Question about Refrigerators
No longer cools. apparently a relay has been replaced twice since 2002 any idea as to what this relay is?
  • Refrigerators Master
  • 43,501 Answers
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Nov 14, 2010
I've got a mini one 2002 cooling fan dose not work unless I turn the a/c on if I don't turn the a/c on it will Overheat
7 Common Repair Problems Mini Cooper Owners Face
www.britishamericanauto.com/car.../7-Common-Repair-Problems-Mini-...
Feb 3, 2014 - This describes the top seven Mini Cooper repair problems owners may ... out the cooling fan and other related parts while the vehicle is apart. ... MiniCoopers aren't the most expensive cars to purchase new, and with .... Your article was a great read and at almost 60K miles , I've been through a few of them.
Mini Cooper cooling fan relay switch located Questions ...
www.fixya.com > ... > Cars & Trucks > Mini
Mini Cooper cars & trucks cooling fan relay switch located questions and answers. Ask your Mini cooling fan relay switch located related question. Get free help from topMini experts. ... I've also seen that problem in some Minis that required the fan motor to be replaced. ... The fan on my cooper s 2002 wont go on any idea.
Radiator Fan won't turn off! - North American Motoring
www.northamericanmotoring.com/...problems.../31220-radiator-fan-wo...
Sep 26, 2004 - Join Date: Aug 2002 ... I've posted a few times here on NAM that I never heard my car's electric fan run after the car was shut off. ... If it does not shut off then, replace that relay (you can find this relay at many ... Took the car in today to get thisproblem fixed. ... There is a recall on aux fan for MINI Cooper.
Dec 26, 2015 | Mini Cars & Trucks
My 2003 VW Jetta air conditioning is cooling for a few minutes and sometimes longer and then it stops cooling. The fan continues to run but the compressor apparently stops running.
Have you watched the compressor in action? The compressor is driven by the fanbelt which turns a pulley on the compressor shaft, but there's an electric clutch that disengages the pulley from the friction plate attached to the compressor shaft. You should hear a click when the clutch engages and disengages. Do you hear that? Can you see the friction plate turning with the pulley or does it stay in one position while the pulley turns? If if works for a bit then stops turning, you may have a damaged friction plate such that it doesn't engage with the pulley. Take your car to an auto A/C specialist and let them examine it. It's also possible that the relay that sends 12 volts to the clutch is intermittent and needs to be replaced.
Jul 22, 2015 | Heating & Cooling
Whirlppol Side by Side no longer cooling well.
I'd suspect a failed thermostat in the fridge compartment, a split and sagging door seal, or a fault on the microprocessor control if it has one of those.
Feb 10, 2015 | Refrigerators
Blazer headlight relay keeps sticking on, replaced it twice.
probably the igniton switch, not to be confused with key switch, they are seperate.
Dec 16, 2013 | Cars & Trucks
Hello, my girlfriends 2002 kenmore refrigerator stops cooling after a few hours of being plugged in. Replaced the thermostat, replaced the fan, and replaced the computer board (which I thought was the...
The compressor feel hot to the touch after she quits? Could be a bad compressor relay. The ice box might have a fancy control but it still has relays just like the older ones. themobilian_256.jpgthemobilian_257.jpg
Nov 24, 2010 | GE GDS20KBS Bottom Freezer Refrigerator
2002 focus overheats very quickly (within 2 blocks). changed fan motor relay, thermostat, flushed coolling system and this still happens, although now a little longer till it overheats (6 blocks).. Ran...
Sounds to me like the impeller in the water pump is corroded bad enough that you now have no volume of water flow.If a pressure test on the cooling system shows no leaks and the rad fan does in fact run then this is the most likely solution,if the fan does not run you may need a temperature switch or a fan motor.
Sep 16, 2010 | 2002 Ford SVT Focus
2002 jeep grand cherokee larado is over heating. The cooling fanonly runs if I hotwire it. I changed th thermostat. Temp gauge is reading . Could it be the cooling fan relay if so where is it located. The...
Fan relay is located under pass headlight. Remove light assembly, use 2 1/2 " hole saw to drill hole in plastic housing ,3"from back wall, 3'' from left side.This will put you right over relay. Unscrew two bolts,replace. Relay was $40.... dealer wanted$350 to remove front bumper to replace it.
Sep 02, 2010 | 2002 Jeep Grand Cherokee
I am still having the problem with my car fan blowing when the car is off for more than an hour. it blows warm air on full blast. can hear outside of car. when put key in and turn ignition it stops.
There is a small relay unit which turns off the fan once it cools the engine. Have the relay unit replaced, also check the fuse if fuse is defective fan may run longer. than normal.
Jun 28, 2009 | 2002 Volvo S60
Refrigerators Logo
27 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
