Washing Machines
Problem for Washing Machines
Generic problem for all Washing Machines
Whirlpool duet washer fault code
By Smcdonald05 on Jun 18, 2008
whirlpool duet washer fault code 21F and also 5d
Same Problem
May 11, 2009
-   i have model# WTW6600SW2 and my machine keeps coding 5d and it wont spin.. how do i fix it -   ajaehammitt
May 08, 2009
-   Sears techs were at my home today and it was exactly as stated above. There was a bobby pin lodged inside the pump. It could have been costly if not caught at this point. -   Guest
Apr 06, 2009
-   Is there a free online service manual for the Whirlpool Duet Sport washing machine? -   mt pleasant
Best Solution
posted on Jun 19, 2008
Helpful)
Lumpy816
Rank: Guru
Rating: 93%, 279 votes
F21 is a drain error code. You likely have something stuck in your pump. Remove the lower front panel. (there are 3 #20 torx screws on the bottom of it holding it on) Once you have the panel off, the white object in the front cneter is your pump. Remove the #20 torx screw out of there too to make life easier. Slide the pump forward slightly so you can raise it. Now, on the front of the pump is a handel that you will need to trun counter clockwise. So after placing something under neath to catch the water left inside the machine ( a large bowl or bucket), turn the know slowly counter clock wise. If there is too much water for your container, screw it back clockwise and go empty your container. Repeat until all of the water is out. Once that is done, unscrew it all of the way and slide if forward. You will usually find missing socks, toys, coins and all other kinds of fun objects. While you have the trap out, reach in with your finger to the hole on the right. Try and turn the wheel inside to make sure there isn't anything keeping it from turning (bobby pins, nails, screws, etc) If there is, you will need to unclamp both hoses on the back of the pump and remove any further forign objects. Now re-assemble the unit but leave the panel off. Run a quick fill and drain to make sure all of your connections are tight and you don't have any leaks. Put your panel back in and you're ready to go.
Was this helpful?
Yes
No
8 people thought this was helpful
Solution #2
posted on Jul 13, 2009
Not Rated)
csalm
Rank: Apprentice
Rating: 0%, 0 votes
Hey I have a Whirlpool Duet Sport Washer and there is a code that says F22.... I want to know what that means. I shut the washer off and it started back up, buti still would like to know what F22 means in case there is a problem.
Thanks
Was this helpful?
Yes
No
Popular Solutions for Washing Machines
Questions and Unsolved Problems for Washing Machines
Answer
whirlpool ultimate care ii washer LSQ9110PW2
Answer
Toward the end of the wash cycle, my whirlpool cabrio has started making a very loud crackling... (More)
Answer
F70 Error Code after initial wash. Unplugged unit, plugged back in and nothing happens - dead.
Answer
Had to move the Maytag Neptune. Need to reconnect the drain hose. How?
Describe your Washing Machines problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machine Experts
Top Washer & Dryer Repairmen
in , PA
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
