Question about Ariston Technologies Ovens
My Ariston oven FV 271 FV242D is 12 years old, never had a problem, but recently the oven would not come on but the digital display was set to zero and flashing so i thought i had had a power cut recently. I followed the booklet instructions and the oven started but stopped after a few minutes and the clock flashed again. This repeated itself a few times until the oven worked ok. Today i want to use the oven but the clock is on flashing auto 0000 and when i try to set the clock it makes a loud click and refuses to be set. One attempt to set the clock worked but the oven tripped out after about ten seconds. Thanks. William
No solution I'm afraid, just exactly the same problem, have you managed to fix yours?
Posted on Dec 17, 2010
  • hy10tp Dec 17, 2010
    Scratch that I appear to have fixed it, it was a loose connection in the back of the timer. I just had to pull the oven out, take the fascia off and press the back of the timer a few times, at which point the timer started working again.
F12 error flashing on the display
Keyword Ranking Analysis for ARISTON OVEN FAULT ...
www.webstatschecker.net/stats/keyword/ariston_oven_fault_code_f12
Keyword Ranking Analysis for ARISTON OVEN FAULT CODE F12 ... fixya.com.Ariston Technologies Ariston AWD120WH - "F12 error code" issues
Aug 18, 2015 | Ariston Technologies Ovens
Hi my Ariston oven shows in the display error 07. I have an ariston oven FZ 87.1 (IX)
problem je v nedostatku vzduchu pri ventilatori,treba viac priestoru pre ruru
problem is the lack of air when fan, need more space for tube
Jun 29, 2011 | Ariston Technologies Ariston FO98P...
Hi Experts! I'm having problems with my Ariston FO87CIX oven. The oven turns on but if I try to set the temperature the oven turn off and the time resets. It's weird but I've worked out that any...
One of 2 things, either the pt100(sensor) is faulty, or the control is defective. Unfortunately you need a digital multimeter to check the sensor first. When in doubt, replace both and all will be well.
Sep 09, 2010 | Ovens
Oven turns off if too hot
There is a temperature switch that shuts the power down if the temperature goes too high. This is to prevent a fire if your thermostat sticks on. Sometimes the switch will become weak and open the circuit at too low of a temperature. Replacing the switch should solve your problem.
If you need more assistance, post a comment with the model and s/n of your stove.
Thanks,
Tim
Jun 28, 2009 | Ovens
Ariston oven error code F8E0
solved by rotate the temperature knob!!!
maybe would be a problem of the potentiometer or knobe of temperature
Jun 28, 2009 | Ariston Technologies Ovens
Marking have worn off on front cover of ariston FM 22 M IX - oven
Try using ovenlettering.co.uk - I recently had same problem the symbols are easy to apply and look great. A brand new oven in minutes, speak to Mark - he can guide you through the process - very helpful
Mick Lawry
May 17, 2009 | Ariston Technologies Ariston FO98P...
Old Gaffers& Sattler oven won't heat up. I suspect timer setting?
The most common failure in any electric oven is the heating element.
Jun 20, 2017 | Ariston Technologies Ariston FO98P...
DOUBLE OVEN,GAGGENAU
this oven could be in display mode this only allows non harmful functions to work eg lights etc but no heat this can be disabled through clock test prog reset but you will need an engineer to do it as complicated.
ring 08705 678910 for service and advise
good luck
Dec 16, 2007 | Gaggenau EB 270/271 Electric Single Oven
Ovens Logo
966 people viewed this question
Top Ariston Technologies Ovens Experts
ashburton
Samuel O'Donoghue
Are you an Ariston Technologies Oven Expert? Answer questions, earn points and help others
