Question about Yard Machines Red Edger
Idles rough - Yard Machines Red Edger
  • Yard Machines Master
  • 7,482 Answers
Check your fuel filter in the fuel tank,if you have one.
If the mower/weedeater is over a year old, then I recommend that you buy
and install a new carburetor repair kit,because the diaphragm will get hard
and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor
internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small
rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid
and letting it run a few times like that and it will flush the gunk out of
the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to
reassemble the carburetor or follow the instructions you get with the
carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need
to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes
to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first
and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on Dec 05, 2010
2010 Malibu LTZ rough idle
I would check the throttle body, where the fuel mixes with the air also clean all pipes/connections etc after that you should know where to go next, but give the "plate" inside where fuel and air mixes, carb
Jun 11, 2013 | Chevrolet Malibu Cars & Trucks
92 dodge 1500 pick up 360 v8 automatic Starts, runs but hesitates, low power code 37 on diagnostic readour
Code 37 is torque converter clutch solenoid failure. Transmission wont shift in and out of overdrive.
Nov 28, 2012 | Dodge Cars & Trucks
Ford Taurus idle missing
It can be issue with IAC( idle air control valve) causing the problem.
There are many other possibilities causing these idle issues.Engine idles rough.
There are few help links with solutions to troubleshoot such idle issues.
I suggest you refer the link below and follow its troubleshooting details:------
Click the link below:-----
Bad miss at idle? http://technoanswers.blogspot.com/2012/01/bad-miss-at-idle.html
Stumbling and stalling at idle after engine rebuild?
http://schematicsdiagram.blogspot.in/2012/03/stumbling-and-stalling-at-idle-after.html
1999 Ford F-150 Idles rough and quits when gas pedal is pressed less?
http://technoanswers.blogspot.in/2012/01/1999-ford-f-150-idles-rough-and-quits.html
Engine stumbles coming off idle when warm?
http://repairhelpcenter.blogspot.com/2012/01/engine-stumbles-coming-off-idle-when.html
Erratic idle on car?
http://schematicsdiagram.blogspot.com/2011/12/erratic-idle-on-car.html
Cold start problem and vehicle shudder around 2500 to 3500 rpms
http://repairhelpcenter.blogspot.com/2012/10/cold-start-problem-and-vehicle-shudder.html
Low idle when cold out side?
http://repairhelpcenter.blogspot.com/2011/12/low-idle-when-cold-out-side.html
GMC Sonoma Stalls and idles low
http://technoanswers.blogspot.com/2012/10/gmc-sonoma-stalls-and-idles-low.html
GMC Idle Air Control (IAC) Valve Replacing?
http://schematicsdiagram.blogspot.com/2011/12/gmc-idle-air-control-iac-valve.html
1996 Camry intermittent engine failure while idle?
http://repairhelpcenter.blogspot.com/2011/10/1996-camry-intermittent-engine-failure.html
Engine quits at idle?
http://repairhelpcenter.blogspot.com/2011/10/engine-quits-at-idle.html
Car overheats and Air blows hot at idle?
http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
High Idle Problem
http://repairhelpcenter.blogspot.com/2012/10/high-idle-problem.html
While stop engine idles like cylinder missing?
http://schematicsdiagram.blogspot.com/2012/01/while-stop-engine-idles-like-cylinder.html
Idle flair is noticed on car? Rough idle? car will not idle? Erratic idle speed?
http://technoanswers.blogspot.in/2012/02/idle-flair-is-noticed-on-car-rough-idle.html
High rpm in neutral? Inconsistant high RPM in neutral?
http://technoanswers.blogspot.in/2012/02/high-rpm-in-neutral-inconsistant-high.html
Vehicle stumbling at idle and shows code 54?
http://schematicsdiagram.blogspot.in/2012/03/vehicle-stumbling-at-idle-and-shows.html
Rough idle, staling and Erratic shifting?
http://technoanswers.blogspot.in/2012/03/rough-idlestaling-and-erratic-shifting.html
These details will help.
Thanks.
Nov 24, 2012 | 2001 Ford Taurus
My Chevy 2500, 2001 runs rough when it cold outside
It can be issue with low fuel pressure,the fuel pump is getting old both needs to be checked.Also get the IAC valve checked.
