Question about Brother IntelliFax-1860C Plain Paper Inkjet Fax
Although I bought new print cartridges the fax continuously tells me to insert Cyan which I do, yet again it does not acknowledge that I have inserted it and states to insert Cyan. Is the ink cartridge damaged or faulty? The machine is a Brother Fax 1860C
  • 10,515 Answers
1- Remove ALL the ink cartridges from the printer
2- Check that there is no residual tape on the cartridges.
3- Then clean the contacts on the cartridges as well as inside the printer itself
===> Do this with a small amount of warm water on a cotton swab until no ink comes off on the swab
4- If any of the other cartridges are low, empty, leaking or bulging, replace them with genuine and original ones.
5- Then turn off the machine and unplug it for 60 seconds
6- Insert the cartridges and check to see if the problem is still there.
If that does not solve the problem, Unfortunately it would confirm that printhead is defective. The print head is the part of the printer that puts ink from the cartridges onto the page. If your printer is in warranty please call Brother at 1-800-284-4329 Monday through Friday, 9:00am - 7:00pm EST and ask for a free printhead replacement. They will ask the date of purchase and the serial number of the printer.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Nov 14, 2010
Epson wf-2530 - cyan is printing out as a pale pink even after inserting a new cartridhe
My suggestion is to pull the cartridges check your ink collector pad. This is where the extra ink gets wiped from the cartridges as it goes by. make sure that the pad is not pooling up check the bottoms of your cartridges and wipe them clean also and do a quick cleaning inside if you see any extra dust, ink etc.. just wipe it clean. then power your printer off and back on again and see if that helps. Hope it does the trick for you.
Nov 08, 2014 | Epson Office Equipment & Supplies
My Toshiba estudio 4511 says call service
Your CYAN is one of 3 colors the "Smart guys" came up with to make 252 some colors. Between Cyan Magenta Yellow and the ever so present Black you can make all your colors. Obviously you don't need the three C,M,Y to make a black and white copy. So the issue remains that a low or empty Cyan (pronounced S-eye-ann)
A couple differant issues I've run into since the creation of color copies near 2003 is A pull tab on the toner isn't pulled off before inserting the tube. Another is for several possible reasons the toner just isn't getting down into the developer mixing auger. There is also, upon occasion a situation that the motor that turns the toner auger inside the new toner cartridge doesn't turn enough/properly/ or at all. These days that will almost always throw a code in the display window. My 23years of Toshiba tells me try your C cartridge, play with it a bit and make sure its in right, with tab pulled. another tool is monitoring how long it tries to and the Cyan, does it attempt to restore it' levels for about 90 seconds or is it immediately tell you there's a cyan issue? Can you hear the motor and toner bottle turning? It should tell you "adding Cyan Toner" or even "Check Cyan Cartridge" worst case scenario you call Toshiba business Solutions and they vacuum it all out and do some adjustments......could be a good thing With Toshiba you get a lot of bang for your buck, meaning: a service call is good every once in a while. Your 4511 is a work horse you won't regret $pending for service. ~~~~~> SC
Sep 22, 2014 | Toshiba Estudio 4511 Color Printer,...
Install cyan
That message is saying you need to replace the blue "Cyan" ink cartridge in the printer. When the printer detects that the ink in out it tells you to replace the empty one to continue printing. Just buy a new cartridge install it and you will be good to go.
Jun 29, 2013 | Brother MFC 210C All-In-One InkJet Printer
CAN'T GET FAX TO ACCEPT AN IN COMMING FAX. KEEP GETTING THE MESSAGE : "RECCOMMEND NEW C-CRT". I REALLY NEED THIS FAX HELP! WE HAVE CHANGED THE INK CARTRIDGE TONIGHT AND IT WILL PRINT FROM THE COMPUTER.
Erase driver from windows, unplug fax, plug it back in and reinstall drivers via add new hardware, Select from disk if you have it or let Windows do it. Worth a try.
Jun 15, 2010 | Canon PIXMA MX310 All-In-One Printer
I replaced an ink cartridge because the printer stopped working and showed a message that the old cartridge is empty. However after putting the new one in but the printer still refuses to work and shows...
maybe the cartridge is wrong, release it and clean the electrical contacts, put them again one by one, if notting happen, try this
Solution As the printer operates, it moves ink from the ink cartridges into a printhead reservoir. The printer does not deliver a message when an ink cartridge goes empty, because it still has ink in the reservoir. The printer continues printing until the ink level in the reservoir falls to a first trigger point - then a message appears advising the printer owner to Replace Cartridges Soon . At this point, other cartridges that are empty but have not reached the trigger point are also mentioned in the message, to save trips to the retailer. After the first trigger point, the printer can continue printing until ink levels in the reservoir reach a second trigger point. At the second trigger point there is only enough ink left to perform vital servicing tasks, and a new message appears, saying Ink Cartridges Empty . The options offered depend on the usable inks remaining. If no options are offered, the cartridges indicated must be replaced before printing can continue. The Ink Cartridges Empty options are described in the table below: Ink colors out Option Print mode possible All Cancel None Black
AND
Cyan, Magenta, or Yellow (any or all) Black only Continue with other colors Cyan/Magenta/Yellow mode (composite black)
Text and photo quality will differ from those printed when all colors are available Light Cyan or Light Magenta (either or both) Cyan, Magenta, or Yellow (any or all)
(Black still available) Print with black ink only Grayscale
Apr 07, 2010 | HP Photosmart 3210 Printer
New cartridge inserted, received error
Hi can try I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Apr 03, 2009 | HP Photosmart 3210 Printer
LaserJet 3550: override chip on toner cartridge to continue print
Disable Carts is for service tech troubleshooting.
You will have to replace. All prints use all cartriges every time.
Jan 20, 2009 | HP Color LaserJet 2600n Printer
Cannot receive faxes or do copies
If you still have your old cartridge reinstall it that will tell you if it is the cartridge or not. If you still have the problem,it could be the encoder.
Oct 23, 2007 | Office Equipment & Supplies
Printer won't recognize ink cartridge
I had the same problem with the yellow cartridge.   At first when I resinserted it, it would solve the problem, but today even that didn't work.
I did solve the problem by clearing all print jobs, turning the printer off and then on, and then running a cleaning cycle on the color nozzles.   I don't know why this fixed things, but my yellow was suddenly recognized without any further fiddling.
Sep 07, 2007 | OEM Systems PIXMA iP3300 Photo Printer
U150 error
Anyone game for a class action against Canon? I've called, E-Mailed, and faxed, all to no avail, not one answer, no return contact whatsoever!!! Please post this info about these piece of **** Canon printers on every website you can and anywhere else you can, the world needs to know what GARBAGE Canon is unloading onto the unsuspecting consumer. Hopefully, it will get Canon's attention and maybe those losers will take notice when their sales drop! What say everyone boycott anything that says Canon on it. Come on Canon, take care of this junk you have ripped us off on. I am even telling people IN the stores who are looking at printers to AVOID Canon completely.
Nov 07, 2006 | Canon Pixma MP800 All-In-One InkJet...
Brother IntelliFax-1860C Plain Paper Inkjet Fax Logo
143 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
