Question about Sony Playstation 3 (PS3) Console
I can't get any kind of picture from my PS3 to my TV it just stays a blank blue screen (using a scart lead). The cable to the TV I'm using is fine as it is working on my PS2 and I don't have any red or yellow lights showing, it also takes and ejects dvds etc without any problems. Its and early 60GB.
  • 4,102 Answers
Hi, the problem you are having is with the settings on the ps3 or the video lead you are using, try switching the ps3 on at the back then hold down the on button will its switches itself back of doing this resets the video mode and should get it working for you.
let me know how you get on or if it dont solve the problem then i can asist you further ok
Posted on Mar 03, 2011
I was using my ps 3 on my plasma tv connected by a HD lead. I then hooked it up to another tv using a scart lead and now it won't work. I hooked it back up to the plasma tv and it works fine. I need it to...
Got to settings in the PS3 Crossbar and go to display settings. The first one should say video output settings, click on it. It should say your connection type is HDMI. Select component/D Terminal and hit change. The screen should go blank. During this time plug it in to your other t.v by the scart. It should say "Can you read this screen?" hit yes and there you go. To go back to HDMI do the same.
Jan 07, 2011 | Sony Playstation 3 (PS3) Console
Scart signal
check the tv mode av1 av2 and pal settings
Sep 05, 2008 | Televison & Video
Bought my ps3 when it came out been really good till naw . it will switch on disc will go in everything sounds like it works but i get no picture tried a new scart lead and still nothing.
  • If the video output settings on the PLAYSTATION®3 do not match those of the cable or TV in use, there may be no picture. If the screen goes blank, turn off the system.
  • Then, with only the PLAYSTATION®3 and the TV connected, touch the system's power button for more than 5 seconds to turn the system back on. The video output settings will automatically be reset to the standard resolution.
  • This is from playstations website Hope this helps.
    Nov 22, 2010 | Sony Playstation 3 (PS3) Console
    MY SCREEN IS BLANK MY TV IS NON HDMI AND SO WAS
    • Have your ps3 in standby mode (red light).
    • Now, press and hold the power button in the front down. Your ps3 will beep twice. Let it go almost exactly after you heard the second beep.
    • Wait 10-15 seconds. A display will show up, and just answer yes to all!
    Dec 30, 2009 | Sony Playstation 3 (PS3) Console
    Acoustic Solutions 26'' HD TV cannot play PS3 blue ray films
    I have recently brought the same TV and had the same problem but I've mangaed to find a soultion.
    The automatic setting for Blu Ray on PS3 is Full HD (1080p) but the Acoustic Solutions TV is HD ready (720p). For PS3 games it will automattically change settings for you to 720p. This is why this works straight away but Blu Ray doesn't.
    Solution
    You need to plug in your PS3 using the scart contection, then on the ps3 menu go to settings > display settings > HDMI. You will then need to attach the HDMI cable and manually set up
    HDMI by checking the 720p option and deselect 1080p.
    That should then play Blu Rays too. You don't lose too much quality as 720p works nearly as well as 1080p on smaller TVs.
    Rich
    Feb 18, 2009 | Televison & Video
    No sound through ps3 hdmi
    I have sound on video 2, and when on a static channel but not on the usual channel 3 which is TV. Just stoppen working one day and cant figure it out... Please help!
    Oct 19, 2008 | Televison & Video
    Connection problems
    Assuming you have connected the DVD to the component (red / green / blue phono) connectors at the back of the set, and the TV is set to EXT5 then the problem is a setting on the DVP5980.
    Check the Upscaling setting on the DVP5980 by pressing the HD UPSCALE button on the unit. Cycle through the options until you get a picture. The 30PF9975/12 is not fully HD compatible, so may only support the lower resolutions. (If any)
    If this does not work, connect the DVP5980 with the scart and power on the without a disc in the tray.
    Press Setup on the remote.
    Press the right arrow button twice to get to the VideoSetup Page.
    Move down to the Component setting an change from RGB to INTERLACE.
    Disconnect the scart and connect the component lead. Select EXT 5 on the TV.
    If the picture appears correctly, go back to the Video Setup Page and change the progressive option to On.
    Mar 09, 2008 | Philips 30PF9975 30 in. LCD HDTV
    Hi I recently played my ps3 on my friends tv using an hdmi lead and all was fine. Now i have returned home and tried to play my ps3 without the hdmi lead and it wont work can you help please.
    go back to your friends with your ps3 and change the tv settings on the ps3 back to scart output but also take your scart lead and have it plugged in at the same time. once you have selected scart output unplug the hdmi cable to make sure the settings are right. hope this helps you.
    Dec 26, 2007 | Sony Playstation 3 (PS3) Console
    Sony Playstation 3 (PS3) Console Logo
    66 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    shaun taylor
    marley mcelhinney
    juanmireles1
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
