Question about Sony PlayStation Portable (PSP) Console
Inposible I followed you intructions but it saidthe attempt to obtain the IP adress timed out. help me
    Sergeant:
  • 243 Answers
Did you select to have security for the connection? If so, you probably entered the wrong security key.
Posted on Jun 18, 2008
  • Nathan Ayers
    Nathan Ayers Jun 18, 2008
    A Connection Error has Occured. The attempt to obtain the IP address timed out.
    - If using the PPoE,You entered a wrong username or password.
    + Check your username and pass
    + Check if you have internet connection.
    + Enable your DCHP server.
    + Restart your router.
    + Be sure to check your IP address and Primary/Secondary DNS to match what in your computer.
    + Check your WEP password if you correctly typed it.
    I found that inputing the SSID manually instead of scanning sorted out
    the problem. Im not sure if it'll work for you, but who knows. You may even have to turn wep off for it to work if you have the 3.90 updates......
My ip adress is gone of laptop how do i fix it
Normally IP Address is assigned by your router which then also provides gateway and dns settings. On the IP address screen, select Obtain automatically for both IP and DNS.
If this does not solve your problem, please explain fully what the problem is.
May 12, 2011 | ip-adress.com
When i try to connect to the internet on my psp it says my
Hi! At This Time : I use WPA PSK encryption simply because it is the only one i can work out how to set up and the PSP will not support this which is why i disable encryption while using it! But : i had that error. wut I did was (u can do this from in the game or in network settings) delete the one that should be working. did it all over again and this time I scanned for a connection. when I found my connection, I used it. and i redid the connection and it worked when I tried it again. Fix-sha0w
Jul 14, 2010 | Sony PlayStation Portable (PSP) Console
How ya going im tring to conect my play station3 to the internet and when i try to obtain my ip adress it keeps saying attempt timed out
r u using a router?? if so then u have to reset ur router settings it seems like u set ur router to have a specific IP address, u have to leave it givin way IP's automatically
Jun 03, 2010 | Sony Video Game Consoles & Games
Need ip address for syrens, not sure if i remember right: 192.168.1.1???
Hi Stephan,
the ip address of your router by default should be "192.168.1.1". to check if the ip adress of your router here's the solution :
  1. go to control panel > network and sharing/networking >change adapter settings
  2. then you'll see your local area connection
  3. right click on it>properties
  4. double click on (internet protocol tcp/ip) "tcp/ipv4 in windows vista/7
  5. the select "obtain ip address automatically" & "obtain dns server464142c.jpg automatically" click ok and click ok for the other window
  7. the dns server ip show should be your router ip adress
  8. open your web explorer and type in your router ip an press "enter" you'll get your router configuration where you'll be able to change the default ip.
I hope that it will help & don't forget to rate
Kind regards
Feb 14, 2010 | Sea and Sea Syrens OnBoard WiFi...
Attempt to obtain IP adress failure
contact your internet provider and have them unlock your IP address
Aug 24, 2009 | Dmm Call of Duty: World at War
Cant connect to http://192.168.0.50
what you need to do here is manually set your static IP adress, I had this problem as well and I know what to do.
you need to go to your network connections ( Controll panel>network connections) in xp (Controll panel>network and sharing center then left hand it sais: change adapter settings )
then rightclick your wireless connection and look at it's properties. then you need to click on Internet Protocol, for vista/windows 7 it's internet protocol 4 which you need to select. once selected click on properties just a little below.
there you'll see the setting is on: obtain Ip automaticly, but you'll have to choose ( use the following IP adress ) and enter
IP adress: 192.168.0.99
subnet mask: 255.255.255.0 Default Gateway: 192.168.0.50
once entered press OK and now go to your browser and type the routers adress (192.168.0.50) in my case and now you should be in your modems setup menu.
once changed your setting you need to change your IP back to auto obtain IP adress. or your internet still won't work
Oct 20, 2008 | D-Link AirPlus Xtreme G DWL-2000AP...
Ps3
wired conection , connection test fails obtain ip adress connect but connection internet failed.
Oct 07, 2008 | Sony Playstation 3 (PS3) Console
Driver help...Anyone?????
For Router drivers is not required ,U can configure though the command prompt
I can tell some configuration try it,
the default ip adress of the router will the 192.168.1.1 OR 192.168.0.1
In your Lan card configure,
1. obtain Ip adress automitically
go to command prompt----type ---ipconfig---check the ip address which ip is getting---
go to internet explorer ----type the ip address in adress bar-----------login page will get---
login as, user name admin
password admin------configure your internetip adress & DNS ip address,save & check.............
Mar 21, 2008 | Actiontec GT704WG Wireless Router...
Belkin Router
Ip adresses are SIMPLE to find, it doesn't matter what router you have, unless you are looking for local ip which doesn't seem you stated it
You could find your ip in theese following sites
www.ip-adress.com
www.ipchicken.com
www.whatsmyip.org
www.whatsmyip.net
Hope this helped!
Dec 01, 2007 | Belkin (F5D5231-4) Router
Sony PlayStation Portable (PSP) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
