Question about Bunn BT10B Coffee Maker
Filling coffee resovoir after several days of non use while it has been plugged in
When do i add aditional to fill resovoir, when i haven't made coffe in a couple of days? Do i need the heating element off or on and do i plug in
maker while filling or after/
    Problem Solver:
  • 15 Answers
Water typically doesn't go bad in a reservoir, which is a closed container.
That said, if you're worried, run the unit until all of the water is in the carafe and out of the reservoir.
Turn off machine. Dump carafe contents in sink. clean with soap and water. Refill water in machine, place filter and coffee into machine and use as per normal.
Posted on Jun 22, 2008
Why Coffee Machine keeps saying 'fill coffee beans' ?
Unplug it to disconnect the electrical power.
Reconnect it.
Look for a "sensor" that determines when the hopper is filled -- is that "gummed-up" or "jammed" ?
Jun 12, 2014 | Saeco Coffee Makers & Espresso Machines
Red light on, not blinking
make sure your steam button is completely turned off
Jan 14, 2012 | Saeco Odea Giro Plus Coffee Maker
Can you explain the descaling process?
when removing coffe scum or 'scale' try using a small amount of bleach, or a concentrated briquette of cleaning chemicals especially for coffe stains. CLR works too. fill the container with the substance and generous water past the scum line. let it sit for 30min-an hour. you'll notice the scum lifting. might have to repeat the process, but it is very important to not add too much soap, and try using scalding hot water. thoroughly rinse the container to avoid toxicity.
May 06, 2011 | DeLonghi Coffee Makers & Espresso Machines
Water does not come out ...is there a fix
mcdevito75 here, Make sure everything is set to make coffee, New or clean filter, filter basket set in machine. Your coffee maker might need cleaning also.------------ Fill resovoir with white vinegar, let it run thru the machine 3 times, half way thru ther 3rd time stop machine and let stand for 30 minutes. resume brewing, then fill resovoir with water and let run thru machine 2--3 times to get rid of vinegar. If this don"t help you may need new coffee maker.
Jul 09, 2010 | Mr. Coffee TFTX85 Coffee Maker
Need directions for the Micro-Perk microwave coffee brewer
i recently bought a microwave coffe maker and it also has no instructions,,, help its from a company called colony...
Sep 19, 2009 | Faberware FCP240 Coffee Maker
Coffe/water dripping from handle when preparing coffee
On the inside of the basket is a line or ridge close to the top, that is your fill line. If you fill the basket to the top and tamp to that line then that should be perfect. For the portafilter it should be no more than a 90° angle with machine if it goes father then it is time to change the group gasket.
May 20, 2009 | FrancisFrancis! X1 - Stainless Steel...
Keurig Special Edition B60
I assume your coffe maker used to produce more coffee for each use. Roughly 6 ounces per large cup, and now is only making 3 oz. cups.
If your coffee maker is sputtering and not able to "suck" enough water to fill your cups of coffee it is most likely due to cavitation caused in the little pump due to a stoppage, which is most likely lime or scale buildup somewhere in the pump line.
To fix it, don't take your coffee maker apart. Get a bottle of distilled white vinegar, and pour it straight into the empty water resevoir. Press brew with no coffee pod so you are just running the vinegar through the system. Pour the vinegar out of the cup and back into the resevoir. Add some ice to cool it off. Repeat about 10 times. This should clear out the toughest lime scale clog.
After you notice the cups are filling full of water, Replace the vinegar with fresh water. Run about 5 or 6 cups of fresh water through the system to get rid of the vinegar.
Make coffee/tea/whatever.
Jade
Oct 06, 2007 | Keurig Special Edition B60 Coffee Maker
Bunn BT10B Coffee Maker Logo
48 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
evans_lloyd
Level 1 Expert
gbob59
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
