Question about Briggs & Stratton Ignition Kit 2-8 HP Engines with Breaker Point Ignition #5012D
8hp briggs motor. ive cleaned all magnets even under the flywhell and set the gap and replaced the coil but i still have no spark. it does have a small spark start to ground but not through the spark plug. any thing else i can chech?
  • scromer159 Nov 16, 2010
    no points magnita and i did clean all the magnets.
    Guru:
  • 302 Answers
Is the air gap around .008 thousands.
Posted on Nov 13, 2010
  • 2 more comments
  • scromer159 Nov 15, 2010
    .010
  • Kevin Smith Nov 16, 2010
    Have you checked the points under the flywheel to see if they are corroded and or breaking when engine is turned over.
  • Kevin Smith Nov 17, 2010
    Alot of theolder briggs had a set of points under the flywheel underneath a tin cover that you had to remove.
    the points will need to be cleaned and check the gap and if it has sat for a long time it might need points and condensor replaced.
    the points is what causes the spark when they open they cause the magnetic field in primary to collapse and induce voltage into the secondary causing the spark at the plug.
  • scromer159 Nov 17, 2010
    found it! bad ground wire! it broke off when i touched it! thanks though!
Were is low oil sensor 13-hp.briggs
check gap on coil the gap on the points and also make sure the magnets are free of rust, the capacitor could be weak also.
Jun 11, 2014 | Briggs & Stratton Ignition Kit 2-8 HP...
Briggs ans Stratton Quantum 5.5 HP still no spark after changing coil and plug
You are correct, you have a flywheel with magnets in, an electronic ignition unit which when the magnets pass the ignition unit core at speed energises and creates a spark via the plug, the earth wire simply takes the unit to ground and shuts off the spark, the unit you changed was it definetly an electronic unit or just a coil? if electronic and you are cranking the engine fast enough and have the plug well earted against the cylinder with the earth wire not connected it should spark.
Sep 01, 2012 | Garden
No spark
Did you try grounding the plug against a clean metal surface of the saw and pull the starter rope. If you do not see a spark I would suspect the ignition coil.or magneto that the flywheel rotates around to create an elelectrical charge. Sometimes eith the magnet on the flywhell or coil can get rusty. Try cleaning them up with some light sandpaper. Just make sure you replace the coil with the proper gap between it and the flywheel. When testing for spark as described above make sure you are not touching any metal surface on the saw or you could get a shock.
Aug 14, 2012 | Homelite Garden
My 5 hp briggs stopped running. No spark. took recoil off to reveal a rotten coil with wires rotted off. cleaned off the flywheel and replaced the coil with one from Napa. The engine does not have points...
Did you set the Air Gap correctly, it should be .020 inch. If the Air Gap is correct and you cleaned the pickup magnets, you should be getting spark. I have different color coded plastic sheets of the correct thickness to set the Air Gap on different engines. You could use a use a side panel from a plastic soda bottle (Mt Dew, Pepsi, ect) Place it between the Flywheel and the Armature/Ign Coil. Allow the magnets on the Flywheel to pull the Armature/Ign Coil together and then tighten the Armature/Ign Coil bolts. Carefully turn the Engine while pulling the plastic from between the Armature/Ign Coil Pickups. The Armature/Ign Coil is now properly set.
Generall speaking for a gasoline engine to run you need 3 things. (1) Spark, (2) Gas and (3) Air.
I hope this is helpful. UAW 974
Jun 25, 2011 | Sport & Outdoor - Others
No fire mtd 21inch 3.5hp
You should have a strong, blue sparlk. Make sure plug is grounded to engine when you test. Don't do it in the air. Check the flywheel/coil air gap. I think on Briggs it should be about the thickness of a standard business card. If after setting the air gap and there is no spark...plug is bad or ingition coil module is defective. When you adjust the gap, make sure the magnets in the flywheel are lined up with the "legs" on the coil to assure the correct setting.
Aug 11, 2010 | Briggs & Stratton Garden
Need point gap setting for 8 hp Briggs and Stratton gas engine
If it is an older BS it will be .015 That was standard. In fact an old match box cover would work to set them if you could not find a guage
Oct 07, 2009 | Briggs & Stratton Ignition Kit 2-8 HP...
Cant get a spark on my briggs and stratton 4hp engine, trying to
Doooh!!!! had the coil on backwards this will cause a weak or no spark situation. Should have had my glasses on , there is a faintly perceptable this side out on the new coils. Also there is no mention of this in the directions.
May 18, 2009 | Troy-Bilt Garden
Chipper won't start
what engine do you have im guessing a briggs & stratton was it running previously or sitting awhile it can be a few things the flywheel key could be sheered or the points are bad or the flywheel & coil are rusted check flywheel & coil to see if rusted if so take coil off mild sand paper like 80 grit i beleave clean both to get the right gap between flywheel & coil turn the flywheel alittle bit so the magnets won't touch coil or if coil still of set flywheel to where it will touch magnets fat peice of sand paper not folded but flat sand paper about .020 gap between magnet & coil if you place sand paper against the flywheel magnet then set coil against sand paper & magnet that should give you 0.020 gap & it should start if not e-mail me i will guide you through everything to get it started
May 11, 2009 | Heavy Machinery
'Get-Jet' Airplane mover
Hi Freddie ignition- to- flyweel gap means flyweel magnet positioned under the ignition coil armature.Remove the flyweel.Check the flyweel key(if it is sheared off install a new one).Remove the ignition coil.Clean the flyweel magnet and the ignition coil armature.Check the ignition coil wires and terminal to have continuity.Remove the breaker points cover,check the condenser and breaker points(they should not to be burned).The ignition breaker point gap and ignition-to-flyweel gap is 0.020" and the spark plug gap is 0.030". regards savumihai71
Nov 01, 2008 | Briggs & Stratton Electrical Supplies
Briggs & Stratton Ignition Kit 2-8 HP Engines with Breaker Point Ignition #5012D Logo
505 people viewed this question
Top Briggs & Stratton Hammering Experts
Dan Webster
Dan Webster
John Trevino
JOHN LAPIER
Are you a Briggs & Stratton Hammering Expert? Answer questions, earn points and help others
