Question about Husqvarna YTH21K46 (46") 21HP Lawn Tractor 960 43 0085
Tractor will not start not clicking in engine at all
  • 755 Answers
Confirm battery is fully charged with a load tester first.
then check your seat and brake pedal interlocks with continuity meter.
Posted on Nov 16, 2010
Solenoid clicks but starter does not kick in to start tractor
Clicking Sound While Attempting to Key Start - Riding Mower
troybilt.custhelp.com/.../clicking-sound-while-attempting-to-key-start---r...
Jul 19, 2002 - Why does the tractor make a clicking sound and not start? ... Thesolenoid connects the battery to the starter motor when the solenoid is energized. ...It can click, but not make a complete connection. ... Starting - Riding Mower · Professional Shop Manuals · Basic Troubleshooting - Lawn & Garden Tractors.
How Do I Tell If the Starter Solenoid Is Bad on My Kohler ...
homeguides.sfgate.com > Real Estate Advice > Basic Real Estate Advice
Most large Kohler engines on riding lawn mowers use an electric starting system. ... A bad solenoid can deny electricity to the starter motor and prevent engine startup. ...Lawn Mower Will Fire but Not Start · Replacing a Solenoid on a Craftsman Lawn Mower or Tractor · How Does a Starter Solenoid on a Lawn Mower Work?
My Bolens lawn tractor won't start. It just clicks when I turn ...
Dec 03, 2015 | Garden
Will a John Deere LA175 lawn tractor start without the mower attachment installed?
I wouldn't think so. I know you DO need the seat switch depressed in order to start the engine.
Oct 18, 2014 | John Deere Garden
Ford 601 tractor starting problems
Ok lets start at the start on this one. Which of the following best describes the situation?
- Turn key and nothing, no lights on dash, no noises.
- Turn Key and weak lights that flicker in start position and clicking noises
-Turn key, strong lights but little to no movement from engine or a strange noise comes when key is turned
-Turn key, strong lights, engine turns over but will not fire.
A tractor is a complex piece of machinery and something like an engine that will not start could indicate one of many problems, with some trial and error you can generally work out what the problem is be we need somewhere to start.
Aug 03, 2013 | Garden
Starter will click but does not turn. battery good
If the starter clicks but does not turn try hitting it light with a hammer. Seems odd but could help, helped me once with the starter engine in my car! It is something tot do with your start engine, wordt case you have to buy a new one.
Jun 14, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Won't start
battery flat.disconnect and put on charge
Jul 07, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
42 in. Deck 19.5hp Lawn Tractor: Craftsman Lawn tractor my engine clicks but will n...
battery has a low charge or the starting gear on the starter is bad. just remove cover and see if the starter ingages and cranks the fly wheel. look at the gear itself to make sure the teeth are good ,if not replace the plastic gear. takes 5 min.
May 18, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have craftsman tractor Model 917.272751. Now engine clicks but will not start. I checked Starter. It is good. What is the posible probelm? Thanks
If it just clicks and won't crank, most likely it is your starter solenoid.
You can verify this by "jumping" across the 2 large posts on the solenoid.
If it cranks doing that then the solenoid needs to be replaced
Oct 18, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Clicking noise
removed engine cover - found starter was hung up, this seems to have fixed the problem it starts and runs fine now.
Jun 01, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Won't start
it sounds like the battery doesnt have enough crankinc amps. thats a pretty big engine and should have probably have atleast 250 cranking amps. its possible the starter is going bad also
May 03, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Turn key and get a click
the started is probably jammed and needs to be unbolted and put starter bendix gear back in starting position turning over an engine too long on a jump start can cause this
Apr 02, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Husqvarna YTH21K46 (46") 21HP Lawn Tractor  960 43 0085 Logo
290 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
