Question about Waring CO1500 1700 Watts Toaster Oven with Convection Cooking
I have a CO1500 and I'm looking for the thermostat assy for it (the contacts are fused together). What is the part # for this assy and do you know where to purchase it?
    New Friend:
Try Partstown http://www.partstown.com/
Posted on Jan 18, 2015
You may have a problem. I have a CO1500B, and am trying to find parts for it. I have been told that their factory does not sell the parts separately. You can buy trays, rack, rotisserie parts, etc. No repair parts for oven itself though.
Posted on Mar 14, 2011
Breville smart oven no heat or convection fan. LCD and controls working and can hear the oven clicking on.
The fan probably operated on the heat... I would tackle the THERMOSTATS, heat elements (at least 2) and/or fuse first.
My favorite supplier, appliancepartspros, struck out on Breville
(never-mind) I'll add a couple of credible ones at the bottom.
Sears parts is a good information source... but very pricey ($$$$) for the EXACT SAME PARTS you can get elsewhere...
If you can determine from your OWNERS papers which part you want to try first... get the operating parameters... and and check with a volt meter (ohms scale... power OFF)... for continuity on the FUSE, heaters & thermostat.
There is a possibility your control board (PCB) is at fault... it seems to be getting scarce... Turn it over and look for a burned/broken solder joint.
http://www.ereplacementparts.com/breville-bov800xl-smart-oven-parts-c-116052_116061_116092.html
In any case... get three prices...
In the event that PCB is the issue I do recommend LOOKING TO SEARS because of their parts support and warranty...
Good luck (finding the FUSE).
Breville BOV800XL Smart Oven Parts
Parts and Accessories
Sears Appliance Parts
Mar 04, 2016 | Breville The Smart Oven Convection Toaster...
Have T4800 Convection Oven, need fan, motor and thermostat. Cannot locate any parts.
Not knowing where all you have checked, here is contact info for customer service for electrical appliances from Farberware: Electric Appliances
farberware-electric@saltonusa.com 1-800-233-9054
If that doesn't work, then here is an address that will give you a list of sites that carry oven parts:
netshoppers.com/search/index.php?phrase=oven+parts&uid=d5d00793c96dccbcaa9b5f3ca3d412cd&kuid=4c4a6ef184c15b7eeffee322a7d94921&src=7s
<a href="http://www.toasterandconvectionovens.com">ToasterandConvectionOvens.com</a>
Feb 16, 2011 | Farberware T490C 1500 Watts Toaster Oven...
No thermostat control......... oven always on...... Is thermostat serviceable ??
Please remove and check if there is any short in the wiring to the thermostat.It is important to replace with the same type/model as it is not advisable to repair unless for an emergency if the same type is not available, could be adjusted with a local one.
Please ceck with the help of multimeter for any shorts/ in the circuit. Hope this helps you Good day.
Jul 04, 2010 | Sunbeam 6198 Toaster Oven with Convection...
The broil element and bake element both come on set for Bake.
You are correct in your diagnosis. The selection switch has 2 sets of contacts that should only make one when on bake. The contacts internal to that fuse are most likely fused together, the other thing that could be going on is a short circuit in the wires to the selection switch causing the same problem. Typically a repair unless under warranty would be costly unless you are up for the challenge of replacing the switch and checking the wiring yourself.
Apr 20, 2010 | DeLonghi XU1837 Trilogy Bake 'N' Broil...
Blown microtemp fuse
Hi man, take a look here" http://www.tod.com/productdetail.asp?ProductID=30. I think u know what to do next ...
Apr 08, 2009 | Toastmaster TOV200 Toaster Oven with...
THERMAL FUSE BLOWN ON KITCHEN AID KCO100508 TOASTER OVEN. WHERE CAN I BUY A REPLACEMENT ? This Thermal fuse [ 206 degrees C ] is a ceramic housing mounted to a bracket near the oven wall. It contains a...
My KA KCO100508B blew its thermal fuse after 3 years. I found a replacemnt close to 206 centigrade for $2.60 at Appliance Parts Warehouse near my home in Smyrna, GA. Know what to ask for when you enter APW. They don't like selling potential fire hazards to novice repairpersons!
Mar 05, 2009 | Toaster Ovens
No broiler heat
its not a diode its a fuse a high temp fuse . there is a number on it with a "c" after it thats the temp it opens ..... you can jump it out with a small bare wire just to test your elements and thermostat . if the thermostat does not cycle this fuse will blow . do not leave it jumped out , this is just for testing . find one on line with the number . and high temp fuse ... good luck
Feb 05, 2009 | GE 168947 Toaster Oven with Convection...
Rotissere Toaster Oven Just Stopped Working
the problem is internal and it might be the fuse or the thermostat
Dec 05, 2008 | Euro-Pro 0.7 Cu. Ft. Convection Toaster...
Overheating
Try CG Industries in Chicago, IL - they rebuild a wide variety of electronic thermostats. Their number is 630-216-5050.
Feb 08, 2008 | Waring CO1500 1700 Watts Toaster Oven with...
Waring CO1500 1700 Watts Toaster Oven with Convection Cooking Logo
434 people viewed this question
Top Waring Toaster Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Waring Toaster Oven Expert? Answer questions, earn points and help others
