Hi sir i have asus p5 nmx having nvidia geforce 7050/nforce610i integrated graphic .it shows 390 mb total graphic memory in win 7with 1 gb ram .where it shows 780 mb useable ram .here i have chosen 256 mb buffer size from bios .so plz tell me how much graphic memor and use able memory it will show when i will use 2gb and 4 gb ram.
  • 75 Answers
512 for 2gb and 780for 4gb
in intergrated gpu,s the memory is borrowed from the main system memory however the actual intergrated gpu has some of its own memory,but this is normally only small such as 64mb or 128mb however it can borrow memory from the main system memory,something thats known as s.m.a(shared memory architecture)
there are also some dedicated graphic cards that borrow memory from the main system memory,these are known as "turbocache" with nvidia based cards and "hypermemory" with ati radeon based cards,however these cards are very rarely used now as they were not that efficent and in windows vista they score very low performance baseline scores
Posted on Nov 13, 2010
How do i remove/reduce my shared system memory from my Samsung R480?
Don't un-share it unless you buy more memory. It is only showing a total available of 3 gb.
Making more available memory you can use the page file sys.
http://www.tomshardware.com/answers/id-2709950/shared-system-memory.html
Mar 26, 2017 | Computers & Internet
Nvdia 9400 gt on P5GD1-TML/S
Yes, your mainboard supports up to 2GB of DDR memory. That does not change if you add a graphic card. Windows XP 32 bit can actually address up to 4 GB of total memory including CD, hard drives, and video cache.
Note: Your mainboard only supports up to 2 GB, but newer boards can support much more memory, up to 16GB of RAM.
If you could install 4 GB of RAM in your machine, it would still work, but windows would only address as much RAM as it can use; the rest would go unused, so it would probably show up as 3.5 GB of RAM then.
Jan 05, 2012 | ASUS GeForce Computers & Internet
I have AMD Sempron 140 on ASUS M2N68-AM SE2 motherboard, Strontium 1GB PC800 DDR2 RAM. But in system properties, the RAM is showing as 768 MB instead of 1024 MB (WinXP 32 bit). The dealer is saying the RAM...
Yes the dealer is correct that the 256 MB of your RAM is allocated to the video card of this computer since the unit has a built in NVIDIA GeForce 7025 Shared video memory (UMA)that uses 256 MB of your RAM , so if you like to maximize the use of your RAM you need to install a expansion video card.
Sep 07, 2010 | Computers & Internet
Sims 3 crashes
Hi. Well that is obvious if the memory as well as the virtual memory drops below the required level. Your VGA settings (Graphic Adapter) might also making the game crash. It is a good thing to disable AVG temporarily while you play the game. (Please let me know your System's specifications as well. Like RAM size, VGA size, Processor Speed and Hard Drive Capacity - Both free and used capacity. If you have default specs for the Dell I6400 no need to include). Otherwise it will use the memory and virtual memory to scan the activities of the game.
You have to keep some vacant area in your System Partition (In which you have install the Operating System). Virtual memory page file is 1.5 x the size of RAM. But you can increase the size. But you have to have a faster hard drive as well because it will be used more when you increase it. The other option is to upgrade your RAM (installing an additional RAM if the PC supports). Most of the modern games require way too high performance PCs. Most of the time RAM and VGA.
To increase the Virtual Memory:
  1. Right click on My Computer icon and go to Properties.
  2. Click on Advanced tab.
  3. Click on Settings under the category, Performance.
  4. Click on Advanced.
  5. Click on Change under Virtual Memory.
  6. Select a free Partition (Which had more than the size x 1.5 of your RAM)
  7. Select the option System Managed size if you do not wish to do it manually. If you want to configure manually, select the Custom size option and enter the size which I mentioned before in BOTH the boxes.
  8. Then click on SET.
  9. You may be asked to Reboot the machine. Do so if asked to.
  10. Then play he game.
  11. If possible please upgrade your RAM.
Sims 3 System Requirements are as follows:
  • FOR WINDOWS XP
  1. 2.0 GHz P4 processor or equivalent
  2. 1 GB RAM (512 should be enough however)
  3. 128 MB Video Card with support for Pixel Shader 2.0
  4. The latest version of DirectX 9.0c
  5. Microsoft Windows XP Service Pack 2
  6. This one is very important: At least 6.1 GB of hard drive space with at least 1 GB of additional space for custom content and saved games.
