Question about Husqvarna Garden
Pull cord is not engaging - it is 'freewheeling'
  • Husqvarna Master
  • 1,807 Answers
Possibly a problem with the stater pawl, you will need to remove the starter recoil and investigate.
Posted on Aug 02, 2013
A PTO that is engaged constantly,
On that type PTO engagement there is slack in the belt that disengages the deck, in some case there is a arm with a idler pulley that swings against the belt to tighten it and engages the deck , in other cases like older MTD:s the deck swung backwards as it was let down and tightened the belt and was lifted to turn it off. Most of the decks had a brake of some kind on the deck pulleys to stop freewheeling of the blades when disengaged .
May 26, 2016 | Garden
The red light flashes 5 times scooter will not move
I would look at the freewheel lever. Disengage and then engage the freewheel and see if this corrects the problem. If not, you may have a bad freewheel switch.
Apr 10, 2014 | Drive Medical Phoenix 3 Wheel Compact...
Pride gogo think is in freewheel when it isn't
There is a micro switch that the lever engages to tell the controller the position of the lever. It's either not closing properly or is defective.
Feb 08, 2014 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
I have a go go elite traveller plus , the battery pack will not lift off my scooter it seems to be stuck , i need to replace the batteries
The manual for this scooter is at http://www.discovermymobility.com/store/scooters/summit-scooters/elite-portable-scooter/manual.pdf
The closest info I can find is page 14. MOVING AND TRANSPORTING YOUR Easy Travel Elite
6.1. Moving Your Easy Travel Elite in Freewheel Mode when unfolded:
The Freewheel switch (Fig. 1/17) is used for releasing the brake and moving the Easy Travel Elite without operating the motor. Before activating, make sure your Easy Travel Elite is switched on. Turn Freewheel switch to the "freewheel" position and push or pull the Easy Travel Elite manually.
NOTE: The Freewheel mode can only be activated after the battery is in place and the power switch (Fig.9/1) is turned on. Doing otherwise will cause a fault situation indicated by rapid flashing of the Indicator light (Fig. 9/4). See section 4.2.
WARNING: The Freewheel switch should never be engaged on a slope.
CAUTION: The seat back must remain in the upright position.
They seem to assume removal is obvious, I would check any connections from battery to scooter are pulled out and that freewheel mode is not engaged.
Oct 07, 2013 | Pride Mobility Products Go-Go Elite...
Freewheel not locking in
The pawls (small spring activated plates) inside the freewheel body are stuck down and cannot spring back up to engage the gear body.
This is usually caused by oxidation and moisture.
This is a long term issue, the freewheel really should be replaced. It may randomly work if you can get a lubricant to penetrate into body, but this is normally a short term solution.
Most freewheels from Sram or Sunrace will run about $20.00.
Dec 26, 2012 | Mongoose Mens Xr250 Bicycle Grey 18-Inch
How to place freewheel control into engaged position
there is a rod that hangs out above the hitch you pull it out and move it into a released position when done release and push it in
Jul 01, 2012 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
Rear sprocket turns but the wheel does not engage the bike is a 26" cruiser windwood model. looking for a exploded view of the rear axle
The freewheel has little arms that are spring-loaded and should engage teeth that would drive the wheel. This is exactly like a ratchet wrench. The problem is that those little arms (there are probably two of them) are either broken or they are too dirty to move. You can spray WD-40 into the groove that is about 1.5 inches in diameter. This may work to free those little arms. Or you should just buy a new freewheel. It is unlikely that you will be successful in disassembling the freewheel without special tools. Try this link for some information about freewheel removal and service. http://www.parktool.com/blog/repair-help/categories/cassette-and-freewheel-service good luck, AL K
Sep 01, 2011 | Cycling
Gears do not engage.\r\nis in freewheeling mode
If you remove the wheel can you spin the gear cluster forward with no resistance? Does it ratchet when spun backward? If yes and no, the hub is shot.
Jun 06, 2010 | Huffy Blackwater Men's 26-Inch Mountain...
LED Flashes 5 times - Brake in freewheel or brake connection problem. How can I fix this?
Brake in freewheel means that your scooter is not fully in gear, it must be 'set in the engaged (Fully forward) position.' See page 24 of the manual for your model, (Link below to the pdf if you need it) but if its anything like mine it just didn't click in properly. Roll it back and forward a few inches, and it should 'click' like the seat in the car when you change its position. If freewheel is not the problem (if it can't be rolled and is definately in gear) check all plugs and cords are tight in sockets, you may have a brakes problem. In this event it must be looked at by an expert. Stay safe!
http://www.rentascooter.com/downloads/_manuals/goldentechnologies/Golden%20Technologies%20Buzzaround%20Lite%20Owner%27s%20manual.pdf
Hope this helps:)
May 04, 2010 | RTO Golden Buzzaround Lite Scooter Meets...
Craftsman 20HP , can't stop freewheeling,
Sounds like your problem is the key in your rear wheel is missing or sheared, you have to remove the wheel @ tire assembly ,pull rubber cap off then clip to remove if one of the keys is sheared or gone it will go into gear and the brake will work ,but they will only stop the shaft without the key it will not move or brake becuase its not attached if you know what I mean.
May 11, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Garden Logo
120 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
