Question about HP Computers & Internet
I have a HP Pavillion laptop. The computer is starting with the "windows error recover" running. Then once you click to repair the problems or start windows normally, the computer start to load and goes to a screen that says "Windows has encountered a problem communicating with a device connected to your computer. This error can be caused by unplugging the removable storage device such as an external USB drive while the device is in use, or by faulty hardware such as a hard drive or CD-ROM drive that is failing. Make sure any removable storage is properly connected and then restart your computer. If you continue to receive this error message, contact the hardware manufacturer. Status: 0xc00000e9 Info: An unexpected I/O error has occured."
  • HP Master
  • 7,733 Answers
The easiest thing to check is to unplug any USB drive type devices (say the MP3 player) before starting Windows and see if that helps. If not then it sounds like something on the harddrive was messed up.
You could try holding F8 at boot to get the boot menu. Select Safe Mode and see if that will boot. If it does, answer yes to the popup question and then do Start'Run and type in:
cmd
to get a command prompt. In the command prompt type:
chkdsk c: /f
It should say that it can't check the drive right now (since Windows is running off that drive) and ask if you want to check it at boot. Answer with a y. Then reboot, let it try to startup normally, and chkdsk should run and check the drive for errors.
If that doesn't work (can't boot safe mode) and If you've got a Windows CD, (XP SP2 version disc may be needed if you have really large harddrives, doesn't have to be the disc used to install Windows on that computer) you could try booting it and go into the Recovery Console. (Basically a dos prompt type thing.)
Then type:
chkdsk c: /p
It should check the harddrive for errors and if it finds some will try and fix them. If when it's done it says it found and fixed one or more errors, then I'd do it again and see if it says it found one or more errors. (If it doesn't say that it found errors the second time then, hopefully, that means it fixed the errors it previously found. If it keeps finding errors every time you run it then that may indicate that the drive is failing.) In any case, running chkdsk once as above may help you get into Windows. (I'd still have it do chkdsk c: /f on reboot as above after booting Windows, just to be on the safe side.) You will need to have set a password for the Administrator account to do the Recovery Console though. (Administrator account is accessible when booting in Safe Mode.)
If you can get Windows booting (by any method) one thing you can do that might help prevent this from happening in the future is to disable disc caching for the MP3 player.
Plug the device in, right click the "Safely Remove Hardware" icon and choose "Safely Remove Hardware."
Check the Display Device Components box if it's not checked.
Find the MP3 player in the list (likely under USB Mass Storage Devices) and click it.
Then click the Properties button. On the properties window click Policies and set it to "Optimize for Quick Removal" and click OK.
From now on (at least on that computer) you should be able to remove the MP3 player without using the Safely Remove Hardware tray icon, as long the computer's not actually accessing files on the drive.
Posted on Nov 13, 2010
Boot device not found, insert a boot disk and press any key
The "no bootable devices found" error can create headaches, as well as occasional heartache if you're a laptop user. This error appears when your computer is unable to find a device or file required for normal operation. It could indicate one of three issues: hard drive failure, software error or motherboard malfunction. Any of these potential problems can render your laptop useless. Hard drive failure or software errors can lead to data loss, which can cause anguish and catastrophe, depending on the files business information, family photos, student projects at risk.
Hard Drive Failure
The interior of a hard drive is akin to a turntable. Most hard drives contain two to three discs, known as platters, which are similar to records. These platters are read and written on by a tiny needle called the read/write head, similar to the arm and needle on a turntable. When a hard drive functions properly, the platters spin and the read/write head accesses the files necessary to boot your computer. Improper function of any of these physical pieces can cause a mechanical failure and result in the "no bootable devices" error. Software Error
In rare instances, a software problem more specifically, a particularly nasty virus may cause the "no bootable devices" error.
Most often, if a virus attacks and corrupts your system, your computer can still detect the hard drive and operating system, and you'll see some attempt at a normal boot.
If a virus attacks certain system and startup files, however, they may not be detectable next time you boot your computer, thus causing you to see "no bootable devices."
This may also happen if you are manually deleting files from your computer and accidentally delete system files.
Motherboard
Sometimes individual components of your laptop's motherboard malfunction, which can cause problems ranging from loss of wireless capabilities to inability to detect an external power source.
If the components that detect your hard drive fail, your laptop is unable to receive signals from the hard drive and therefore may display the "no bootable devices" error.
