Question about Karcher 2500 PSI Pressure Washer
Karcher 2400 psi with honda motor started up big puff of white smoke from exaust it shut off noiw wont start whats going on
I have a john deere 3000psi pressure washer with similar problem. Running fine then a puff of smoke and it shut down. I checked the oil and found it full of water. Not only that but since I still had the water turned on, the water was flowing out of the dip stick tube. I'm trying to find a solution online and will pass any information on.
Posted on Nov 22, 2010
Doesn't start
It sounds like it has jumped time. What year is the car and how many miles. Timing chains can go bad as early as 70,000 miles
Mar 22, 2014 | 2001 Chevrolet Silverado 1500
Reddy repair center
There are four possible answers to this problem, if the heater starts normally, runs for a few seconds or minutes and the shuts down but was still running normally at the time of shut down, this could be caused by the photocell, also known as the flame out control. This safety device may be failing, shutting down even though the heater is working normally, check the operation of the photocell. The second cause may be partial fuel filter blockage, the heater is effectively starving itself of fuel, so the flame blows out, hence the puff of smoke, and then shuts down on the safety cut out. Third cause, if this model has a compressor at the rear of the motor, the problem could be low pump pressure, caused by wear or contamination of the carbon blades, this would cause the wrong amount of fuel to be syphoned up, with weak fuel mix the heater may blow itself out and shut down. The fourth cause, perhaps indicated by the puff of white smoke, is contamination of the fuel with water, water will cause the white smoke and also is indecated by white residues or a power like substance on the end plate of the heater which glows red hot when burning.
Jan 24, 2014 | Desa International R40 Utility Heater
When ifirst start my 1989 chevy silverado it puffs white smoke
It's your valve seals... You start it get a big puff of white blue smoke than it goes away? ^^ idiots
May 25, 2012 | 1989 Chevrolet C1500
Overfilled the oil and black smoke came. Can't startt now what i need to do
hi there pauly46 here
remove plug, pull engine over to remove oil from combustion chamber , clean plug,
refit, remove air filter - replace it if its wet with oil / or water damaged and clean backing plate , drain float bowl and check oil in carb, refit bowl and connect water supply to pump - turn on and start engine ( sounds like you hydraulicd the piston in the cylinder )
engine may blow blue / white smoke for a while then settle back
note do not use a sae 30 , use a 20w/50 oil or 10w/40. honda engine with low oil shut down
units on them have a problem with sae 30 oil
cheers hope it helps
pauly46
May 13, 2011 | Karcher 2500 PSI Pressure Washer
White smoke. when it won't start, raw gas comes out of the exhaust GS190 honda Karcher 3000 PSI
Sounds like it's flooded. Close the throttle and open the choke if equipped. Pull it through a few times and then open the throttle a bit.
May 24, 2010 | Northstar Pressure Washer 3000 PSI
Honda GC190 engine shuts down on my Karcher 3000 PSI PW
Well would you believe that I have the very same problem. I suspected that the pump was seizing up, so we tried the pump on another unit and it worked fine. On inspection of the motor we found the cam (which also operates the decompression mechanism) was worn out. It's made of hard plastic. It is only about 7 dollars too, so cheap enough to fix. I have mine ordered now and feel pretty confident that that should fix it.
Aug 13, 2009 | Karcher 2500 PSI Pressure Washer
Karcher Power Washer that surges up and down with water pressure.
Before you start it up:
1. Disconnect the high pressure hose 2. Connect the water supply and turn on 3. Make sure water is flowing through the pump
Start the motor, run for about 10 seconds and then turn off.
Turn off the water supply, connect the high pressure hose, turn water back on, start the motor and away you go.
May 29, 2009 | Karcher 2500 PSI Pressure Washer
Big puff of white smoke at start up after sitting for several hours.
white smoke is water
blue smoke is oil.
nest time try and smell the white smoke see if it smells sweet?
if it does its antifreeze.
and also black smoke is fuel (like a leaky injector )
hope this helps
paul
Sep 19, 2008 | 2007 Nissan Altima 3.5 Sedan
Karcher 2500 PSI Pressure Washer Logo
322 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
