Question about Samsung Televison & Video
I have a samsung tv and the remote is the BN59-00849A(it comes with the 8000 series)I went to pair the remote and the button(tiny button)got stuck down,then I hit the reset button(tiny)and it got stuck in the down position.I can't figure oput how to get the remote apart(removed screws from back)????
SOURCE: Samsung TV remote control
I HAVE THE SOLUTION TO THIS PROBLEM.
Confirmed with Samsung tech support. Problem is with remote. to fix, simple take the batteries out of the remote. Press and hold the UP Volume button for 2 Mintues (no cheating, it has to be at least 2 minutes), this Reset's the Remote Control. Put the batteries back in. Bob's your uncle. all fixed.
Posted on Jan 26, 2008
SOURCE: harmony 880- how to take be back cover off?
Once the screws are out, using your finger nail (I find the thumb is best), with the remote display side up - do the following: At the very narrowest part of the remote, with the display facing up, wedge your nail in and down. This will spread the cover just a bit. Move forwards and backwards, and you should get the retaining clips to "pop' out from the top half. Do one side completly before the other, there are 4 "clips" per side. If you did this carefully, you will not have broken any of the clips, nor scratched the plastic. When re-assembling, be sure the IR / USB cover is properly in place before evenly snapping the top and bottom halves back together. Hint, if you look very carefully in the seam, you can actually tell where the 4 clips are as there is a slight indent and it is a bit darker.
If you do not want to damage the case edge, or break the clips....DO NOT use a screw driver, and do not force anything very far into the seam.
Posted on Dec 12, 2008
bernardlunda
  • 318 Answers
SOURCE: My samsung tv is not responding to my remote control
your turning section is not responding to any input, hence needs to be checked by a technician. every thing you have mentioned are controlled by one ic, with its respective voltages.
Posted on Mar 27, 2009
SOURCE: My remote for the samsung htc550 home theater
Press the BD Receiver / TV button twice in quick succession. The light should now be orange which indicates it will operate the Home Cinema system....Pressing it twice again in quick succession will turn the light green indicating it will operate the TV.....Unfortunately the useless operator manual with the system does not tell you this....
Posted on Dec 18, 2010
NickF DISH
  • 36 Answers
SOURCE: Dish Network IR Remote's SAT Mode Not Working ____
Hello, this is Nick Franta with DISH.
If you are trying to get the remote programmed to the receiver you can remove the smartcard from the receiver and that will prompt the system info screen. This will allow you to program the remote to the receiver.
If you need the process for programming the remote, here it is:
  1. Go to System Info screen (in this case -- obtain by removing smartcard from receiver)
  2. Hold down the SAT button until all mode lights light up.
  3. Enter a number between 1 and 15 using the numeric keypad on the remote.
  4. Press the pound (#) button
  5. Once the SAT button blinks three times, press record.
Hope this helps!
Posted on Jan 03, 2011
Samsung BN59-01223A Remote Control
Try Pairing procedure:
  1. TV off
  2. Bring remote within 3 feet of TV
  3. Push Pairing button (Paper Clip or other pointed object in button hole)
  4. Turn on TV
  5. Should be paired. Try remote channel or other buttons.
  6. If not, try 2 more times.
  7. If still not working, push RESET button first and repeat Pairing.
Feb 15, 2016 | Samsung Televison & Video
My Samsung remote is BN59-01134B. I cannot remember how to program it to my TV I don't remember the code to program it to my TV I'm totally lost please help
  1. TV off
  4. Turn on TV
Dec 20, 2015 | Samsung Televison & Video
Instructions to control samsung t v
  1. TV off
  4. Turn on TV
Samsung remotes for LED / LCD TVs are generally RF, not IR.
Most Universal remotes do not generate RF signals, so disregard advice about codes for Universals.
  1. TV off
Within 3 feet of TV
PAIRING and RESET buttons:
Dec 08, 2015 | Samsung Televison & Video
Why won't my samsung smart tv emote wont change chanel
It needs to be Re-Paired to the TV.
First, fresh batteries, and clean battery contacts if needed.
Then, Try Pairing procedure:
  1. TV off
  4. Turn on TV
  1. TV off
Within 3 feet of TV
Please rate if Helpful.
Good Luck !!
May 25, 2014 | Samsung TV Remote Control
My samsung 3D led multisystem smart TV remote control does not work anymore
  1. TV off
  4. Turn on TV
Good Luck !!
  1. TV off
Within 3 feet of TV
PAIRING
and RESET buttons:
Apr 15, 2014 | Samsung TV Remote Control
Remote will not work
  1. TV off
  4. Turn on TV
Good Luck !!
PAIRING
and RESET buttons:
Within 3 feet of TV
  1. TV off
Mar 05, 2014 | Samsung TV Remote Control
Samsung tv has never responded to the remote control
  1. TV off
  4. Turn on TV
Good Luck !!
PAIRING
and RESET buttons:
Within 3 feet of TV
  1. TV off
Feb 15, 2014 | Samsung TV Remote Control
What is the difference between RMC30C1 and RMC30C2
They are pretty much the same except the C1 is designed for the 9000 series TVs and has a twin screen button whereas the C2 is for the 7000 / 8000 series Samsung HDTVs and has no twin button.
Apr 29, 2011 | Samsung RMC30C2 Remote Control
How can I connect the RMC30C1 Samsung Remote COntrol to my Samaung 8000 Series TV
No simple answer. I have the series 9 samsung.
Basically you need to connect the tv to the internet, and the remote control to the internet and then connect the remote to the tv. There are a few other ways but this is what I did for my Series 9 TV: Before you start check your wireless internet security number for your broadband router. If unsure check the instructions that came with your wireless router as you will need to type in the internet address and setup wireless security key, otherwise your exposed to other people using your broadband download.
Step One: Menu setting on TV go to PlugPlay- Network - set it up. To find Menu TV Control on remote, flick your finger right to left to scroll to new hidden screen - menu appears! Step Two: Test network connection, (you should set up wireless security (WEP/WAP) to match your broadband security key) Step Three: Services Tab/Setting icon/remote settings/network/wait until it finds network/select network/add security internet WEP/WAP Key - check IP Service Provider if unsure. When Remote is connected to the internet tap bottom right button to connect tv. Tab appears on the tv 'allow or not allow remote' select allow using the TV navigation button. Simple really. Mike
Jan 11, 2011 | Samsung RMC30C2 Remote Control
TV IS NOT RESPONDING TO REMOTE. I'VE CHANGED THE BATTERIES AND HAVE TRIED OTHER SAMSUNG REMOTES THAT WORK ON MY OTHER TVS. ANY SUGGESTIONS...
Sounds like problem is with TV. Make sure the remote sensor on the TV is not blocked, it is located at the lower right part of the front of the TV.
Dec 12, 2010 | Samsung BN5900696A Remote Control
Televison & Video Logo
99 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