Repair
Fixing a "no bootable devices" error can prove costly.
If motherboard failure caused the error, you're probably better off purchasing a new laptop; unless it's under warranty; the average motherboard replacement costs $250 to $500.
You can reinstall your operating system to resolve software errors, which is fairly inexpensive by computer repair standards, costing $80 to $130 dollars, but this step may also overwrite your existing data.
In some cases, data may prove so badly corrupted it's not salvageable.
If you can recover it, however, that raises your repair costs. additional fee.
If hard drive failure caused your "no bootable devices" error, you can replace the drive.
If you need to recover data from a malfunctioning hard drive, send it to a clean room for recovery.
In a clean room, technicians disassemble your hard drive and image each platter; this kind of data recovery is extremely expensive, costing up to $2000 depending on the work involved.
Prevention
There is no way to guarantee you will never receive a "no bootable devices" error, but there are some steps you can take to help prevent it from happening.
Keep your laptop on a flat surface when using it, and avoid any bumps that may cause the hard drive's read/write mechanism to lock up.
Avoid transporting your laptop while the hard drive is active; turn your computer off while traveling.
Additionally, regularly run an anti-malware program to catch and remove viruses or spyware before they cause system problems.
http://www.upgradenrepair.com/Issues/N/nobootabledevicefound.htm
also you might
HP laptop no bootable devices found
Turn on your HP laptop with Windows Vista or Windows 7 and press the "Esc" key repeatedly to access the startup Menu. Press "F10" to access the BIOS.
Press "F9" to restore the BIOS to its default settings. Press "Enter" to verify that you want to restore the BIOS default settings.
Press "F10" to save your changes and exit the BIOS. Press "Enter" to confirm that you want to save the BIOS changes and continue booting up the laptop.
HP Hard Disk Test
Hold the Power button down for 15 seconds when the laptop is turned on to turn off the laptop.
Press the Power button again to turn on the laptop and press the "Esc" key repeatedly to access the startup Menu.
Press "F2" to access the System Diagnostics.
Click "Hard Disk Test" to begin testing the hard drive.
If "Pass" is displayed after all of the tests then the program fixed the error.
If "Fail" is displayed after any of the tests, proceed to Section 3 if you are using Windows Vista and Section 4 if you are using Windows 7.
Recover Windows Vista Factory Settings
Click "Start," "All Programs," "Recovery Manager" and "Recovery Manager" again to open the HP Recovery Manager.
Click "Advanced Options," then click "System Recovery" and "Next."
The laptop will restart and will boot up to the HP Recovery Manager.
Click "System Recovery" and click "Next."
Click "No" when asked if you want to use Microsoft System Restore and click "Next."
Select "Recover without backing up your files" and click "Next."
Click "Next" to begin the recovery process.
When the process is finished the laptop will restart and boot to the Windows Vista setup screen.
Recover Windows 7 Factory Settings
Click "System Recovery."
The laptop will restart and will boot to HP Recovery Manager. Click "System Recovery," then click "Next."
Click "Recover without backing up your files" and click "Next."
When the process is finished the laptop will restart and boot to the Windows 7 setup screen.
