Question about RCA F27664 27" TV
How do i reset the channel list? i am not able to change the channels that are viewable.
A possible solution for this; Unplug the power cord and wait about a minute, then plug it in and turn the set back on. Sometimes a power surge will disrupt the computer circuit that affects the channles, and it should come back up normally using this proceedure.
Posted on Nov 13, 2010
I tried to program the TV 125 channels but only channel 3 is viewable
If it's a universal remote, you should find another one.
If original, it's not working
Jun 02, 2015 | Toshiba Televison & Video
Froze
To see if the problem is with your remote control, go to the receiver and use the channel up/down buttons on the receiver itself. If you can change your channels with the buttons on the receiver, the batteries in your remote control probably need to be changed.
If you can't change channels from the receiver, turn off the receiver. Then unplug it for at least 15 seconds. Plug the receiver back it and turn it on. Again, try changing channels from the receiver itself.
Tune to a channel, and while programming is playing, try tuning to the missing channel by entering the channel number on the remote control keypad to see if channels change. Do not try to select the channel from a channel list, program guide, or favorites list.
If this approach takes you to the correct channel, you need to adjust your favorites list function. Press the "guide" button on your remote. Look for a button on your remote called "fav" or "list." Press it several times and watch for an indication at the top of the guide that you are moving from "all channels" to a particular favorites list.
If you are locked on one channel only, your Channel Lock feature is likely active. Consult your owner's manual to unlock the rest of your channels. See your owner's manual for information on managing favorite channel lists and locking out channels. Enter your password, if necessary.
Jul 30, 2012 | Coby TFTV1925 19 in. LCD TV
I have a Sanyo tv ( model #DS19330 ) and using a Sony remote to operate it. I am trying to restore channels 14-69 by scrolling through the channels with the remote. I can punch all channels in by...
It sounds like that the TV was set to skip certain channels. You need to rescan for channels or manually edit the channel list. To manually add channels, press Menu on the TV (or the equivalent key on the Sony remote if you found a code that works). Then use the Up/Down arrows (channel change keys) to select Ch Scan Memory + . Then enter the number of the channel (numerically or up and down arrows). Press + (volume + key) to change the setting from Deleted to Added or vice versa. Since you do not have the original remote, I'm not sure if the Sony remote will match the Reset key of the original remote. Unfortunately without that key being pressed twice, you can't reset the entire channel list and cause the channel search to begin automatically.
The manual for the DS19330 TV is here: http://www.sanyotv.com/DS19330%20%28ESF%29%203764--.pdf . (I'm assuming you haven't recently added cable after only receiving only OTA signals. If you have changed inputs like that, you need to go through the menu and change the source.) Menu > Cable or Air .
I hope this helps.
Jul 27, 2011 | Sanyo Televison & Video
Channel lock is stuck on
May 28, 2011 | Televison & Video
Auto set up finds only some of available programmes. Only ITV channel found is ITV 4. cHANNELS 4 AND 5 not found. Very good reception on programmes it has found. Full range of programmes viewable...
It maybe that the TV needs to be completely reset. in the menu somewhere should be a setting to "restore factory settings" or "reset to default" something like that...
Try this and post the results...
Aug 27, 2010 | Panasonic (TH-50PZ700U) Television
Everything work except it will not change channels with the up and down button and says that the channels are not viewable but if you enter the channel number it works
Hi, This sounds like it is not a problem with the remote, but more like the channels have been "skipped" in the tuning menu of your TV.
To Fix, enter the tuning menu on your TV and set the "skip" or "clear" to OFF for all the channels you want to watch, then the program+ & - buttons should then work for you
Mar 19, 2010 | Kenwood Televison & Video
Trying to re-set the digital channels. Using
Hi Barry Like mine, it could be that since the channel 5 fiasco, your new signal may be a bit weaker, and may have only just been strong enough before. I had to dig out an old signal booster, a re-tune again, and bingo all there! Also, when you go to retune, you may want to use "first Time Install" because it completely wipes the old channel list, and starts a fresh.
Dec 06, 2009 | Televison & Video
Toshiba 42 lcd cannot delete channels I use the manual channel set and select Not Viewable for channels I don't want to see. Then as I click through the channels, the deleted channels show up again.
Also have a 42" Toshiba and had the same problem, then had issues moving the channel order while some channels were set to skip.
What I ended up doing was retuning the tv. Then went through the channel list (Menu -> Setup -> DTV Setting -> Channels) and changed the number of the channels I didn't want to 1000+ (using the red button, ie 1001, 1002, 1003...). This in itself does not change the channel order, but when I then move these channels to the end of the channel list and because they are numbered numerically I can be sure I don't miss any.
Next I went to the channel options (Menu -> Setup -> DTV Setting -> Channel Options) and marked all the channels I'd moved to the end of the list as channels to skip and locked. This does not remove the channels from the EPG but it does move them to the end of the list and when scrolling with the channel +/- buttons these channels will not be selected.
Ideally I would also like to delete channels such as QVC etc altogether and would love to know if anyone has a more effective solution to this issue.
Aug 15, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
A&E is only viewable channel
try switching the cable inputs around you can also do a auto Chanel in the menu, if the problem presets then your tuner is out
Mar 06, 2008 | Samsung HCN4226W 42" Rear Projection...
Guide listings are incomplete
1. Manually scan all channels on your TV with your TV remote and write down the channels and network shown:
(sample: 119.2 C-SPAN2 digital channel).
2. Go to Edit Channels and find the icon for C-SPAN2 (about icon 261 in my zip code). Manually change the channel from Off to On, Insert the frequency, and optionally insert the number you want the channel to show in your channel listing ( or move it manually later).
I have about 10 to add each time I reset my recorder.
Feb 15, 2008 | Sony DHG-HDD250 200-Hours Video Recorder
RCA F27664 27" TV Logo
29 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
