Question about GPS
Garmin nuvi won't turn on
My nuvi 610/660 won't turn on unless plugged in. When it's plugged in it only goes as far as showing the sign that reads "Garmin Nuvi". garmin nuvi 650...turns on, but when I answer "yes" it shuts off
  • 1 more comment
  • jerroldb Jun 18, 2008
    updated firmware...still ng
    garmin gps 650...turns on, but turns itself off when I click "agree" or try to put any info into it. Have it plugged into car...no help.
  • jerroldb Jun 21, 2008
    where do i go to repair my nuvi?
    Sergeant:
    Champion:
  • 230 Answers
Try the hard reset method, that is , take the battery out and wait for half an hour and then put the battery and try this will help you
Posted on Jun 21, 2008
  • 4,472 Answers
Is the unit still under warranty as you may only have to pay for shipping?
Thanks,
lee
  • Lee A.
    Lee A. Jun 21, 2008
    http://www.portatronics.com/
    try here for having it repaired.
    Thanks and if you have a moment and found this helpful it would be greatly appreciated if you could accept and rate appropriately.
    Thanks,
    Lee
    Master:
  • 638 Answers
It can be batter problem or sometimes the battery is okay but the contacts of the batter on the board chip r loosened.just get it serviced n dry soldered n it will be back to work.even i had a same problem with my device few days back i doubted battery first n changed a battery but it didnt help so i was sure about the chip n just got it repaired n its working perfectly fine now.hope itworks for u too.
feel free 4 further assistance n keep sending more question n comments or doubts that arise in ur mind regarding this to me.rate the solution as fixya if it helps u understand n solve ur problem
Posted on Jun 18, 2008
    Master:
  • 788 Answers
Does it do the same thing if you try it plugged in but without the battery in the unit? Could be that your battery is faulty, replacement batteries are available from multiple sources on-line.
    Genius:
  • 3,422 Answers
HI,
Please do a hard reset of the unit.This will restore the factory default settings.
If you need anymore help let me know.
Goodluck..
  • Priya darshan Jun 18, 2008
    If you still face the problem then the issue is with the battery you'll have to replace it with a new one.
    Please don't forget to rate the solution.
  • Priya darshan Jun 21, 2008
    You can get it repaired from Garmin.For more details CLICK HERE
  • 298 Answers
It could be a problem with the battery. If its possible to change the batter try to do so. But if not, I suggest that you really need to contact your manufacturer's tech support for servicing.
  • Jeffrey Pedimonte
    Jeffrey Pedimonte Jun 23, 2008
    You can contact their tech support 1-800-800-1020. you need to get first a RMA no. before you can send it to them to get replaced/repaired. For more details you can check this link for more info about the repair.
    Master:
  • 555 Answers
Sounds like it needs a firmware update.
I have a Garmin nuvi 1450. When I plug the mini USB between the garmin and my laptop the units screen turns on but only goes to a page showing Garmin and a picture showing the device and a USB plugging...
Yes, it is normal. This is the data mode, where you now have access to the unit's internal flash drive. You can update your units map and firmware by registering your unit with Garmin on their website www.garmin.com.
May 11, 2013 | Garmin nuvi GPS
GpS gARMIN nUVI 40 ONLY SHOWS gARMIN NAME ON SCREEN AND WON'T DO ANYTHING ELSE
I have a similar nuvi model and this happened to me. I contacted Garmin who said that I need to update the software on my model. Plug your nuvi into a pc. Hopefully the pc will recognise the device and it will launch some Garmin web page. From there, read the instructions on the page and see if you can update the software. If there is no response from the device when plugged in, visit Garmin's website and find your device. There should be an option to update software. Try it this way. Hopefully this sorts the problem. I leave mine in the car a lot and in freezing conditions and while it does drain the battery a bit, I don't have the problem you are having. Good luck.
Feb 04, 2013 | Garmin nuvi 40 - GPS receiver
Any time I plug my Nuvi 205 into my car charger, it shows that it is in pc link mode. How do I get my Nuvi 205 to get out of pc link mode while it is plugged into my car? It renders the GPS useless as it...
Sometimes this problem is caused by the charger plug not going far enough into the mini usb socket of the satnav. It feels as if it's fully in but it's not. Pushing it in further usually solves the problem. As your charger is not a garmin make there's no guarantee but there should be very little difference so it's worth a try.
Mar 08, 2011 | Garmin nuvi 205 GPS Receiver
When using wire in car, Garmin won't turn on, it starts, shows a low battery sign and shuts down. Was working fine on recent trip. It seems no power is reaching GPS. Nuvi 765T
Most likely the fuse in the charger plug has blown. The plug that goes into the cigarette lighter socket has a ring near the end. On most chargers it's silver but some of them are black. If you unscrew this ring the plug comes apart. Be careful not to lose any parts. You'll see the fuse in there. Replace it and it should be ok.
The other possibility is that the cigarette lighter socket is not working. You can check that easily enough by trying something else in it.
Oct 14, 2010 | Garmin nuvi 765T GPS Receiver
My Garmin nuvi 780 will not turn on. When I turn on, the Garmin logo shows on the screen. However, when "Loading Maps" is displayed, 1-2 seconds later the screen goes blank. This occurs when the unit is...
I had the same problem. When you have your nuvi plugged into your cigarette lighter it doesn't charge. Your battery is probaly near dead. I called Garmin and they told me to plug it into my computer via the usb cable. Turn the Garmin off and let it charge for several hours. That did the trick
Apr 03, 2010 | Garmin nuvi 780 GPS
My garmin 200w shows garmin screen then goes black even with charger plugged in
sorry . some problem with your charger .try using another charger
Sep 20, 2009 | Garmin nuvi 200W GPS Receiver
Without plugged in my garmin nuvi 200 will not work
That means that you have to replace the battery.
The video on the link below shows how to replace the battery in a Garmin Nuvi:
How To Change The Battery On A Garmin Nuvi 760
Jan 21, 2009 | Garmin nuvi 200W GPS Receiver
Power cord doen not seem to recharge Garmin Nuve 680 in car.
to register my Garmin Nuvi. I want to get it registered, I tried before I'm not sure how far I got if it is registered or not
Jan 15, 2009 | Garmin Nuvi 680 GPS Receiver
New Garmin Nuvi 660 gps
Page 2 of your manual shows you that the plug goes into the bottom of the GPS unit. Turn it over and you'll see a slot for the plug.
Apr 21, 2008 | Garmin Nuvi 660 GPS Receiver
folks, the garmins have an on-board battery that needs to be powered up (at least occasionally) via the usb port - like from your computer. just using the dc car power cord does nothing for this battery. i've had this exact same problem on both my 760 and 780 nuvi units. fixed it using the usb charge. seems to run down differently for all the various nuvi models. my regular charge will hold for 7 hours on my old 660, my 760 and 780 work about 5 hours. my 'power up' failed on the 660 after 10 months with no internal battery charge, but the 7xx models only took about 5-6 months to 'fail.' hope this helps. jack b :-) in midland, tx usa
Jan 13, 2008 | Garmin Nuvi 660 GPS Receiver
GPS Logo
595 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