Jun 26, 2013 | Acer Aspire One PC Notebook
Tip
How to Reset Windows Password on ThinkPad Laptop
For IBM ThinkPad Laptop or Lenovo <a href="http://windowspasswordrecovery.net/">ThinkPad password reset</a>, there are common password problems about the BIOS password, Power-on password, Hard drive password, etc. Here we will discuss how to reset ThinkPad password based on Windows 7, XP, Vista, Server 2003, 2008 domain, etc.<br /> <br />Firstly, <b>ThinkPad password</b><b> reset</b><b> with password reset disk<br /></b>Well, the first way is the most time saving and money saving to recover lost ThinkPad password. Pity that most of ThinkPad laptop users may without this named ThinkPad password reset disk. Notice that we should create the disk before lost or forgotten password or at the time that we set the password for logon Windows system. The below are steps to create and use the <a href="http://windowspasswordrecovery.net/article/reset-windows-7-password-with-4-easy-ways.html">Windows 7 password reset disc</a> for ThinkPad Windows 7 laptop:<br /> 1. Insert a CD/DVD/USB Flash Drive into the driver. <br /> 2. Click Start - Control Panel - User Accounts and Family Safety - User Accounts.<br /> 3. Select "Create a password reset disk" - "Forgotten Password Wizard" on the left pane.<br /> 4. Click "Next" and follow the Wizard to create password reset disk.<br /> Once we forgot Win 7 password for ThinkPad computer at the login screen and input an incorrect password, click "Reset Windows Password" and insert the password reset disk. The Password Reset Wizard will lead us create a new password to remove the lost or forgotten Windows 7 password.<br /> <br />Secondly, <b>unlock ThinkPad Windows XP password with Windows Installation Disc<br /></b>1. Start PC with Installation disc. Choose "Accept" once it asks to repair your current Windows installation, press "R" to run repair and also allow PC to repair by copying files to hard drive.<br /> 2. The PC will reboot, and then display "Press any key to continue." Please do not press any key.<br /> 3. Let computer restart the installation and at the same time please notice the words shown at the bottom of screen. Once "Installing Devices" comes up, press "Shift +F10".<br /> 4. Then input "nusrmgr.cpl" and press "Enter".<br /> 5. On the User Accounts windows, choose the "Administrator account". Then there will be listed all user accounts of the system.<br /> 6. Select the account that has to remove or reset password.<br /> With Installation CD to break ThinkPad password also can be used on system based on Windows 7, Vista, 2000, Server 2008, etc.<br /> <br />Thirdly, <b>reset ThinkPad administrator password</b> by accounts with administrative rights<br />Only the accounts with administrative privileges can help us reset lost password, the built-in administrator account included. Now, take <b>ThinkPad XP password recovery in Safe Mode</b> as example:<br /> 1. Press F8 once IBM ThinkPad laptop starts. Select "Safe Mode with Command Prompt" and Enter.<br /> 2. At the login screen with computer user accounts, choose an available account to login. Please note that the built-in Administrator account password is blank if never set password for it before.<br /> 3. In Safe Mode, Dos command displays. Input "net user" and press Enter to list all the user names in Windows XP computer. Then input "net user Susan 123" (Susan is the locked account name and 123 is the new password set on this account) and press Enter. Then we will see "The command completed successfully."<br /> 4. Input "shutdown -r" and press Enter to restart the system, then we can access "Susan" account in normal logon mode.<br /> <br />If the above methods still can not help us <a href="http://windowspasswordrecovery.net/">reset ThinkPad password</a> or make us feel difficult to operate without some techniques, we can opt for some professional Windows Password Recovery tool or software. Such as <a href="http://windowspasswordrecovery.net/"><u>Ainorsoft Windows Password Recovery</u></a>, it has Basic, Enhance and Corporation three different versions for computer basic on Windows 7, XP, Vista, Server 2003, Server 2008, R2, etc. Especially, <b>Windows Password Recovery Corporation</b> has large amounts of faithful users. With the Windows Password Recovery software, users can solve Windows password problem within minutes without special techniques!<br /> <i><br /></i><br /><i>Source</i>: http://windowspasswordrecovery.net/article/thinkpad-password-reset.html<br />
on Jun 01, 2011 | Computers & Internet
Tip
How to check a hard drive for errors in Windows
Windows comes with many diagnostic, repair, and maintenance tools that can help you get the most life and best performance out of your computer. One of these tools is the hard drive error-checking utility.<br /> <br /> Over time, your hard drive can develop problems, both with the physical disk itself as well as with corrupted areas of the file system. Running the error-checking utility can sometimes fix these problems, and if it can't fix them, it can at least identify and isolate them. It's a good idea to run error-checking once in a while to optimize your hard drive.<br /> <br /> To run Windows error-checking, follow the steps below.<br /> <br /> 1. Click on the Start button (in Vista, click on the Vista orb) to bring up the Start menu.<br /> <br /> 2. Select My Computer (in Vista, select Computer).<br /> <br /> 3. Right click on the hard drive you want to scan for errors and select <br /> Properties.<br /> <br /> 4. In the Disk Properties window, click on the Tools tab.<br /> <br /> 5. Under the "Error-checking" heading, click "Check Now...."<br /> <br /> In the Check Disk window that appears, there are two options. You can run error-checking with neither, one, or both of those options selected, depending on how intensive a scan you want to run (and how long you have to wait). If you check the first option (<i>Automatically fix file system errors</i>) and click Start, you'll be prompted to restart your computer in order for the utility to able to run; you can either restart now or restart later, and when the computer boots back up, the check disk program will run.<br /> <br /> The second option (<i>Scan for and attempt recovery of bad sectors</i>) can be run immediately, but it can take a lot of time to finish. The bad sector check has four phases, and you'll see a status bar to let you know how far along the check is. Only select this option if you don't need your computer for a while. If you are using a laptop, connect to an external power source before clicking Start to begin the scan.
on Dec 17, 2010 | Computers & Internet
My Sister bought a hp mini 210-307nr pc, HELP!!
