It seems my heil heat pump is going into defrost every time it comes on and blowing a smell back into the vents in my home.The unit will come on heat up and then we smell this odor. It has not been very cold here yet for it to be defrosting that much and I don't see the steam blowing outside from the unit.I had a problem with the fan motor back in the summer and a service man replaced it I was wondering if this has cause the problem now with the heat. The unit is only 2 1/2 years old.Could someone tell me if they know what this problem might be?
Yep it is the heater core, you need to replace it
Posted on May 14, 2012
I would have either the circuit board that makes it go into defrost checked, our new Trane had same problem and we had to replace it, or also have them check the sensor that "tells" the unit to go into defrost. I'm suspecting that is happening in ours now, too, as it seems to go into defrost more often again, but not as bad as last year. As for the odor, you have what we, and a lot of others have, is called "dirty sock syndrome", appears to be cause by organisms of some sort growing on the coil in the indoor unit, when it goes into defrost mode the coil gets wet and "turns them on" thus making the organisms smell. Difficult to get rid of. Am going to try a spray called Alathene II and see if that helps.
Posted on Nov 19, 2010
Heil heat pump heat won't work changed defrost board ac works
Reversing valve may be bad or stuck. U can pull the fan, then turn the unit on. The reversing valve is just a small unit with a 110 V. cable going to it. Sometimes taping the valve will make it change to heat.if so it will need to be replaced.
Feb 28, 2014 | Heating & Cooling
Defrost will not defrost my windshield
You do not mention the type of car you have. If you have air that blows out the defroster and panel vents you should have defrost. Do you smell a sweet odor coming from the car? This could be antifreeze leaking though the heater core. This will cause your windshield to remain foggy.
Nov 13, 2013 | Eagle Cars & Trucks
No heat just cold air
Is the gauge showing the engine is warming up to normal temp ?
Are the heater hoses getting hot ?
If the heater core is getting hot, it could be a blend door problem. The blend doors direct air thru the heater core and the ac evaporator among other things.
Dec 06, 2012 | 2005 GMC Yukon
Heat pump doent kick back on after defrost-blows 5amp breaker
If you continue to blow the 5 amp fuse, you have a "short" in the control circuit. It could be the reversing valve solenoid coil (very rare) or it could be in the wiring. It is possible that you have a wire with cut or melted insulation that is causing the low voltage short. If this is happening only during the defrost cycle, then you want to check the wires going from your defrost board to your reversing valve solenoid coil. Also check the wires going from the defrost board to the defrost thermostat. Often, some electrical tape and some wire ties to pull the wires away from the area that damaged the insulation is the only thing that is needed to correct this problem. I hope this helps. Good Luck!
As far as the refrigerant is concerned. Yes, it is possible to overcharge a system. It would have to leak out, but it is not uncommon to charge a system that has 5 years and perform a quick check for leaks. Sometimes systems have very slow leaks or the leaks reseal after time. It is better practice to charge it, look for obvious leaks and then see how it does than it is to spend hours looking for a leak that may not be found. It costs you more money and the tech more time. Hopefully, you used a reputable company to charge this system.
Feb 07, 2010 | Carrier Heating & Cooling
Should my Heil heat pump CH95 automatically defrost? And when?
It depends if it has a defrost control built into it or not. Most units do not come with them installed they are an add on feature that you have to pay for. if the outside unit is icing up then the outside temperature is probably to low to run the compressor. I would switch over to aux. or emegency heat option on the thermostat as in low temperatures it is not efficent to run a heat pump anyway. Hope this helps have a wondeful evening.
Jan 30, 2010 | Heating & Cooling
UNIT NOT BLOWING WARM AIR-OR REACHING DESIRED TEMP
I assume this is a heat pump. The outside unit may be icing up. It should have a defrost cycle with electronic control that sometimes fails or sensor associated with the electronic determination of when to defrost may have failed or may not be sensing because its out of position. You can check for a defrost problem. If frost is blocking the outside unit air will not pass through it after the frost builds up and you may be able to see the white frost as well. If all this is true you need to get a service manual and use its procedures to find out why the unit is not defrosting.
Jan 12, 2009 | Weather King 12AJA4801AH Air Conditioner
Air conditioning and heating
have the water pump checked out, i had a van that did the same thing and founf i had a bad water pump it fixed the problem.also check the blower motor to make sure its working right by tapping on it while you have the car running. the car will survive dont worry its going to be one of those two things im pretty sure.
Jan 08, 2009 | 2001 Saab 9-3
Compressor fan not running
Does it look like the coils are frosting over? Is it steaming? Keep watching, after about 30 min does the fan come back on?
If yes to any/all the above then the unit is probably in defrost mode and yes the fan will stop blowing during that time, but restart when the unit goes back into regular heat mode.
During this time you will likely notice warmer heat from the vents than normal and the "AUX or EM HEAT" light will be on.
That is your backup heat system. It should automatically come on during a defrost cycle.
Dec 06, 2008 | Goodman CLQ36AR49 Air Conditioner
I HAVE AN AMERICAN STANDARD HEAT PUMP/AIR CONDITIONER UNIT OUTSIDE MY MOBILE HOME A FEW DAYS AGO A UNKNOWN SMELL COMES THRU ALL VENTS IN AIR CONDITIONER MODE ONLY. WHEN HEAT IS ON THERE IS NO SMELL UNTIL...
This is a condition called Dirty Socks Syndrome air cleaners and dehumidify usually fix the problem also adding a uv light to the duct can remedy the problem the light is probally the cheapest solution
Dec 04, 2008 | LG LS-K1830CL Cool Mini Split Air...
Heating & Cooling Logo
390 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
