Question about Norelco Reflex Shaver 5845XL
My Norelco 5845xl willnot turn on or charge. - Norelco Reflex Shaver 5845XL
  • Norelco Master
  • 1,610 Answers
The shaver probably needs a new battery pack. You will find replacements at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/shaver-battery-pack-for-most-norelco-more-p-278.html
To replace, first remove the back cover by removing the two screws. Then remove the two plastic clips that are in the wat of fully accessing the batteries. You can then access the batteries and circuit board inside. For easiest installation, it is suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
Posted on Nov 14, 2010
To charge
Men\'s Grooming / Norelco
1-800-243-3050
Monday - Saturday 9:00 AM - 9:00 PM EST
Sunday 9:00 AM - 6:00 PM EST
Excluding Major Holidays
good luck
Apr 19, 2014 | Philips arcitec 1060 Electric Shaver
Norelco arcitec
Yes, you will find a replacement at shavoutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/cords-chargers-and-stands/philips-norelco/norelco-arcitec-shaver-counter-charging-stand-p-468.html
Oct 13, 2013 | Health & Beauty
Norelco 8894XL is charging to over 100 minutes. According to manual, it supposed to charge only to 100 minuyes. What is causing it overcharge?
I have owned a Norelco 8894xl for over 10 years. My battery meter will show 127 minutes after the razor is fully charged. The battery is not over charged. This is normal and does not indicate a problem. Hope this helps.
Jan 07, 2011 | Norelco 8894 XL Electric Shaver
Charging is full but equipment is not starting
if the charge indicator is working and dispays full, you probably have some type of loose connection inside. Check the connection between the circuit board and motor. Less likely but possible that the motor brushes may be worn out. One way to test this is to remove head and turn shaver on...then turn one of the three gears by hand in a clockwise direction. If it then starts to turn slowly on it's own, the brushes are probably bad
Jan 13, 2010 | Norelco Spectra 8865 XL Electric Shaver
I have a Norelco 6885XL electric razor that won't hold a charge. It will "recharge" to 44 minutes, but once below 39 minutes left it goes to 0 when turned on.
It's easy - I replaced mine (Norelco 6885XL) with a soldering iron & batteries I found online. Here's one place that sells them:
http://www.electricshaverstore.com/get_list_145.htm
As these are NiCd, I always drain them totally dead, then recharge, as this type of battery does suffer from the "memory effect".
Dave
Dec 16, 2008 | Norelco 7886XL Electric Shaver
Norelco model 5885 XL Battery replacments
I just installed two brand new Eneloop cells and it will only charge up to 35 minutes on the display (I had been able to get up to 52 minutes with the original NI-CAD's). I also discovered that it would not recognize the capactiy on the minute meter until I drained the batteries and recharged the unit. When I went to drain the batteries they ran for 2 hours and 15 minutes!!! But again the display only shows 35 minutes right now after an hour charge when it says FULL. I'll leave it on the charger and see what happens. I used a pair of needle nose pliers and "rolled" the metal tabs off the NI-CAD's. Snapped the one on the negative side but got the positive side off clean. I couldn't get the strips to solder back to the new Eneloop batteries so I had to use electrical tape which seems to be holding fine. The battery holder holds the positive and negative terminals against the old tabs just fine. Also I learned that if you hold the power button on long enough it will cycle through a test function. It will go to zero minutes and all the way up to 35, then turn on and go back to zero stopping at the appropriate cleaning cycle times (takes about 40 seconds to do the test so don't touch the power button until it's done). Not sure if the batteries will still go 2 hours and 15 minutes after being charged in the shaver, but they do when chaqrged outside the shaver. Just my two cents!
Mar 23, 2008 | Norelco Reflex Shaver 5885XL Electric...
Health & Beauty Logo
103 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