The two main methods in which to take care of Status Oxcoooooof Repair Screen error message:
Advanced Fix (manual update):
1) Start your computer or laptop then log on as an admin.
2) Click the Start button then click Programs, Accessories, System Tools, and next click Restore.
3) From the new window, click "Restore my system to an earlier period" then click Next.
4) Select the freshest restore point in the "select a restoration date" listing, and then click on Next.
5) Then click 'Next' on the verification window.
6) Restart the pc when the rescue is completed.
Inexperienced Computer User Resolution (totally automated):
1) Download the (Status Oxcoooooof Repair Screen) fix application.
2) Setup application and simply click on Scan button.
3) Hit the Fix Errors button once the diagnostic scan is successfully completed.
4) Restart your laptop or computer.
Here is a link to another Status Oxcoooooof Repair Screen recovery utility you can use in case the above option does not work anymore.
Nov 26, 2012 | Computers & Internet
Windows installer not working
If you have windows 7 try the steps below, if not let me know your operating system.
Click Start
Type: CMD, from the results, right click CMD
Click 'Run as Administrator'
At the Command Prompt, type: sfc/scannow
This will check for any integrity violations
Restart your system
1. Insert the Windows 7 DVD
2. Restart your computer
3. When asked if you want to boot from your DVD drive, do so.
4. Choose your language, click Next.
5. Click 'Repair your computer'
6. Select operating system you want to repair.
Apr 29, 2012 | HP Pavillion G50-111NR Notebook
My dogs were playing and my laptop fell onto the ground, not once,but twice (about two feet each time)! I heard a whirling, scrapping noise then it went away after some time.Everything worked fine for a...
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive or
go to control panel administrive tools computer management you can right click on the drive select properties tools check now?tick in both boxes to scan for and attempt to repair/recover any bad sectors and automaticall fix any corrupt files
in xp
hope this helps
Jan 31, 2011 | Computers & Internet
I have an HP Pavillion dv9700 laptop. When I turn on the laptop I get an error reading that says "a disk error ocurred hit ctrl, alt, delete to restart". I do this and and it recycles back to the...
Do you have the Restoration Disk?
You have corrupted basic Windows files. How? Windows is a funny animal. That, and viruses just drive Windows users crazy.
The Restoration (CD) Disk has the basic Windows files. You can do a Repair.
Start the computer, insert the Restoration Disk in the optical drive. Close the drive tray.
When asked perform a Non-Destructive Installation.
Don't have the Restoration Disk?
Contact HP Support.
The disk/s are free. The shipping and handling is not.
In the US the phone number is 1-800-474-6836
It's $17 for a 5 to 7 day ship, $24 for a 2 to 3 day ship.
Not in the US?
Here is the HP Support Worldwide contact page,
http://welcome.hp.com/country/us/en/wwcontact_us.html
Nov 15, 2010 | HP Pavilion dv9500 dv9600 and dv9700 FF...
No sound (i.e. music) coming from my HP Pavillion Entertainment laptop
  1. Click Start , type services.msc into the search field, and then select services.msc from the list when it becomes available to open the Programs window.
  2. Grant permission to continue, if prompted.
  3. Scroll down to and select Windows Audio , right-click to open the drop-down menu, and then click Start . Figure 1: Starting the Windows Audio servicec00847914.gif
  4. Right-click Windows Audio , click Properties , and then verify that Startup Type is set to Automatic . The Windows Audio service is now running. The error message should close.
Nov 01, 2010 | HP Pavilion dv9000z Notebook
HP Pavillion dv9000. Intermittent stops. Cannot restart, but will do so after many hours. Screen turns blue with band of torn blue that looks like shutters. System carries out repair check - once worked...
Try booting your computer in safe mode... when your machine starts press F8 and go to Windows. Run for a couple of hours and see if this problem happens.
If you have system restore running, restore back to a point when you didnt have the problem
May 17, 2010 | HP Pavilion dv9000z Notebook
Computers & Internet Logo
140 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
