I format my labtab computer and I need drive to work with my EZX60.
    Brigadier General:
  • 10,406 Answers
The Sennheiser EZX-60 is a BlueTooth device.
Does your laptop ("labtab"?) computer have built-in BlueTooth support?
What manufacturer of computer?
What model of computer?
Access the manufacturer's web-site, and look for "support and drivers and downloads" specific to your computer.
Posted on Nov 13, 2010
My computer can't see my 1tb seagate expansion portable hdd which I formatted to my smart TV
Formatting a drive using smart TV usually makes your drive into Linux file format like ext2 or ext3 file format, which windows does not recognize. (not unless you install reader or software to read this).
Check on your computer's "Device Manger" if your drive is undetected or just in format your computer cant read. To check
1. On start menu, right-click "My Computer" & click Manage.
2. Click on disk management (assuming your HDD is connected)
3. Check if your drive is shown there and in what format. Like this:
4. You can format your drive here too if you want.
5. If it is here, then your drive is working fine, you just need to install ext2/ext3 file format reader to see the files.
Dec 26, 2014 | Computers & Internet
I have a sata drive but it is not properly formatted.....how do i format it on win xp home
if this is not your primary drive
click start click on my computer you should see your drive
right click then select format
another way is to control panel administrative tools computer management disk management right click on your drive select format
if you need more help with this or if i have missed the problem post a reply
hope this helps
Apr 30, 2012 | Compaq Computers & Internet
Format a 16gb PNY Micro SD
Format it by using a device like a camera, the computer will not work to format this type of memory. I know this from own experience with 4 different computer in my house..
Jan 16, 2012 | PNY Attach? 16GB USB 2.0 Flash Drive
Good day. I bought this Netbook with Windows 7 installed. I need to format and reload Windows XP as I have software that I need to use that only works with XP, I have an external "USB CD Drive"...
Hi neil720...
Installing the external CD Player...
You will go and start up and install Windows XP by doing he following:
Plug in your external CD drive, and let windows install it into the system...
Once the CD is ready to go, shut down the computer.
You will first need to format your hard drive, I will give you instructions on how to do that.
1...To format your hard drive and install XP:
To set you computer back to factory fresh settings you will need to format the hard drive and install the XP operating system and the drivers.
1.Format the hard drive:
You do this by double left clicking on "My Computer",then double left click the main drive (normally C drive).
When the window pops open, you will choose "Format"
Keep in mind that once you format your hard drive you will loose all your files,programs,pictures,etc that you installed since the computer was new.
So make your back up on a portable hard drive,thumb drive,etc.
2. Once the formatting of the hard drive is complete you will need to install the XP operating system along with the drivers.
You will now insert the CD's into your external CD player starting with #1 first and continuing until all has been installed.
After all has been installed, shut your computer off and restart.
That will bring your computer back to Windows XP factory new condition as far as operating is concerned.
Please take time to rate me
Sep 15, 2011 | Acer Aspire One D255-2670
Where do i get the usb format utility for my G3 external hard drive
right click on drive in my computer select format leave default options and hit ok simple as that you don't need an extra utility
hope this helps
regards
djbr1ck
May 13, 2011 | Samsung G3 Station 1TB USB 2.0 Black...
How to format usb that says it has 8mb capacity.
To Format Any Flash (USB) Drive
WARNING: This will permanently remove ALL data from your flash drive.
1) Insert the flash drive into a working usb port on your Windows PC.
2) Open "My Computer" in Windows XP or eariler OR "Computer" in Windows Vista/7
3) Right click on the Flash Drive (Usually labeled "Removable Disk")
4) Click "Format..."
5) Ensure that file system is "FAT32", Volume label is a name of your choosing, and that "Quick Format" is unchecked
6) Click "Start"
7) Windows will warn you that all data is about to be deleted. Click OK.
8) Once the format is complete, Windows will produce a pop-up window telling you so.
You now have a blank flash drive.
Apr 12, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I want to reformate my HDD using another computer.I will connect the HDD as a Slave how is the configuration of the Pin.Will it be ready for installation of an XP.What other things i need to do and how...
you dont need to format on a working computer u can just format the hard drive during the install of windows xp.
it will give you the option to delete the data and format to either FAT or NTFS.
Mar 10, 2011 | Xante Internal IDE Disk Drive Hard Drive
My Book essential 2 TB hard drive not recognized by PS3. It is partition with 2 ms-dos fat partitions. An ideas how to get the ps3 to see the usb mass storage device?
You must format the drive as FAT32
Note that your drive is too big to be formatted as a single 2TB FAT32 partition, its basically too big for PS3 usage.
but I think we should be able to get it to work.
You need to create one big partition off the drive, you can do that by connecting the drive first to your computer and then, right click on my computer or computer and select manage. Then on the right side of the computer management window you need to click on Disk management.
On the right side you need to find your 2TB externall hard drive, delete all the partitions from it so that its entirely free space or unpartitioned space, then create a new volume, full size of the drive, do not format it, if it doesn't let you pass without formatting then make sure its on quick format and fat32.
Jan 08, 2011 | Western Digital My Book Essential 1TB...
I have kingston 32gb pen drive this working only 1gb remaning 31gb not woked
Try out to format your PD. if format doesn't work try following steps.
steps to format:
  1. right click on my computer.
  2. select manage.
  3. select disk management.
  4. on right side select your drive.
    (tips. your pendrive is in removable media. so see in this group)
  5. right on drive,you want to format.
  6. then select format.
if it doesn't works on your computer. then use updated antivirus or else format it on others computer.
if it helps, pls rate it... ; ) thank you.
Oct 12, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Computers & Internet Logo
David Payne
David Payne