  • FOR WINDOWS VISTA
  1. 2.4 GHz P4 processor or equivalent
  2. 1.5 GB RAM
  3. 128 MB Video Card with support for Pixel Shader 2.0 (not enough)
  4. Microsoft Windows Vista Service Pack 1
  5. At least 6.1 GB of hard drive space with at least 1 GB of additional space for custom content and saved games
  6. For computers using built-in graphics chipsets under Windows, the game requires at least:
  • Intel Integrated Chipset, GMA 3-Series or above
  • 2.6 GHz Pentium D CPU, or 1.8 GHz Core 2 Duo, or equivalent
  • 0.5 GB additional RAM
  • FOR MAC OS X
  1. Mac OS X 10.5.7 Leopard or higher
  2. Intel Core Duo Processor
  3. 2 GB RAM
  4. ATI X1600 or Nvidia 7300 GT with 128 MB of Video RAM, or Intel Integrated GMA X3100.
  • This game will not run on PowerPC (G3/G4/G5) based Mac systems, or the GMA 950 class of integrated video cards.
Windows Supported Video Cards NVIDIA GeForce series FX 5900, FX 5950 6200, 6500, 6600, 6800 7200, 7300, 7600, 7800, 7900, 7950 8400, 8500, 8600, 8800 9300, 9400, 9500, 9600, 9800 G100, GT 120, GT 130, GTS 150 GTS 250, GTX 260, GTX 280, GTX 285, GTX 295 ATI Radeon™ series 9500, 9600, 9800 X300, X600, X700, X800, X850 X1300, X1600, X1800, X1900, X1950 2400, 2600, 2900 3450, 3650, 3850, 3870 4850, 4870
Intel® Graphics Media Accelerator (GMA) GMA 3-Series, GMA 4-Series
Laptop versions of these chipsets may work, but may run comparatively slower. Standalone cards that are installed in vanilla PCI slots (not PCIe or PCIx or AGP), such as some GeForce FX variants, will perform poorly.
Integrated chipsets such as the ATI Xpress and the NVIDIA TurboCache variants may default to settings that are higher than what would be optimal for them. Graphics settings can be lowered to improve performance.
The NVIDIA GeForce FX series is unsupported under Vista. MAC OS X Supported Video Cards NVIDIA GeForce series 7300, 7600 8600, 8800 9400M, 9600M GT GT 120, GT 130 ATI Radeon™ series X1600, X1900 2400, 2600 3870 4850, 4870 Intel® Graphics Media Accelerator (GMA) GMA 3-Series.
So make sure to meet at least the minimum requirements.
Enjoy Gaming.
Please feel free to ask anything related to this. Please rate the answer as well if you feel that it helped to solve the issue.
Thanks for contacting Fixya!
Jul 10, 2010 | Dell Inspiron 6400 Notebook
Need specs
Systemax Ascent KMA3500 Desktop
Processor :AMD Athlon 64 X2 2.3 GHz
Installed Memory :2 GB (DDR2 SDRAM)
Operating System :Microsoft Windows Vista Business
Video Output Interface :PCI Express
RAM :2 GB
Max Supported RAM :4 GB
Installed Video Memory :128 MB
Supported RAM Speeds :800 Mhz
Hard Drive :160 GB
Hard Drive Interface Serial ATA II
CD / DVD :CD-RW/DVD-ROM (Combo)
Graphic Processor NVIDIA GeForce 6100
Integrated Audio Realtek ALC833
Networking
Networking Type Integrated 10/100 Network Card
Dec 18, 2009 | Systemax Ascent PC Desktop
Loss of Ram in D102G intel Board
hello, you just have a shared memory with the on-board ati graphics, if it's on- board graphic card it shares the system memory-most are adjustable through the system bios-in 64,128,256 settings. and if you put more memory, in most cases it will automatic-raise the memory size of the graphics memory. i hope this helps you, all the best. if you need further assistance reply. don't forget to rate this solution.
Mar 25, 2009 | ASUS P4B533-VM Motherboard
"Call of Duty" runs in slow motion on my PC.
Hi thomas,
Upgrading video cards will definitely increase in performance. You asked whether you should upgrade your entire PC or just the card and that really depends on the hardware you are running. If all of your hardware just barely meets the requirements than upgrading the videocard WILL give you a noticeable improvement but obviously it will not be as good as getting a better CPU and more RAM as well as a new card.
A good measure of a cards performance is based on the series of cards it is from. Your Geforce is from the 6000 series of Nvidia cards, they have 7000, 8000, and even 9000 series cards atm.
I would recommend something like an XFX Geforce 9800 GTX+ series card with 512MB of onboard memory, or any other competing card in the 200$ price range. This will definitely give you an increase in performance, and is a very popular card.
Hope this helps and please take a second to rate!
Mar 20, 2009 | HP Pavilion a1610n PC Desktop
Would like help with what the optimal gaming settings are
Got free help somewhere else and problem solved
Nov 11, 2008 | Computers & Internet
Computers & Internet Logo
73 people viewed this question
David Payne
David Payne
