Question about LG Audio Players & Recorders
I have an LG FB 162 stuck in the CD/DVD mode. Regardless the efforts done by unplugging and replugging the unit all is working fine except the fact that i cannot get out of the CD/DVD function. Your help will be highly appreciated
  • 130 Answers
SOURCE: System unresponsive when modes are switched
Arnt they seperate things? ive seen some systems that dont function if thery are not in that mode. If its in DVD mode nothing on the DVD works, if its in the radio mode maybe the power changes over to the tunner only? you cant play both at once maybe their idea. Will things work when its in the cd mode? Is the unit staying cool?
Posted on Apr 13, 2006
simplemitch
  • 752 Answers
SOURCE: Pioneer X MT- 2000 Stereo Bookshelf Unit - No sound!
It definitely sounds like it took a surge. yhe Power Amop IC in those things are pretty sensitive. Any decent repair shop should be able to repair it for under $125.
Posted on Sep 18, 2007
SOURCE: stuck in "safe" mode
Hold down power on vcr/dvd unit or the remote for 8 seconds. It turns the SAFE mode on or off.
Posted on Dec 16, 2007
melnavz
  • 1226 Answers
SOURCE: LG LS50 DVD/CD-RW DRIVE won't recognize blank dvd-r
Yes does not read DVD-R because if your LS50 Labeled like this (DVD/CD-RW) means that can read only all DVD Disc and cannot write on DVD blank only CD blank.
You can burn only on the blank CD-RW or any blank CD.
Posted on Jan 17, 2008
SOURCE: Unit totally locked up
CALL 1-877-805-0519
I just called, if I mail it back, they will send a replacement. I also mentioned I have a VHS & DVD stuck in it, and was told to have it removed by a repair shop, and they would reimburse me up to $20.
Posted on Apr 28, 2008
Lg mini home theatre model FB 162 dvd door will not open dvd's will not play will not play
look for a tiny hole in the dvd door; insert a straightened paperclip into the hole; push in; the door will open then clean the laser lens with a dvd cleaning disk by running the disk in the machine
Feb 18, 2013 | Audio Players & Recorders
LG MINI HOME THEATER FB 162 - SOUND PROBLEM
I have a question. The system refuses to change function and is stuck on DVD player
Feb 21, 2012 | LG Audio Players & Recorders
How do i get my th-a9r to play dvd-rw
You can't. The Laser will only Play +R & +RW.
Non-playable discs
• DVD-ROM • DVD-RAM • DVD-R • DVD-RW
• CD-R* • CD-ROM • PHOTO CD • CD-RW*
* Audio formatted CD-R and CD-RW can be played.
• Playing back discs list as "Non-playable discs" above may
generate noise and damage speakers.
Apr 23, 2011 | JVC TH-A9 System
Cannot detect dvd/cd and it cant work
unplug data lead,turn on pc,then turn off,replug in data lead and the pc should see the drive.
Aug 02, 2010 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
I have a Sony RDR-GX360. Some how I have changed the command mode from DVD1 to DVD 3. Now my remote has frozen and I can't do anything with the DVR player. Is there a reset button or please help.
To fix the Sony remote dvd-1 dvd-2 dvd-3 issue is to take the remote for that recoreder into another room or unplug the dvd recorder a moment. Then hold down the enter key and the number of the mode its stuck in ie if its stuck in dvd-1 mode hold down the enter key and then the 1 key. hold both buttons together for 3 seconds. After this go back into the room and try it or if you unpluged tthe player replug it back in. The remote has to be away from the player to work. again example
get away from player different room so it can not sence remote. Hold down enter and 1 button for 3 seconds and then try it
if its stuck in dvd-2 mode dold down enter and the number 2 button together for 3 secondsd and try it. The idea is you have to be far away from the recorder so it dosent recieve any inputs from the remote while doing this.bigsmile.gifclap.gifagreed.gifpuh2.gifbowdown.gifeek.gif To fix the Sony remote dvd-1 dvd-2 dvd-3 issue is to take the remote for that recoreder into another room or unplug the dvd recorder a moment. Then hold down the enter key and the number of the mode its stuck in ie if its stuck in dvd-1 mode hold down the enter key and then the 1 key. hold both buttons together for 3 seconds. After this go back into the room and try it or if you unpluged tthe player replug it back in. The remote has to be away from the player to work. again example
Mar 08, 2010 | Sony RDR-GX360 DVD Recorder
My Sony DVP CX860 DVD/CD player is jammed
You can unscrew the top panel. (Two screws on either side, three along the top in the back.) That will allow you access into the unit.
Inside the unit the lense and spindle are encased inside a shell in the center. If there is a disc jammed in there it will require some effort to get it out without damaging your machine. Be sure that it is unplugged to avoid a shock and I would simply attempt to fish it out through the front or back slot.
There's also the possibility that if you unplug it and replug it, the machine will eject the disc if you loosen it up or get it back on track.
Aug 19, 2009 | Sony DVP-CX860 Multi-disc DVD Player
DVD/VCR Combo Stuck in VCR Mode
i could probably walk this one through chat at idahoredfoxusa@yahoo.com
Jun 04, 2009 | Toshiba SD-V394 DVD Player/VCR
Samsung ht-ds610 wont work at all
Loading mechanism is stuck some where in loading or unloading process.
Unplug unit form AC outlet for couple of minutes and replug back in, power up and check.
Feb 11, 2009 | Samsung HT-DS610 System
Power saving mode knocks the computer out, have to restart
I have an LG Flatron 19" black w1952TQ that I bought on 2 Apr 2008; when it goes into sleep mode, will not recover. Did the online troubleshooting, reseting things, unplugging/replugging all cables, nothing works except restarting the computer, and that only works until it sleeps... Read more
Aug 05, 2008 | LG Computers & Internet
Hotpoint wt960p lcd display very dim ...machine works fine otherwise
Assuming that there is no provision for a panel darkening mode...the panel LCD is probably bad. You might try accessing the unit and unplug/replug in each connector. Sometimes, this will help. Be sure the wall plug is removed before doing this.
Mar 31, 2008 | Hotpoint Ultima WF860 Front Load Washer
88 people viewed this question
Top LG Audio Players & Recorders Experts
Electro Med Services...
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
