Question about Jandy Ae2500t 115,000 Btu Heat Pump
Jandy AE-TI H20 error message - pool not heating
  • 310 Answers
Just looked at the manual for this unit. It does not list an H20 code. Is this all it says on the screen?
Posted on Nov 15, 2010
Jandy ae heat pump
make sure wiring is correct for 220 volt or 115 volt and check fuses
Mar 20, 2013 | Jandy AE3000T AE-Ti Heat Pump 137K BTU
Jandy AE-Ti model ae1500t with a message "shorted h20 sensor" appearing and unit not running.
replace temp sensor mounted on side plumbing goes in with plastic black screw remove take out unplug and replace
Jan 22, 2013 | Jandy Pool & Spa
What is the pressure switch on a Jandy pool water heater AE-Ti
it tells the unit that the filter pump is working if you dont have voltage to both sides either bad pressure switch or plugged copper line
Dec 29, 2012 | Jandy Ae2500t 115,000 Btu Heat Pump
Where is the pressure switch on jandy pool water heater AE-TI
open front panel look for a white and copper triangular object with 2 wires connected and a copper tube
Dec 28, 2012 | Jandy Ae2500t 115,000 Btu Heat Pump
How do i fix H20 sensor on a jandy pool water heater AE-TI
remove the two black wires from the PCB board and remove the other part from the copper line going to the header where the pipes connect
Jandy AE.TI AE3000T .263 BOARD SHOW FAULT SHORTED H20 SENSOR
The H20 sensor is the Pressure Switch. Locate the pressure switch, remove the two leads and jump them together. If the error code goes away, you need a new switch. If not, it could be a software, or other hardware issue.
Jan 08, 2010 | Jandy Ae2500t 115,000 Btu Heat Pump
Jandy Ae2500t 115,000 Btu Heat Pump Logo
537 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
