Question about Black & Decker ProFinish X750 Iron
How to clean the Black & Decker PROfinish 750 iron
SOURCE: Cleaning a self cleaning iron
My iron went into cleaning mode and I don't know how to stop it from doing this. I don't need to clean it now. How do I get it to stop?
Posted on May 24, 2007
electrodynam
  • 35 Answers
SOURCE: the black and decker iron wont heat up
It probably has a high temp overload opened up inside or the thermostat control has gone bad.You can only tell for sure by taking the unit apart and testing the circuit for continuity.The steam feature on the iron is heated by the same element that heats the iron so it wont work.the element itself could also be bad,but I have never seen one go bad.You will have to check each component seperately to find the damaged part.or you can test the whole circuit at the plugs end,and use a jumper across each part until you have continuity through the unit.Make sure the thermostat is turned all the way up.the part that you are bypassing when you get continuity is the bad part.
You can buy a cheap continuity checker at any lowes,or even wallmart for that matter.
Posted on Mar 16, 2009
stonephoenix
  • 563 Answers
SOURCE: How do I clean my Black N Decker Advantage Iron
I work for Black & Decker customer service. Our number is 800-231-9786.
You can obtain a new manual for free by visiting www.useandcaremanuals.com. Below is the section from the manual on care and cleaning of your iron.
Care and Cleaning
This product contains no user serviceable parts. Refer
service to qualified service personnel.
It is not necessary to empty the water reservoir after each
use of the iron, if you iron frequently.
To empty the iron, hold the iron over the sink with the tip
pointing down. Water will stream out of the water fill
opening.
TO CLEAN THE OUTSIDE SURFACES
• Unplug and allow iron to cool completely. Wipe the
soleplate and outer surfaces with a soft cloth
dampened in water and a mild household detergent.
Never use abrasives, heavy duty cleansers, vinegar, or
scouring pads that may scratch or discolor the iron.
• After cleaning, iron with steam over an old cloth to
remove any residue from the steam vents.
ABOUT THE SELF-CLEANING SYSTEM
• Use the self-cleaning system to flush out minerals and
lint. If lint is allowed to accumulate in the vents, it can
scorch and cause brown spotting.
For Models D2000 and D2020: Clean about once a
month.
For Models D2010, D2030 and D2035: A "CLEAN"
indicator will appear in the digital display to notify you
when your iron needs cleaning (A).
• Fill the iron as described in "How to Use" but keep the
water level below the MAX line. Plug in the iron, set
the temperature to 6, and stand the iron on its heel
rest. Allow to heat about 3 minutes.
• Unplug the iron and take it to a sink. Holding it
horizontally over a sink, move and HOLD the variable
steam dial in the CLEAN position ( ). There may be
some hissing and spitting while self-cleaning. This is
normal.
• Stay clear of HOT steam and boiling water as it comes
out of the vents while lint, scale, and minerals flush
through! Continue to hold the variable steam dial in
the CLEAN position until all the water has emptied.
If necessary, rock the iron side to side and front to back
to empty it.
• When finished, release the variable steam dial, stand
the iron on its heel rest, and plug it in. Heat for about
2 minutes to dry out any remaining water then unplug.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Posted on Jul 04, 2009
romsky79
  • 822 Answers
SOURCE: Same Issues with my Black/Decker 2030
change the thermal fuse inside iron that's why not getting hot. thermal fuse blown up due to overheat inside.
Posted on Aug 19, 2009
SOURCE: iron saying "error"
my **** is to big for my girls friends ***** how do i get it in?
Posted on Sep 19, 2009
MY BLACK & DECKER D2030 DOES NOT POWER ON?
my black nd decker iron lights up but will not heat.
Jan 01, 2013 | Black & Decker D2030 Iron
My Pro Finish 714 cord was accidentally cut. Is it worth replacing the cord? Where do you get a new cord and can I replace it myself?
Thank you for using FixYa. Is the cord cut near the iron end or the outlet end? could the cord be shortened? A new cord can be purchased at most reasonable hardware stores and with a little care and attention can be replaced yourself.
Hope this has been of some help.
Mar 04, 2011 | Black & Decker ProFinish X750 Iron
Black rubber burned onto plate of iron
Here is a tip that will help you with that problem...
Cleaning a Steam Iron Soleplate
http://www.fixya.com/support/r5301167-cleaning_steam_iron_soleplate
heatman101
Apr 12, 2010 | Black & Decker ProFinish X750 Iron
The Clean light on my Black & Decker Digital Advantage iron has come on and I can't find my manual. How do I 1) clean it and 2) get the light to turn off?
I found a previous answer on FixTa.com that had a link to the owners manual for my iron. The info I needed was there and my problem is resolved!
Jan 12, 2010 | Black & Decker D2030 Iron
Cleaning an iron faceplate
first you get the iron hot,
then you use a damp towel,
and rub firmly
Oct 06, 2009 | Black & Decker Irons
Describe your Black & Decker
Please call Black & Decker customer service at 800-231-9786 so that we may determine your warranty status. Mon - Fri. 8:30 to 6:00 EST.
Jul 07, 2009 | Black & Decker AS150 Iron
How to clean the plate of a black and decker iron that has build up?
you can take the solution for descaling coffee machines and set the iron in a layer of less the 1/4 inch deep.
you can clean out the holes with a needle. than run the selfcleaning cycle.
leave the sole in for about 15 minutes. Than clean with non scratching scotch brite.
Apr 28, 2008 | Black & Decker ProFinish X750 Iron
Black & Decker ProFinish X750 Iron Logo
133 people viewed this question
Top Black & Decker Irons Experts
tfelton3
nmccully
Are you a Black & Decker Iron Expert? Answer questions, earn points and help others
