Question about Olympus Cameras
Driver for the model olympus fe 47 - Olympus Cameras
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Olympus Master
  • 102,366 Answers
Take a look at
http://www.olympusamerica.com/cpg_section/cpg_support_downloads.asp?id=1489
You might want to consider NOT connecting the camera to the computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
Posted on Nov 13, 2010
  • 11967 Answers
SOURCE: olympus fe-47. When you pushed the on button. The
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jul 09, 2010
  • 102366 Answers
SOURCE: I need an owners manual for an olympus FE-310
You can download a PDF version of the manual and/or order the printed one from the manufacturer's web site at http://www.olympusamerica.com/cpg_section/cpg_support_manuals.asp?id=1351
Posted on May 13, 2010
  • 919 Answers
SOURCE: drivers for fe 210
  • Olympus Master 2.11: http://downloads.olympus-europa.com/OM2/win/OM211Setup.exe
  • Posted on Jan 08, 2009
    Obertelli
    • 3006 Answers
    SOURCE: Windows 7 driver for an olympus FE-210
    Currently, you can't.
    Olympus have not yet released a Windows 7 driver and given that it is an ultra low cost model I doubt that they'll be in any rush to do so.
    All you can do is to try and find a Windows 7 compatible xD card reader, but given that xD is now an obsolete format that might also prove to be difficult.
    The only remaining option will be to install your current driver onto Win7 and try to run it in compatibility mode.
    Sorry there's no straightforward/guaranteed fix here, but these issues always arise with an upgrade to a brand new O.S. version and it often takes up to a year to find out which products will be supported on the new O.S. and which ones will be consigned to obselescence.
    Posted on Mar 02, 2010
    muntejaya
    • 10421 Answers
    SOURCE: download driver olympus FE-340 digital camera
    Please get it here then : www.olympusamerica.com > Home > Support www.olympus.co.jp/en/.../digicamera/qa/.../di000400e.cfm
    Posted on Feb 08, 2011
    DRIVERS FOR FE 47
    You don't need a driver.
    Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
    Jan 03, 2013 | Olympus Cameras
    Hello, my name is Bonita. I have a fe 47 Olympus Digital camera, but I do not a manual. I am trying to find one that I can download for free. Can you help please?
    You can download from the following site for free: http://www.olympusamerica.com/files/oima_cckb/FE-47_X-43_Instruction_Manual_EN.pdf
    You can get software also from Olympus.com site. Got to "support" or "software"
    Best of luck.
    Jan 04, 2011 | Cameras
    I need a driver of olympus FE-20 digital camera
    Here is the official link from Olympus website http://www.olympusamerica.com/cpg_section/cpg_support_product.asp?id=1392
    You can download the driver for your Olympus FE-20 digital camera including the user's manual in .pdf form.
    Dec 27, 2010 | Olympus FE-20 Digital Camera
    Cameras Logo
    1,109 people viewed this question
    Top Olympus Cameras Experts
    Willem.
    Willem.
    Steven Wander
    Steven Wander
    Are you an Olympus Camera Expert? Answer questions, earn points and help others