Go through the related help links with similar problem,it may help:---
Click the links below:---
Engine Idles Rough and Dies? http://whatisbyme.blogspot.in/2012/05/1994-lexus-es300-engine-idles-rough-and.html
van idles rough? http://howtobyme.blogspot.in/2012/01/2004-ford-freestar-van-idles-rough.html
runs lean and idles rough? http://technoanswers.blogspot.in/2012/02/ford-runs-lean-and-idles-rough.html
Car still runs Rough after tune up?
http://howtobyme.blogspot.com/2011/12/car-still-runs-rough-after-tune-up.html
2006 kia rio runs rough http://technoanswers.blogspot.com/2012/10/2006-kia-rio-runs-rough.html
Idle flair is noticed on car? Rough idle? car will not idle? Erratic idle speed? http://technoanswers.blogspot.in/2012/02/idle-flair-is-noticed-on-car-rough-idle.html
Rough idle, staling and Erratic shifting? http://technoanswers.blogspot.in/2012/03/rough-idlestaling-and-erratic-shifting.html
Thanks.
Nov 06, 2012 | Cars & Trucks
Car wont idle
There re few possibilities that can cause no idle issues.To troubleshoot the issue help links are provided below.Click the link below:---
Idle Problem? http://whatisbyme.blogspot.in/2012/05/2001toyota-corolla-idle-problem.html
Idles rough and quits when gas pedal is pressed less? http://technoanswers.blogspot.in/2012/01/1999-ford-f-150-idles-rough-and-quits.html-----------
Stumbling and stalling at idle after engine rebuild? http://schematicsdiagram.blogspot.in/2012/03/stumbling-and-stalling-at-idle-after.html
Cooling fan Shuts OFF and Idle Drops? http://howtobyme.blogspot.in/2012/05/toyota-celica-cooling-fan-shuts-off-and.html
Rough Idle and Vibration? http://whatisbyme.blogspot.in/2012/05/2006-ford-f150-rough-idle-and-vibration.html
Steering Wheel Vibrates at Idle? http://whatisbyme.blogspot.in/2012/05/1993-toyota-corolla-steering-wheel.html
Runs Fine But Idle Is Low? http://whatisbyme.blogspot.in/2012/05/2004-toyota-highlander-runs-fine-but.html
Vehicle Will not hold Idle? http://whatisbyme.blogspot.in/2012/05/2003-lexus-es300-vehicle-will-not-hold.html
This will help.
Thanks.
Jul 17, 2012 | Cars & Trucks
Car idols rough no power
Mar 03, 2012 | 1999 Suzuki Esteem
92 NISSAN WITH BOGGING AT 2800 3500 RPM AND AT LEVEL SPEED 4CYL AND 5 SPEED
For this types of problem,there are few help inks to troubleshoot the problem.Click the link below to go through the troubleshooting procedure to resolve the issues :----Idles rough and quits when gas pedal is pressed less? http://technoanswers.blogspot.in/2012/01/1999-ford-f-150-idles-rough-and-quits.html-----------van idles rough? http://howtobyme.blogspot.in/2012/01/2004-ford-freestar-van-idles-rough.html
--------------runs lean and idles rough? http://technoanswers.blogspot.in/2012/02/ford-runs-lean-and-idles-rough.html
-----------Car still runs Rough after tune up? http://howtobyme.blogspot.com/2011/12/car-still-runs-rough-after-tune-up.html
------------Idle flair is noticed on car? Rough idle? car will not idle? Erratic idle speed? http://technoanswers.blogspot.in/2012/02/idle-flair-is-noticed-on-car-rough-idle.html
----------High rpm in neutral? Inconsistant high RPM in neutral? http://technoanswers.blogspot.in/2012/02/high-rpm-in-neutral-inconsistant-high.html
------------Engine Backfires? http://technoanswers.blogspot.in/2012/02/jeep-backfires.html----------- Nissan stalls and bucks on Acceleration?
http://technoanswers.blogspot.in/2012/02/nissan-pathfinder-stalls-and-bucks-on.html
Nissan Pathfinder Backfires? http://technoanswers.blogspot.in/2012/02/nissan-pathfinder-backfires.html
---------How to adjust rpm? http://schematicsdiagram.blogspot.com/2011/12/how-to-adjust-rpm-on-2009-dodge-charger.html
------------Engine cuts out at 3000 RPM? http://schematicsdiagram.blogspot.com/2011/12/engine-cuts-out-at-3000-rpm.html
----------This will help.Thanks.
Feb 17, 2012 | 1992 Nissan Pickup
Yard Machines Red Edger Logo
95 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
