Question about Intermatic Inc. ST01C Digital In-Wall Timer
Does not turn on exhaust fan motor in bathroom. Display functions work. Could it be the battery or the unit?
The problem can be either battery or timer.
Several people wrote fixya over past months saying that ST01C failed completely after installing new CR2 battery.
http://waterheatertimer.org/ST01C-program.html#battery
Battery operated timer, then weak battery can cause timer to malfunction.
ST01C troubleshoot says BATT advisory does not always display.
ST01C has 1 year warranty.
Advantage of battery-operated timer is simple wiring when box does not have neutral or ground wire.
Battery-operated Intermatic EI600 has 5 year warranty
http://www.intermatic.com/products/timers/in-wall%20timers/electronic%207-day%20astro%20time%20switches.aspx
Honeywell Aube T-1032 7-day timer has internal rechargeable battery
http://waterheatertimer.org/Aube-timers.html
Posted on Nov 14, 2010
When Exhaust button pressed, vent fans not working, but microwave running for 30 seconds.
test the components and fix it. God bless you
  1. Exhaust fan motorIf your exhaust fan motor is not running, there are a couple of things that you can check involving the motor to locate the problem. After removing the fan motor, you can manually attempt to turn the fan blades with your hand. If the fan motor is working properly, the blades should spin effortlessly. If this does not occur and the blades are taught, the motor will need to be replaced. Secondly, the fan motor itself can burn out due to time and usage. Using an ohm meter, the exhaust fan motor should read open for continuity. If it does not, then the fan motor has expired and will need to be replaced.
  2. ThermostatAnother part that could cause the microwave exhaust fan to not work is a faulty thermostat. A thermostat gauges the air temperature, which activates the exhaust fan when required. If this part becomes flawed, the exhaust fan will not energize and the thermostat will need to be replaced.
  3. Main control boardIf your exhaust fan is still not working and the microwave fan motor, wiring, and thermostat are operating accurately, the root cause could be with the main control board. Replace the main control board.
Oct 24, 2013 | Frigidaire Microwave Ovens
Dear Sir , the dehumidifier is running the motor is running, but not sending out any water. I have cleaned the filter.n Any recommendations?
Is it only the fan motor running that you hear? Or is it the compressor motor and the fan motor in combination?
If it's just the fan motor, it running to circulate the air, in an effort to sense humidity in the air, above the level you have the humidifier set on. Speaking of which, you may have the level set higher than what the humidity is in the house and the unit is just maintaining it. 50 to 60% is high, as opposed to 35%, which is what most folks want to maintain in the hot, humid, summer months.
If you want to test the unit, place in the bathroom, turn a hot shower ON, turn the humidifier ON and set it for 45% or minimum if your unit does not have a LED readout screen. Do Not turn the bathroom exhaust fan ON. As you leave the bathroom, close the door and don't return for 20 minutes. When you do, turn the shower OFF and check the humidifiers water collection bucket. If you see any water, the unit is working as it should. If you don't see any water, it's time to replace that unit. I say that because, at best, the parts and labor to repair the unit would be equal to or almost equal to, the price of a new dehumidifier.
Hope this helped you troubleshoot and solve the problem. Please let me know. Thanks
May 20, 2011 | Fedders A7DH45B2A Dehumidifier
My bathroom exhaust fan has a dial timer. Sometimes lately the fan does not come on for a couple of minutes after starting the dial timer. Is that likely to be a problem with the dial timer, or with the...
This could be the timer or the motor. The timer could be going out or not starting up in the right position. Has anyone worked or removed the timer knob, it could have been put on just a little off causing the switch to be off just a bit. Again the motor could be going out,such as the bearings inside. I would see what type of warranty is on this fan. I know these exhaust fans can get a little pricey, so I would see what warranty options I have.
Mar 06, 2011 | Broan-NuTone Fan,Bathroom Exhaust Broan...
How do i hook up a two function swith i have white black and ground going to the fan and the light and anther white black and ground coming from my bathroom light i want to have a switch to turn my...
Ok you only have two switches, so you would use one switch for your bathroom light, and the other for both the fan and the light, the light will come on when you turn the fan on.Connect the incoming black (hot) wire to both switches. Then connect the black wire to the switch you want for your light. Connect the other black to the second switch that goes to your fan and light. Connect the three white wires together (neutral) Connect all ground wires together, and leave a pigtail to connect to the ground terminal on the light switch. If you want separate switches for light in the fan and fan, you will need another conductor and a three gang switch.
Oct 17, 2010 | Broan-NuTone Broan 68W Dual Rocker Switch
Have a nutone fan for bathroom taken motor apart to try to figure why it will not turn anymore after i put some oil on the shaft previously. Thought maybe the oil shorted out the something but could only...
Save yourself the grief and buy a new fan. Either replace the whole unit or take the fan from the new unit and install it in the old fan chassis. It will be a lot less painful than trying to troubleshoot the old unit.
May 06, 2010 | Broan-NuTone N-8663RP Combination Light...
Problems with exhaust fan NuTone Model LS 100SE
The fan/motor part of the Broan fan is replaceable. They are actually very simple to take out and install a new part.
The part can be easily purchase here...
http://parts.broan-nutone.com/broan/Shop
Heatman101
Feb 27, 2010 | Broan-NuTone N-LS100SE Exhaust Fan Exhaust...
Replace motor in Broan 678 bathroom fan
I ran into the same problem, Lowe's carries Broan exhaust vents. They had both a replacement motor for all generations of 678 fans for $18, and they also had the latest generation of the complete unit for $40. I bought the complete unit, which included the fan I needed. Just unbolted it from the new bracket and bolted it to the old one. The new light housing, trim piece, and lens also interchanged. The existing one was old and yellowed, so this made for a huge improvement. All done from in the living space as well.
Aug 11, 2009 | Broan-NuTone N-8663RP Combination Light...
Bathroom exhaust fan 16 years old and noisy. How to fix?
One drop of 30 wt oil at each bearing will quiet the thing for a while, but you will eventually want to replace it. Also consider the whole fan is about the same cost as the motor, and easier to find.
May 16, 2009 | Broan-NuTone N-671R Exhaust Fan Exhaust...
Bathroom Ventilation Fan Motor Failures
I'm guessing that water isn't splashing up on this fan's motor, so the moisture that is causing the rust must be water vapor. The exact same water vapor that the fan is supposed to be removing. I have two suggestions before replacing the entire fan. One is to make sure that the ducting that carries the moist air out of the bathroom (and preferably out of the house altogether) is free of obstructions and that the fan can actually do it's job. Second is to actually run the fan, and run it a lot longer than you probably are right now. If it is running while you are in the shower and then you turn it off after you leave the bathroom, it can't possibly be removing that moisture. I'd invest in a countdown type timer and replace the existing switch with that. Set that thing for 30 or 60 minutes when you get in the shower and let it turn it off automatically.
Jan 28, 2009 | Broan-NuTone N-LS100SE Exhaust Fan Exhaust...
Noisey 8 x8 Broan Bathroom Exhaust Fan (With Light) (7 years old)
Mine was doing the same thing. I found it was coated with dust.
I took the blower out [unplugged it, and removed the single screw holding it to the box], took the face plate off [removed 4 or five screws] brushed the squirrel-cage fan blades using a narrow, long and stiff bristled brush, and reassembled it [used care to align the small plastic axle on the flap valve ] and reinstalled it. The vibration was greatly lessened and the fan was about as quiet as it had ever been.
Dec 23, 2008 | Broan-NuTone N-LS100SE Exhaust Fan Exhaust...
Intermatic Inc. ST01C Digital In-Wall Timer Logo
171 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
