Question about Whirlpool Washing Machines
Whirlpool duet washer flashing code 21F and also flashed 5d
  • 246 Answers
F21 is a drain error code. You likely have something stuck in your pump. Remove the lower front panel. (there are 3 #20 torx screws on the bottom of it holding it on) Once you have the panel off, the white object in the front cneter is your pump. Remove the #20 torx screw out of there too to make life easier. Slide the pump forward slightly so you can raise it. Now, on the front of the pump is a handel that you will need to trun counter clockwise. So after placing something under neath to catch the water left inside the machine ( a large bowl or bucket), turn the know slowly counter clock wise. If there is too much water for your container, screw it back clockwise and go empty your container. Repeat until all of the water is out. Once that is done, unscrew it all of the way and slide if forward. You will usually find missing socks, toys, coins and all other kinds of fun objects. While you have the trap out, reach in with your finger to the hole on the right. Try and turn the wheel inside to make sure there isn't anything keeping it from turning (bobby pins, nails, screws, etc) If there is, you will need to unclamp both hoses on the back of the pump and remove any further forign objects. Now re-assemble the unit but leave the panel off. Run a quick fill and drain to make sure all of your connections are tight and you don't have any leaks. Put your panel back in and you're ready to go.
Posted on Jun 19, 2008
It starts and then stops and then F28 flashes
http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3708-whirlpool-washing-machine-fault-codes.html
Not good! Probably motor control board or motor or wiring harness from control board to motor.
This leads to a Kenmore Video
Whirlpool, Maytag, Kenmore. Same machine different name different trim.
Whirlpool Duet f28 YouTube
Sep 21, 2014 | Whirlpool Duet GHW9150P Front Load Washer
F21 is flashing
This means the water is not draining out like it should. I solved this problem initially on my washer (my drain pipe was clogged), but now (about 4 months later), I have a flashing F21 and 5d, because of a clog some- where. I can drain and rinse (after this cycle, the door will unlock), and the tub spins, but I can't complete a cycle. Lots of debris has come out with rinse water, but I still seem to have a clog somewhere. I can complete a wash load by manually switching the settings.
Dec 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer flashing f- 20.
not enough water coming in washer press pause/cancel twice to clear the codes the check water flow from valves look for dirt clogging the screens at the inlets at the valves kinked hoses make sure valves are full on or water pressure less than 10 psi
Feb 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Flashing codes
you have a communication problem between your door lock and your ccu board. Are you hearing a click click click before it fails? If so this is a relay inside your ccu board. Replace the board this will solve your problem
Jan 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error code 5d???
sure it's not sud? if so may be oversudsingbe sure you are using an he detergent if you are and suds are and issue try cuting back on detergent
May 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet sport
5d is: suds lock (overdose of detergent dectected during the wash cycle).
Chances are you just put too much detergent in, or maybe the wrong detergent - make sure you're using the HE detergent.
These codes and more details are printed on the service technician diagnostic manual that is affixed to the inside of the washer's front panel.
Unplug your washer, and unscrew the three 1/4" socket screws at the bottom of the washer. The manual should be taped to the back of the panel, and the code and some recommended procedures will be right inside.
Whirlpool flashes 5d
try pushing pause/cancel twice and try again let me know what happens
Jan 17, 2008 | Whirlpool AWM6120 Front Load Washer
Whirlpool duet sport front load washer
the panel below the door has 3 screws under the bottom lip of the panel. remove the screws to get the panel off youll see the pump right in front of you. you can unscrew the cap on the pump and remove it to clean out the punp. thats where 99% of clogges are on that washer
Nov 25, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
Dan Webster
Dan Webster
Sal De
