru:
  • 1,705 Answers
Sounds like the hard drive is on its way out.
If you can get hold of, or download and burn a copy of
A) Ultimate boot CD for windows
or
B) Ubuntu.
These can boot your PC without invoking your HDD, you may be able to access backup/cop your data across to a second or external HDD before it dies.
Posted on Nov 13, 2010
What does it mean when everytime I try to change the song on my mp3 player, It shuts off automatically and than turns on again. It cotinues todo this everytime.
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to fail to detect a hard drive continue on a cycle or to shutdown
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA and
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
or it my be a memory dump fault
memory dump click start right click on my computer,properties advanced scroll down to system and recovery open settings write and debugging information the drop down button select none
hope this helps
hope this helps
Dec 25, 2010 | Mach Speed Eclipse 180SL 4GB MP4 ...
Laptop shuts down begining dump of memory runs check disk
Your hard disk has developed errors.
This might be caused due to damaged files on your hard disk, or a program you recently installed which may have some errors.
If you recently installed a program, that does not work well with your computer, you might consider uninstalling it.
You should also consider performing a disk defragmentation to reorganize file on your computer.
To perform disk defragmentation, go to your "My Computer"
Select your Local Disk drive, then right click and select Properties.
Click on the "Tools" tab, then click on "Defragment Now"
After that, select the Local Disk C drive, then click on Defragment.
Thank you for using Fixya,
Kenneth
Feb 15, 2010 | IBM ThinkPad T30 2366 Notebook
When i turn it on i am asked to select one of two choices of operating systems(windows NT workstation version 4.0, or windows workstation version 4.0[VGA mode]) which one should i choose? whichever one i...
Hello!
Yours problem can be system, or hardware.
First try in bios disable integrated pheriperals, like modem, lan, sound, and try boot.
If the trouble still here, try install new system with full format hard drive.
If you still have a problem, you have some hardware problem,something like procesor heathing.
Nov 02, 2009 | Compaq Armada 1700 Notebook
Beginning dump of physical memory
This could be pretty complex. The ATAPI.SYS file controls the Hard Drive and CD-Rom Drive. I would recommend reading this MS TechNet article:
http://support.microsoft.com/kb/822051/ The article says that it's not uncommon for the problem to be caused by faulty memory or by problems in the mass storage controller subsystem, which makes sense since atapi.sys (a mass storage controller system file) is noted.
If you have multiple memory cards in the machine, it might not be a bad idea to take one out and try again. If the fails, keep swapping out memory cards until we either solve the problem, or elimite that as a cause.
Apr 21, 2009 | Computers & Internet
Windows program shut down Laptop problem model-no-XPS M1530
As with any blue screen, this is an operating system error in which a driver or program has overstepped it's boundries by writing into an unauthorized section of the memroy, therefore causing the memory dump. You will need to run a system repiar or reload with your recovery disc or operating system disc in order to cure the problem. Start with the repair, if the rogue still persists, then you will need to wipe the hard drive and reload the operating system.
Jul 13, 2008 | Dell Inspiron 6000 Notebook
Memory dump
Make sure your computer meets the minimum system requirements for running Windows XP if this is an upgrade - I had a computer that technically met the requirements, but boy did it run slow after I upgraded from Windows ME to Windows XP. If your hard drive contains no programs, information that you can live without, then you can completely reformat the hard drive and start over from scratch. If it does contain important programs, burn them to CD or DVD - and make sure that your computer can read the files after you are done burning - and then reformat your hard drive.
Mar 07, 2008 | Microsoft Windows XP Professional for PC
Hard drive controller
Certain diags only test the diagnostic tracks. That is what's passing more than likely. You should boot the laptop in safe mode (F8) and click start, run, type in cmd, hit enter and type scandisk. This will do a complete scan on the drive. If there are any errors replace the drive.
Jul 30, 2007 | Compaq Armada 1700 Notebook
Blue Screen Error Message
Your hard drive crashed. You need to buy a new hard drive and restore your computer using the restore disks. You can buy a hard drive here: http://www.interproshop.com/commerce/catalog/product.jsp?product_id=13055&czuid=1167865660865 They also sell larger hard drives. If you dont have a restore disk, you'll need to contact HP and they'll send you one. http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=423721&lc=en&cc=us&dlc=en&submit.y=9&submit.x=8&lang=en&cc=us
Jul 14, 2007 | HP Pavilion Ze4805us Notebook
Sony VAIO VGC-RB40 PC Desktop Logo
73 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
