Question about Toys
I have a gemmy santa and penqin infatable train. the motor fan model ts-d-125 120volt 60 hz 1.04a cla 300 rpm has quit working. I need a repacement or something equal that will work. Where can i get one or do you have any suggestions.
  • borgds Nov 15, 2010
    I appreciate you prompt reply but must say I expected better for $12.00. I was hoping being a fix it site and as I gave you the specifications of the fan blower you may have been able to tell me what is a suitable equal and hopefully even beter the name of a place I could in the very least purchase on line. The solution you propose I had already considered and have not been able to find a satisfactory solution. Ebay had one on the US site but the dealer will not ship tinternationally. Can you do anythig to help if not I will just carry on hoping for find a solution.
  • 2,299 Answers
I would suggest looking in the phone book yellow pages and look up electrical wholesale houses. Call one of the ones locally. They will either have the replacement motor or will know a place to get the motor.
Posted on Nov 15, 2010
  • 2,382 Answers
Hi, you have a bad motor fan as you have rightly said and you need to replace it. You cannot get the motor fan part replacement from Gemmy (they don't provide such service), so the only option left is to remove the motor fan and take it to any electronic parts store to look for something similar that will fit in and use or get a new Gemmy.
Posted on Nov 14, 2010
I have blow up santa not a xmas globe
https://www.amazon.com/Gemmy-Airblown-Inflatable-Replacement-TH-BL3-N/dp/B00O0VIDZO
Nov 30, 2016 | Cars & Trucks
Generator low voltage
It could be several things but it sounds like it just running too slow. I would the engine rpms first. Depending if is a two pole or four pole and if your 60hz or 50 Hz on the needed unloaded rpms.
Example: 2 pole 60 hz. Engine needs to be running at 3600 rpm loaded and 3750 rpm unloaded; unless, it has a fuel saving mode.
A 4 pole 60 hz would running half this rpm. The 2 pole producing 50hz would have the engine running at 3000 rpm loaded (about 3100 rpm unloaded)
Now in order for the 50 hz system to produce the same output voltage it requires a different alternator than the 60 hz version; otherwords, You simply can't convert a 60 hz to 50 hz version without changing the alternator by changing the engine speed.
Dec 29, 2014 | Electrical Supplies
My gemmy santa claus stop dancing and head moves one way
Here are 2 reasons why he would have stop dancing 1.the motor inside the body might be dead 2.a wire came off of the motor for the head could could just be the motor is dying
Jul 08, 2014 | Gemmy Life-Sized Animated Santa
My life size santa sings but it sounds like a chipmunk when it does
The speed of the sound coming out of the chip is too fast. Perhaps it was designed in Europe where the frequency of their electrical network is 50 Hz It is 60 Hz here and may speed it up unless they designed a way to calibrate it. Chances are it was not thought out that well at the design stage.
Nov 29, 2013 | Gemmy Life-Sized Animated Santa
I need an instruction manual for gemmy lifesize singing and dancing santa
The shoulder thing worked! thanks so much!! i was all over that thing!
Dec 10, 2012 | Gemmy Life-Sized Animated Santa
I would like to know how many square feet a Model # BRCQ0421BD Serial # 990905429 Coleman Central Air Conditioning Unit will cover. The unit supply is 208-230V 1 PH 60 Hz 10.8 RLA 97 LRA.
The Old Rule of Thumb is 400 square feet per ton, but you really need to do a heat load calculation to be safe. A lot of windows on the west or south side of the house will really increase your load and you may need a lot larger unit. Insulation also changes your load so you may be able to cool a larger area. You may be able to get the Heat Load Calculation Form either online or from Johnstone supply. They are on the internet.
Aug 07, 2012 | Coleman Heating & Cooling
Need fan motor for gemmy airblown inflatable light show. i live in michigan city of warren 48088 where can i find the part? model#TS-D-200 please help thank you thomas bogdanski
Hi, unfortunately Gemmy Industries does not sell replacement motors for their inflatable products. However, motors can be purchased at www.holidayinflatablestore.com. Although Gemmy cannot provide any support to assist you in the process, Gemmy understand that collectors of the product have been able to take care of their replacement needs by purchasing older, inexpensive units from E-bay and then transferring the parts to the newer model.
Dec 08, 2010 | Gemmy Toys
Blow-up santa, lights go on and fan will not go on
blow-up santa, lights go on and fan will not go on
Dec 06, 2009 | Gemmy Toys
Finding a replacement circulator motor (???)
Replacement looks like it would be a fasco K612... the only difference is the 3000 rpm vs. 3200 rpm.
Apr 09, 2009 | Freezers
Toys Logo
929 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
